Sorry to ask a very stupid question, but can you define VSS? Also, I am putting a dash back together and have no place to "hook" that wire up in the back of the instrument cluster. The pink/ black wire I have coming out of my fuse block that is in the position marked cruise control by the schematic has no place to plug in. Any help?
The VSS stands for 'Vehicle Speed Sensor'. There is a small rectangle opening in the back of the speedometer that one end of the VSS plugs into and then a small screw holds it in place.
There are wires connected to this small rectangular looking piece(which connects to the rear of the speedometer) that connect to a light green module as described in the post prior to yours.
Hope this makes sense and helps. If not, let us know what doesn't.
