#183793 - 07/21/06 06:37 PM
Re: Electric Fan FAQ
The Cadillackid
columbus, ohio
I rented a brand new charger while in DC this week and when the dual fans in that hit their high speed it was like a tornado.. im not sure what they are rated but they look like they would fit in a monte real well.. they are offset and not side by side so it looks like they cover more area than the ramcharger fans.. im sure being on a new car they are pretty expensive but possibly an option.. -Christopher
1988 LS, 385,edelbrock performer RPM and holley SA 770 carb, Headers,Duals,flow 40's, Gforce X-member, 2004R, Kevlar clutches ,Sonnax Servo,3000 Stall,3.73 Posi,Vette Rallies, Eagle GT II's, Nordskog Digital Dash, Mark VIII Fan, Ice Cold A/C,!Rebuild in progress! ** New 475HP Stroker SBC up and running!! and fryin Tires! **
#397536 - 01/08/07 05:01 AM
[Re: Black Rocket]
baaboo
Racine, WI
Yeah, but you'll need an ammeter that goes to 50? amps. You hook it inline with tha fans, and it shows the load direct. The factory told me 19.5 on my Ramchargers, but I measured it at 21 - 22 with a gauge.
#424440 - 03/28/07 05:27 PM
[Re: Bones]
Sparkee
Central ILL
FYI. I added my diagram to the new Album.  I also have other diagrams for single speed fans, both single and dual if anyone needs them. Just let me know have a good one!
There is no such thing as too much horsepower, as long as you can put it to the ground!!
#435374 - 04/30/07 12:00 AM
[Re: Aceprowler]
cleetus
NJ
Is a shroud necessary or can you just dump two 12" on there and be ok?
79 Monte:383, XE294HR, Holley 700DP, Protopline 200cc aluminum heads, 4.10 8.5" posi, 700r4 w/3000ish stall-- 12.04 @ 110.5. Crossing fingers for 11's.
#435477 - 04/30/07 04:30 AM
[Re: cleetus]
baaboo
Racine, WI
You should use a shroud so that all the radiator air flows, as opposed to sitting still. This would allow areas to NOT cool the fluid like it should. A LOT of cooling problems have been solved by adding a shroud.
#435896 - 05/03/07 01:34 PM
[Re: ]
cleetus
NJ
What size dual fans you use? Will 2 12's fit?
#436051 - 05/03/07 10:35 PM
[Re: Jeffrey Fontaine]
GregK
Winnipeg, Manitoba
Whatever you do, don't use the probe thermostats. They are horribly inaccurate, and are succeptible to variation depending on what the airflow across it is. Your best bet is to find a screw in switch that opens/closes that the temps you want and grounds the correct way. IIRC, There is an open spot in the thermostat housing, but I put mine in my Edelbrock manifold.
HTH, Jeff I've been using a probe in my SS for two years now and haven't had a single problem. The key is placing it close to the hose so airflow doesn't affect it.
1987 Monte Carlo SS White, Saddle, red stripes. All original. Factory ordered bucket seats with column shift (RPO verified!) http://www.ssmonte.com/
by BaerMonteSS83
by NC87AERO
by lonk
by johnz138
