BoiseSS Offline OP
For those that have made the S10 spindle conversion, how close is your tie rod end to the weel on the drivers side? Mine hits a 15" wheel. Shouldn't be a prolem once I go to17", but still concerning.
1985 Monte Carlo SS
Under construction with a LS376 with a 4L70E
I run a standard S10 spindle with a 2.5 inch spacer and an 18x9 wheel. Not much clearance there, but its enough.
86 SS 6.2l LS3, Ilmor intake, Summit Stage 4 Cam, Stainless long tube headers, Stainless 3in exhaust, Tremec T-56 Magnum 6 speed, Eaton Truetrac 8.8 LSD, UMI Cornermax Front Suspension, 3-link Rear suspension w/ UMI Control Arms, UMI Front & Rear Braces, Brembo Brakes. 496whp/472wtq
B
B
I'm running the S10 spindles with stock wheels. No clearance issues.
~ Matt H.
16,069 Registered Users
