Posts: 47 Likes: 1
OP
Posts: 47 Likes: 1 |
Have any of you fine ladies or gentleman ever heard of removing the steering shaft to get the rubber out of the equation and replacing it with a astro van lower shaft. i was told it is a direct swap. not feeling 40 year old rubber on my steering shaft,if you have may i have the years this will work. Thanks in advance
Posts: 1,163 Likes: 27
Posts: 1,163 Likes: 27 |
I used the 96-05 2wd astro steering shaft and have seen no negative effects and like how it looks.
Posts: 1,293 Likes: 1
10+ Year Member
10+ Year Member
Posts: 1,293 Likes: 1 |
There is a Jeep Cherokee shaft that is often used as well, but it sometimes requires a little work to collapse. I don't think anyone has regretted either swap.
The astro shaft installed, not sure whybthe picture is so big. ![[Linked Image from i.imgur.com]](https://i.imgur.com/yuxmtMk.jpeg)
1 member likes this:
86ttop |
Posts: 47 Likes: 1
OP
Thanks you guys I appreciate the help off to the pic a part next week, again thank you
Posts: 9,309 Likes: 3
20+ Year Member
20+ Year Member
Posts: 9,309 Likes: 3 |
The XJ cherokees worked, at least for part of hte run. Pretty common swap. Collapsing them is easy with a propane torch. I have one on both of my SS's and would never go back to a rag joint.
0 members (),
133
guests, and
11
robots. |
Key:
Admin,
Global Mod,
Mod
