#1077028 05/20/23 01:37 PM
H
HyperV6 Offline OP
H
Anybody have a 200R4 CZF they are wanting to sell from a 1986 thru 1988 SS?
Thanks, Craig
K
K
I'll have one but pretty far away.
H
HyperV6 Offline OP
H
Can you send me a private message with some more information. What year is it? Original? Rebuilt? Modified? Any pictures you could send?
Thanks for any info. Craig
K
K
Will do.
K
K
Some info and pics of my current transmission. WC-T5 going in this summer.
Transmission
Uninstall, bring to local shop to rebuild with my parts, install
Driveshaft rebalanced by local shop
New Spicer U-Joints
2400 stall torque converter
10-vane front pump
TransGo HG2 rebuild kit with new clutches and steels w/Alto red band
ArtCarr deep aluminum oil pan
New TCC solenoid installed
Trans Temp Sensor installed in side of pan
Grand National servo
Bowler 4th gear lockup kit
New plate-style trans cooler
Cleaned, sanded, and painted battleship gray
G-Force Crossmember (excellent product)
BowTieOverdrives TV System w/braided cable line
[Linked Image from kpittman.com]
K
K
You may want something stock.
Give Jim a call, he's been around a while and may have just what you're looking for.
CL GBody Parts
H
HyperV6 Offline OP
H
Guys, I'm really looking for a core. Thanks for any leads.
Craig
B
B
I have one that I'm planning to pull from the car. It has a CK Performance shift calibration kit and billet servo installed. It has a pretty bad leak from the pump area - I suspect a blown seal but haven't pulled it or really inspected it. Swapping in a T5. I'm in eastern PA though, so not close.
~ Matt H.
H
HyperV6 Offline OP
H
PM sent, not sure if you have seen it.
Thanks, Craig
B
B
Replied! Sorry, hadn't checked the forums since I commented.
~ Matt H.
0 members (), 57 guests, and 13 robots.
16,053 Registered Users
