OP
Posts: 75 |
Anybody have a 200R4 CZF they are wanting to sell from a 1986 thru 1988 SS?
Thanks, Craig
15+ Year Member
15+ Year Member
Posts: 1,461 |
I'll have one but pretty far away.
OP
Posts: 75 |
Can you send me a private message with some more information. What year is it? Original? Rebuilt? Modified? Any pictures you could send?
Thanks for any info. Craig
15+ Year Member
15+ Year Member
Posts: 1,461 |
15+ Year Member
15+ Year Member
Posts: 1,461 |
Some info and pics of my current transmission. WC-T5 going in this summer. Transmission Uninstall, bring to local shop to rebuild with my parts, install Driveshaft rebalanced by local shop New Spicer U-Joints 2400 stall torque converter 10-vane front pump TransGo HG2 rebuild kit with new clutches and steels w/Alto red band ArtCarr deep aluminum oil pan New TCC solenoid installed Trans Temp Sensor installed in side of pan Grand National servo Bowler 4th gear lockup kit New plate-style trans cooler Cleaned, sanded, and painted battleship gray G-Force Crossmember (excellent product) BowTieOverdrives TV System w/braided cable line ![[Linked Image from kpittman.com]](http://kpittman.com/88montess/images/newtrans1.jpg) ![[Linked Image from kpittman.com]](http://kpittman.com/88montess/images/newtrans2.jpg) ![[Linked Image from kpittman.com]](http://kpittman.com/88montess/images/P1010617s.jpg) ![[Linked Image from kpittman.com]](http://kpittman.com/88montess/images/P1010566s.jpg) ![[Linked Image from kpittman.com]](http://kpittman.com/88montess/images/P1010559s.jpg) ![[Linked Image from kpittman.com]](http://kpittman.com/88montess/images/P1010239s.jpg) ![[Linked Image from kpittman.com]](http://kpittman.com/88montess/images/P1010454-2.jpg)
15+ Year Member
15+ Year Member
Posts: 1,461 |
You may want something stock. Give Jim a call, he's been around a while and may have just what you're looking for. CL GBody Parts
OP
Posts: 75 |
Guys, I'm really looking for a core. Thanks for any leads.
Craig
15+ Year Member
15+ Year Member
Posts: 987 |
I have one that I'm planning to pull from the car. It has a CK Performance shift calibration kit and billet servo installed. It has a pretty bad leak from the pump area - I suspect a blown seal but haven't pulled it or really inspected it. Swapping in a T5. I'm in eastern PA though, so not close.
~ Matt H.
OP
Posts: 75 |
PM sent, not sure if you have seen it.
Thanks, Craig
15+ Year Member
15+ Year Member
Posts: 987 |
Replied! Sorry, hadn't checked the forums since I commented.
~ Matt H.
2 members (86eses, Donzi4me),
68
guests, and
12
robots. |
Key:
Admin,
Global Mod,
Mod
