I will try to make a long story short. Last year I bought a new headliner from OPGI after I noticed how faded mine was. I ordered the only burgundy color they offered. When I received it, it looked good so I proceeded to cut the hole for the dome/map light. Eventually, I discovered that the color match was way off, way too light. I compared it to a section of excess carpet from my new installed carpet, which was a perfect match to my burgundy plastic pieces and Mikes Montes burgundy interior paint. Since I already cut the dome/map light hole, I did not try to return it. My car has the dual map lights installed in the roof panel. I bought a new headliner from Mikes Montes, which was a perfect color match to my new carpet and existing plastic pieces and Mikes’ burgundy paint.
So I need to sell the OPGI headliner. The box is huge and taking up space in my garage. The box has the headliner rolled up inside, same as Mikes Montes. Pictures are provided below. I hope that someone can dye it darker with fabric dye. I paid $380 for it delivered, but because of shipping costs, could reach $150 via FedEx, I am selling it for FREE plus shipping. My loss is your gain. It is a complete headliner with a very flexible plastic backer, with fabric that is lighter than our burgundy interior. The dome/map light hole has already been cut and the fabric over the sun visor holes has been cut. I am not sure if a standard dome light is in the same location as the dual map lights. That could be a problem if you have a standard dome light. OPGI provided holes already cut through the plastic base for the sun visors so all I did was cut the fabric and fold it back to expose the holes for the sun visors. It has not been trimmed to fit my car. I never tried to install it. The design was nearly identical to Mikes Montes headliner and I trimmed an inch or two off the sides of it to get it to fit properly. I would expect the same for the OPGI headliner.
This post was still longer than I wanted it to be. Sorry.
[Linked Image from live.staticflickr.com]
87 SS, UMI trailing arms. Hooker 2050 Jet Hot Coated Headers. Hooker Cat-Back Exhaust, GM 350, Ported TPI, Trick Flow 56cc alum heads, SLP runners, Comp Cams 260AH-12 cam, Trick Flow roller rockers, TCI 2400 stall converter, Denny's 3.5" Driveshaft, GBodyParts GNX Replica Rims 18x8 &18x9, F-Body Serpentine Belt Sys with Sanden A/C compressor mod.
