OP
Posts: 8 |
Good Morning! I have a 87 MC SS 305HO. So I developed a coolant leak at the rear coolant cross over at the gasket on the intake. I removed the intake and saw that the gaskets have block offs on both rear sides of the head with a small hole in the middle. Im assuming these are original due to the engine only having 89,000 original miles. Do I have to put the exact same gaskets back on or can I use open ended port intake gaskets? I have a new set already from a auto parts store auction I went to a couple months ago. And whats the deal with the blocked off ports anyway? I've only seen block offs on the exhaust crossover. Thanks !
87 SS,55 Belair
Posts: 869 Likes: 9
Posts: 869 Likes: 9 |
You will be fine using an open ended gasket, I have never had any issues and i used the fel pro 1204 or 1205 if I remember correctly.
Posts: 12,051 Likes: 4
20+ Year Member
20+ Year Member
Posts: 12,051 Likes: 4 |
As you can see, the intake gaskets swap without issue from side to side, it is the intake that is blocked off, good luck with your car!! https://www.amazon.com/Fel-Pro-1204...&hvtargid=pla-570517429851&psc=1
2 members (Mick, PB86SS/87LS),
39
guests, and
9
robots. |
Key:
Admin,
Global Mod,
Mod
