Page 2 of 2 1 2
K
K
Originally Posted by SickSpeedMonte
Do you have a starter for the smaller flywheel?
I'm wondering why I'd need a different starter. Wouldn't the mount location just move in a bit to adjust for the smaller diameter flywheel?
I'm pretty sure you're going to need the starter for the application that your WC T5 came out of. I've never seen a starter or block with two sets of holes.
Some of the mini starters have bolt patterns where it can be used on 168/153 tooth. If it's a standard style starter you will need a 153 tooth starter.
K
K
Ok, good to know! Thanks, I'll go look for a T5 starter for an 88 Fbody.
Not sure if you have your orginal starter but it should be 153 tooth.
K
K
Looks like I used the 153 tooth flywheel from my original 305. Hey Paul, thanks for keeping old posts!
[Linked Image from kpittman.com]
Page 2 of 2 1 2
