20+ Year Member
OP
20+ Year Member
Posts: 1,592 |
i have the bottom out and the torx bolts out of the upper one. it will lift ouward but i cant get the top onhooked. any good tricks?
Posts: 5,690 Likes: 1
20+ Year Member
20+ Year Member
Posts: 5,690 Likes: 1 |
Push the top of the seat back in as you pull up from underneath. https://www.turbobuick.com/threads/rear-seat-removal.44583/#:~:text=Start%20on%20the%20driver%20side.....Take%20the%20driver%20side,have%20been%20unlached%20remove%20it%20from%20the%20car.
20+ Year Member
OP
20+ Year Member
Posts: 1,592 |
i got it out. several writeups say its just like the bottom latch where you have to push down and back but the upper one is just like a hook and it just needs to come straight up. i looked down from the top and saw the 3 latches.you can easily just pry them out a bit with a screwdriver to make it easier. i removed it to repair some rust under the passenger side but found that there was basically no floor at all left on that side under the rug and seat. i had to fab up a new floor from sheetmetal i had. all good now!
Posts: 12,032 Likes: 4
20+ Year Member
20+ Year Member
Posts: 12,032 Likes: 4 |
