#1074260 - 07/04/22 07:59 PM
Getting ready 305 to 350 swap
GNX89
Los Angeles, Ca
I just got an engine that was previously rebuilt and driven for a short time due to a bad trans. 350 engine 14010207 casting was told it is a 4 bolt and with a cam. Engine has been sitting in a garage for 5+ years. I will replace valve cover gaskets, oil pan gasket and replace intake with a stock 86ss one. Manifolds will be changed to edelbrock headers. Will probably also swap over my stock 86 dizzy too. Planing to keep stock ccc components on it. I am planning on replacing engine and leaving trans in the car. Looking for some general guidance. Is there anything else I should replace since engine is out?
#1074261 - 07/04/22 09:11 PM
Re: Getting ready 305 to 350 swap
[Re: GNX89]
johnz138
Sterling Heights, Mi
As for engine wise sounds like u got it covered. Since its out toss on a new timing chain cover gasket, check the timing chain also. Check balancer if it comes with one. Good time to change out motor mounts too. Ya know, just check everything over.
1987 Monte Carlo SS, Lightning Rod equipped, engineless/2004-R,Holley carb, edelbrock intake, hooker headers, moog,Iceman crossmember, umi suspension, eibach springs,so much more,no computer/emissions. http://www.cardomain.com/ride/2167110
#1074263 - 07/04/22 10:59 PM
[Re: GNX89]
Honolulu
Somebody correct me if I'm wrong... Agreed you seem to have it covered so I'm going to try field out some gotchas. '86 was kinda the cross year between 2 piece rear main seals (-'85) and 1 piece ('86-) but also retained perimeter valve covers and early style intake w all bolt holes at the same angle. With that said, the flexplate between 2 piece vs 1 piece is different so if the 350 didn't come with one the '86 from your 305 will not work. I would inspect the condition of the frost plugs and change any that looks questionable especially the inaccessible once the transmission is bolted on. If your 350 came with perimeter bolt valve covers then safe to say your '86 intake will work. Center bolt would dictate '87- intake.
1985 GMC Caballero 4.3L V6 TBI 200C w/ 2.41 peg leg 86 Monte Carlo SS BBC396 M20 w/ 3.42 posi screen name whip rust i.p.
#1074267 - 07/05/22 02:08 AM
[Re: GNX89]
johnz138
Get piston #1 at DTC, then mount the distributor pointing at cylinder 1. Hook up timing light and adjust as needed when engine runnin.
#1074283 - 07/06/22 01:19 AM
[Re: GNX89]
That is an 80 to 85 engine according to the casting number and takes the earlier flexplate, use if over it it's in good shape and good luck with your swap!!
#1074623 - 07/27/22 03:44 AM
[Re: GNX89]
Vincenti
Eldersville PA
The ZZ4/ L69 hybrid PROM that bitflipper makes would most definitely benefit you. You must use your '87 ECM for his PROM. 10456288 is the knock sensor number.
by BlueStreak In Spring
by SickSpeedMonte
by SSONAIR
by hotrodmc
by Monte man
