Just installed the below Demon Eye Headlights and had a question about wiring. My low beams have outside lights on as if it was a high beam, (all 3 lights on inside housing). When I switch to high beams the inner ones come on as a high beam but outer ones stay on now as a true low beam, (just two side light on inside housing). The middle circular light turns off on the outer ones when my high beams are on but stays on when my low beams are on. Is this the way they should work, wondering if anyone else has these installed or not. Thanks in advance and sorry if post is confusing...
Not sure about those in particular, but I know in general on these headlights there are some times that you need to swap wires to get them operating right. Based on what you're saying, I think you just need to swap the two wires for high and low beams. You might be able to repin the plug, or I think there are some adapters you can get for a few bucks on Amazon to make it easier.
Thanks for the info, I ended up doing exactly what you suggested and swapped the high/low wires on the low beams and it's functioning properly now! I did notice I have a couple green wires in my headlight harness that go to a small black plug but it isn't plugged in anywhere. I have the same plug on both drive side and passenger side of the harness. Anybody have any idea what they go to, it seems like everything is functioning properly just hate to have stuff dangling that I don't know about. Thanks
