OP
Posts: 194 |
Just installed the below Demon Eye Headlights and had a question about wiring. My low beams have outside lights on as if it was a high beam, (all 3 lights on inside housing). When I switch to high beams the inner ones come on as a high beam but outer ones stay on now as a true low beam, (just two side light on inside housing). The middle circular light turns off on the outer ones when my high beams are on but stays on when my low beams are on. Is this the way they should work, wondering if anyone else has these installed or not. Thanks in advance and sorry if post is confusing...
https://www.amazon.com/Globled-Headlight-Conversion-Projector-Replacement/dp/B09GBCFNDN/ref=sr_1_29?crid=1HHJ2XKVGJEIW&keywords=demon+eye+headlights+4x6&qid=1658166184&s=automotive&sprefix=demon+eye+headlights+4x6%2Cautomotive%2C182&sr=1-29
Posts: 1,273 Likes: 1
10+ Year Member
10+ Year Member
Posts: 1,273 Likes: 1 |
Not sure about those in particular, but I know in general on these headlights there are some times that you need to swap wires to get them operating right. Based on what you're saying, I think you just need to swap the two wires for high and low beams. You might be able to repin the plug, or I think there are some adapters you can get for a few bucks on Amazon to make it easier.
10+ Year Member
10+ Year Member
https://www.amazon.com/Partsam-Harness-Sockets-Headlights-Headlamp/dp/B01N5HLF7U/ref=mp_s_a_1_3?crid=KQLD1KPIPDBT&keywords=h4+headlight+adapter&qid=1658201184&sprefix=h4+headlight+ada%2Caps%2C105&sr=8-3
Something like that is what you would need, I think.
OP
Posts: 194 |
Thanks for the info, I ended up doing exactly what you suggested and swapped the high/low wires on the low beams and it's functioning properly now! I did notice I have a couple green wires in my headlight harness that go to a small black plug but it isn't plugged in anywhere. I have the same plug on both drive side and passenger side of the harness. Anybody have any idea what they go to, it seems like everything is functioning properly just hate to have stuff dangling that I don't know about. Thanks
15+ Year Member
15+ Year Member
Posts: 635 |
Having an issue with Phillips LED lights on an 82 SC. Bought the adapters, can get Low beams and Hi beams but cannot get both on together? Supposed to be H4 configuration on the light. Thanks
![[Linked Image]](http://i11.photobucket.com/albums/a161/black95jimmy/Monte.jpg) 82 SC, Light and Dark Redwood Metallic. 355, Vortec Heads, Roller Rockers, Pypes True Duals, 670 Street Avenger. SS Steering and Sway Bars. Enkie Wheels. Jeep Intermediate Shaft, ZQ8 Bump Stops.
15+ Year Member
15+ Year Member
Posts: 5,145 |
This pigtail is needed for only the low-beam lamps. You will need 2 pigtails. https://www.rallylights.com/hella-adapter-from-165mm-sealed-beams-to-h4-conversion-lamps.htmlThe high beams use the 2 opposite terminals. As for the extra green wires, you could try to tap into the + wire on the running lights, and perhaps to the side turning lamp to get the daytime running lights to blink as a turn signal, you have 3 options with the front and side lighting. HTH
