#1074448 07/15/22 10:11 PM
8
Hey guys, rear driver side wheel making kinda a clunking noise. Are there bearings back there that could be possibly causing that? When I jacked wheel up, it had a little play, thanks
Up and down play or in and out play?? Yes, there are bearings at each axle which the axle rides on. Does in make it all the time or once in a while, the rear shock might be loose, good luck!!
8
It does it side to side, but I think it’ll do it any which way. It’s a small amount, but def makes that clunk when I jack it up off the ground and do it
