#1069042 01/01/21 04:10 PM
BoiseSS Offline OP
It's been a long time coming, but my Monte is going to get finished finally. Teamed up with Kenny's Rod Shop here in Boise and with his help she'll get done.
So now a little visual history.
Here she is stock in '93
After her first paint job, the beginnings of Grey Wolf. Check out the oversize emblems grin
Now a defunct local car show, McDonald's Picnic in '94. A glimpse of a Hurst 442 in background
In the next post, where she was before I tore her apart.
1985 Monte Carlo SS
Under construction with a LS376 with a 4L70E
BoiseSS Offline OP
A visual history continuation
The 355 I built
Now Grey Wolf in her glory laugh
Next some deconstruction
1985 Monte Carlo SS
BoiseSS Offline OP
Continued
Front clip removed
Clean frame horn
Clean floor pan
The 355 is out
The empty engine bay
Now to build her up again, into Redline
1985 Monte Carlo SS
BoiseSS Offline OP
Now we are here today. Again Kenny's Rod Shop (KRS) will be helping me get her back together. Once a slot opens up with his painter, I'll get her to KRS. There he'll shave the door handles to flush door handle, get her off the chassis and put on the rotisserie. Then I get the chassis back to do my part. The body will go to strip and paint while I work chassis. So for a sneak peek at what will be going in.
LS376/480 495 HP
Hopefully I can keep posting on this thread on a consistent basis. That means she's getting close to driving again.
Stay Tuned!
1985 Monte Carlo SS
Online Content
Looks good! Interested to see your progress.
Looking good, will be watching.....
black 87 SS,grey int,355, Edelbrock rpm intake and rpm heads,xe262,holley 600 vac,x-stream k&n,goodmark cowl, 18" Billet Specialties wheels, Nitto 245/45 and 275/40 tires, GN rear diff. Baer brakes 13"front, 12" rear, Street-Comp AFX front suspension
BoiseSS Offline OP
Just a quick post for a tiny update. I got some dress work done on the LS3. I'm still waiting on the hose fittings for the fuel rail crossover. But got the valve covers painted and installed. Helpful hint, if anyone ever gets the Proform coil pack relocation kit that I have, assemble it off the engine. If you drop one of the washers, they WILL make it under the manifold onto the valley pan.. So I had a set of valve cover stickers made for an old school look. Here is what it looks like now.
Now I have a question for you all. What should I do with the oil pan? Should it stay bare aluminum, paint it red or paint it black?
1985 Monte Carlo SS
Hi Boise - I'd go with a thin layer of black paint to improve surface emissivity. The idea here is to make the oil pan a good heat sink.
Online Content
I think it would look good black. Kind of tie in the top, front, and bottom.
BoiseSS Offline OP
Just a quick update. Got some parts in last night. I'm going with the Dakota Digital RTX gauge set up. I want to use the two gauge set up to replace the ash tray in front of the console. So I had Dakota Digital make two gauges for me, a trans temp and fuel pressure. They turned out perfect. Here are the visuals.
More parts are in, I'll get those posted soon.
1985 Monte Carlo SS
BoiseSS Offline OP
Just a parts update. Finally the entire suspension kit showed up. Friday the Currie rear end shows up. Now I just have to wait on the shop to say they're ready for me. They'll remove the body and give me the frame back to work on it while the body is at paint. Getting itchy to start work and all the parts piled up in the garage doesn't help.
Here are all the pretty bits.
1985 Monte Carlo SS
C
C
Looks good, that is the same suspension I put in mine 87 monte carlo SS aerocoupe. Currently in shop getting ls3/6l80 swap. Engine, trans installed exhaust being installed. I also had dakota digital istrument panel installed. Again good looking car and setup.
Online Content
The one I went with from mikes montes. Its a quality piece. I should have my vacuum gauge from speedhut this week. Man, those Dakota digitals are nice.
I must say everything you have done so far with that car is A+, top notch. Keep it up.
F
F
Steven, that is a beautiful build. You will have an awesome machine when you are done. It gives me some inspiration to do some upgrades. Good Luck
Fred
Hi Boise,
Everything looks great except for the rear control arms, and specifically, those cylindrical TPU bushings. They're a big mistake in the rear, because they'll greatly inhibit articulation of the suspension.
BoiseSS Offline OP
Just a quick update. Just got back my rendering from KEG Digital Garage. I'm really happy with it. They even chose an appropriate background without asking.
What do you think?
1985 Monte Carlo SS
Online Content
Looks nice!
Looks great, nice build/thread. Cool to see the different iterations your SS has had, stock, dark silver(dig that color/shade) with the 355 to the update to more modern suspension and the LS3.
BoiseSS Offline OP
Finally!!!!!! The car is at the paint shop! They're going to put all panels back on so they can block with proper gaps. Then they're going to blow her back apart and get me the chassis. Then I can post pictures of all the fun That I get to have. Stay tuned.
1985 Monte Carlo SS
Online Content
Progress!
Sadly, if you want the car to be both low and handle, you're going to hate the QA1 front suspension kit.
BoiseSS Offline OP
Well i got some pictures from the paint shop. the flush door handles are done. also the car is almost ready for first prime. Once the shop is done with the Jeep that's on their rotisserie they'll pull that off and mine goes on. that means the chassis will be close to coming home and for me to get to work on it.
[Linked Image] [Linked Image]
Also I've started a YouTube channel to document the work on the chassis. The first episode is just a rehashing of what I've already posted here, but take a look.
Redline Monte Carlo
Again, I'm close to getting the chassis and getting to work. Stay tuned.
1985 Monte Carlo SS
BoiseSS Offline OP
Ok all, it's been a minute since I last posted. Since then I was able to get the chassis from the body shop and started to strip it down. Got it boxed in and sent it to powder coating. Got it back from there and started putting all the new parts on. Instead of pics I'll post my last Youtube video. There are a total of 5 videos on my channel.
Redline Monte Carlo
1985 Monte Carlo SS
That's a cool build thread, well done.
