#1073972 - 05/24/22 01:08 AM
Re: Chole lite on
[Re: Keithss]
Did you reuse the old oil pressure switch?? It may need to be replaced, good luck!!
#1073974 - 05/24/22 11:58 PM
Re: Chole lite on
[Re: Keithss]
AkronAero
Keith,
Did this start when you replaced the "switch" last summer? The "on/off switch" for the light and the "continuous metering sender" for the gauge can be confused by the auto parts stores, and are not interchangeable. Might confirm that first?
I am traveling and don't have my shop manual, nor much of my memory, so I don't recall if these are single wire (ground through the body) or two wire (power and ground). Especially if its single wire, make sure you are NOT using teflon tape as it cuts the ground. Use teflon dope instead.
Let us know any updates and thanks for sharing.
#1073983 - 05/26/22 10:48 PM
Re: Choke lite on
[Re: Keithss]
Keithss
Jackson,mi
Ok This is what I did today got a new oil sending unit and installed it. Same Problem Went back to town and got a new carb thermostat and installed it. Same Problem
Light still stays on when the ignition is turned on, and the positive wire is hooked up.
Would someone be willing to check there no-computer controlled electric choke system with the positive wire disconnected and then with it connected??
When I am disconnected, I get 12 volts, when I hook it back up I only get around 1 volt. I made jumpers to give it a positive ground and the same problem.
Open to all ideas at this point
Thank you Keith
#1074008 - 05/30/22 01:06 AM
Re: Choke lite on
[Re: Keithss]
#1074009 - 05/30/22 01:29 AM
Re: Choke lite on
[Re: Keithss]
AkronAero
Keith - you just made us all a bit smarter. Persistence paid off. Thanks for sharing. Gordon
by javi05
by Matt?
by dw329
by zz485ss
