#1073919 - 05/15/22 11:22 PM
Re: ECM & removed - other connectors?
[Re: AeroSS_87]
First picture it will not hurt to leave them tucked away. Second picture is your engine oil pressure switch its circuit is on the top side of the schematic, when it senses over 4 psi the switch closes and it sends power to your choke heater and also goes to your oil/ choke indicator on right side of dash. I removed the brown wire headed to the computer. I wanted to retain my choke heater and oil/choke indicator. The oil pressure sender to the gauge is mounted above the oil filter. ![[Linked Image]](https://i.imgur.com/Cxj5dYp.jpeg)
#1073920 - 05/15/22 11:35 PM
[Re: AeroSS_87]
Third picture is plug that goes to power steering pressure switch. I removed this switch and installed a power steering hose off a non ac car. As you can see in the below diagram the dk green wire comes from the ac pressure cycling switch to the power steering switch, then leaves a green white wire to power the ac clutch. I still have ac so I came straight from the ac pressure cycling switch with the dark green wire straight to the ac compressor clutch. Not sure on the other connecter in the picture looks like the connector to the water temp sensor that goes to your gauge but I would need to know wire colors. ![[Linked Image]](https://i.imgur.com/YAYeGDp.jpeg)
by BaerMonteSS83
by NC87AERO
by lonk
by johnz138
