#1072919 - 01/10/22 12:11 AM Cam, Lifters, Timing Chain Set, and Break In oil
88ssBrent Online content
88ssBrent  Online Content
I was going to use this in my original 305 build http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=1069059#Post1069059 but had issues with the heads and ended up getting roller heads so I used a roller cam and lifters. I was going to use this with trickflow heads and 1.6 rockers. Comp cams also recommends this cam for our 305 with the ccc using factory 1.5 steel rockers (attached email). The cam, lifters,
and timing set have only been degreed in the block then removed, never have been used. I would do $250 shipped. To buy from Summitt it would be $384+tax. I would be willing to separate so just message and we can talk price.
Cam 12-249-4 $173.95
Check out this page from Summit Racing https://www.summitracing.com/parts/cca-12-249-4
Lifters 858-16 $123.95
Check out this page from Summit Racing https://www.summitracing.com/parts/cca-858-16
Timing chain set $27.99
Check out this page from Summit Racing https://www.summitracing.com/parts/clo-c-3023x
5 bottles of Driven break in oil $54.95
Check out this page from Summit Racing https://www.summitracing.com/parts/jgr-03706
#1072951 - 01/13/22 12:12 AM Re: Cam, Lifters, Timing Chain Set, and Break In oil [Re: 88ssBrent]
Anyone wanting to pump up the 305 should jump on this - heck of a deal. Good seller as well!!
#1072964 - 01/15/22 02:22 AM Re: Cam, Lifters, Timing Chain Set, and Break In oil [Re: BadSS]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Good deal. Should work equally as well on a 350. 112 degree lobe separation will give a smooth idle. It should pass emissions test in states that still do that on older cars. The cam in my TPI 350 has similar specs but with 212/212 duration at .050 and it passed emissions back when New Jersey did testing on older cars. Good luck with the sale.
Fred
500/thumbs/monteback.jpg
by Cimerian
500/thumbs/toms_monte-11.jpg
by 84casper ss
500/thumbs/tub_paint.jpg
by jnw86
871/thumbs/Foose_6.jpg
500/thumbs/Monte_Carlo_new_paint002.jpg
by troublesnc
