15+ Year Member
OP
15+ Year Member
Posts: 161 |
Posts: 5,215 Likes: 5
15+ Year Member
15+ Year Member
Posts: 5,215 Likes: 5 |
15+ Year Member
OP
15+ Year Member
Posts: 161 |
15+ Year Member
15+ Year Member
15+ Year Member
OP
15+ Year Member
Posts: 161 |
Posts: 7 |
From my experience with Holley carbs if the engine backfires out the exhaust it generally means a rich condition- if it backfires through the intake its running lean. This assumes your problem is carb related.
Posts: 2,080 Likes: 12
20+ Year Member
20+ Year Member
Posts: 2,080 Likes: 12 |
I’m a little late to the party but the vast majority of the time when headers are glowing red it’s due to retarded timing and the unburnt fuel is igniting in the headers. It would have to have a big time serious vacuum leak for them to glow red due to a lean condition.
If you know your timing tab is correct and the timing looks good it could be an issue with the MSD. If you’re not sure about the timing mark loosen the distributor, rev the engine up around 3,000 rpm and hold it steady. Then move the timing back and forth to see if the engine increases with the movement. Where it revs the highest is where your engine wants the timing with the springs you have in the distributor.
If the base timing ends up being too low or too high after doing this you’ll need to play around with the springs and or the vacuum advance pod if you have one to get the base timing and the total timing where they need to be.
10+ Year Member
10+ Year Member
Posts: 317 |
The best test is propane enrichment at idle, put propane in the air filter area and see it the colors goes back to normal, if it does you know it is not a rich issue, it could be lean, or retarded timing but you said you where driving it for a bit and it was fine. do you have spark plug wires that can handle MSD, you did not say it was skipping so I am going to assume your wires are for MSD, I am thinking the MSD has gone bad or the distributor, or the wiring to and from, A timing light may give you an indication but that is not a solid diagnosis. If the propane makes it idle and no red headers odds are all is good with your MSD. I have seen carbs go bad and cause this issue but usually both banks. how much vacuum does a gauge say? Good Luck 18 inches is what you want.
Posts: 1,089 Likes: 23
Posts: 1,089 Likes: 23 |
Badss is correct in what he is saying. When I built my engine the first time I fired up I didn't have my distributor where it needed to be. Headers where so hot that it flaked off my new ceramic coating, glowing red, and melted anything and everything within 6". It was about a $600 mistake, timing is the first thing I would check. I seem to think that there might be a issue with the msd.
15+ Year Member
OP
15+ Year Member
Posts: 161 |
15+ Year Member
OP
15+ Year Member
Posts: 161 |
15+ Year Member
OP
15+ Year Member
Posts: 161 |
15+ Year Member
15+ Year Member
Thanks for the help, it was the intake manifold gasket that was the problem.The Monte is up and running. Also the corrosion on the MSD distributor is a know problem with that model according to MSD. Probably late, but did you check the intake manifold for warpage? I had intake vacuum issues and it turned out the manifold was warped.
0 members (),
57
guests, and
13
robots. |
Key:
Admin,
Global Mod,
Mod
