#1072471 - 11/12/21 08:36 PM
won’t idle/ running lean.
8T7AERO
Corona, CA
#1072473 - 11/12/21 09:58 PM
Re: won’t idle/ running lean.
[Re: 8T7AERO]
Buick Runner
#1072539 - 11/21/21 07:50 PM
[Re: Buick Runner]
8T7AERO
Corona, CA
#1072541 - 11/21/21 08:27 PM
[Re: 8T7AERO]
Buick Runner
#1072543 - 11/21/21 09:17 PM
[Re: Buick Runner]
8T7AERO
Corona, CA
#1072729 - 12/14/21 05:56 PM
[Re: BadSS]
8T7AERO
Corona, CA
#1072863 - 01/05/22 01:10 AM
[Re: tom demarco]
8T7AERO
Corona, CA
#1073111 - 02/05/22 06:08 PM
[Re: 8T7AERO]
8T7AERO
Corona, CA
#1073117 - 02/06/22 12:03 AM
[Re: 8T7AERO]
Buick Runner
Thanks for the help, it was the intake manifold gasket that was the problem.The Monte is up and running. Also the corrosion on the MSD distributor is a know problem with that model according to MSD. Probably late, but did you check the intake manifold for warpage? I had intake vacuum issues and it turned out the manifold was warped.
by montesleeper83
by montec_ss85
by pazzo1969
by Rich.S85SS
by BENCHSEATRACIN
