#1072535 - 11/21/21 05:04 PM Idling high w/ computer
Ranger413 Offline
Ranger413  Offline
South GA
New intake manifold gaskets, rebuilt carb.
Having trouble. . .
Set base timing with distributor 4 pin disconnected, idling at about 650 in park. All seems good there. Engine warm, off of high idle cam.
Plug computer back in and the idle sits at 1100 or so.
Help!
88 MCSS, T-Top Notch Back, Factory 305
#1072538 - 11/21/21 06:17 PM Re: Idling high w/ computer [Re: Ranger413]
Ranger413 Offline
Ranger413  Offline
South GA
I might be close. Seems like the rebuilt carb is not exactly meshing up with the linkages, possibly. Had to turn the cruise linkage out a hair for a little play. I think I could also use a new throttle return sping. Runs great otherwise.
#1072542 - 11/21/21 08:35 PM Re: Idling high w/ computer [Re: Ranger413]
With the dist diconnected from the computer, it goes into limp mode with no timing advance and full rich command. Once the dist is reconnected the computer advances the timing which should increase the rpm. 650 rpm in park is low, 1k is more normal in park. In drive it should idle at 600 to 650. Idle in drive is lower than idle in park due to the load from being in gear. This is why idle adjustments are made in drive.
#1072545 - 11/21/21 09:39 PM Re: Idling high w/ computer [Re: Ranger413]
Ranger413 Offline
Ranger413  Offline
South GA
That makes much more sense to me. I think I'm about there.
500/thumbs/MC22.jpg
by 87Aerocoupe87
500/thumbs/andrew_car_087.jpg
by gunga
568/thumbs/badbattz.jpg
by battz89
500/thumbs/aerobill.jpg
by SS101
1026/thumbs/Wheels_and_Waves_group_shot_final_copy.jpg
by 1KOOL86
