#1072471 - 11/12/21 08:36 PM won’t idle/ running lean.
8T7AERO Offline
8T7AERO  Offline
Corona, CA
#1072473 - 11/12/21 09:58 PM Re: won’t idle/ running lean. [Re: 8T7AERO]
Buick Runner Online content
Buick Runner  Online Content
#1072539 - 11/21/21 07:50 PM Re: won’t idle/ running lean. [Re: Buick Runner]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
#1072541 - 11/21/21 08:27 PM Re: won’t idle/ running lean. [Re: 8T7AERO]
#1072543 - 11/21/21 09:17 PM Re: won’t idle/ running lean. [Re: Buick Runner]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
#1072579 - 11/28/21 05:47 AM Re: won’t idle/ running lean. [Re: 8T7AERO]
Chargedbill Offline
Chargedbill  Offline
Mundelein, il
From my experience with Holley carbs if the engine backfires out the exhaust it generally means a rich condition- if it backfires through the intake its running lean. This assumes your problem is carb related.
#1072597 - 11/29/21 09:44 PM Re: won’t idle/ running lean. [Re: 8T7AERO]
I’m a little late to the party but the vast majority of the time when headers are glowing red it’s due to retarded timing and the unburnt fuel is igniting in the headers. It would have to have a big time serious vacuum leak for them to glow red due to a lean condition.
If you know your timing tab is correct and the timing looks good it could be an issue with the MSD. If you’re not sure about the timing mark loosen the distributor, rev the engine up around 3,000 rpm and hold it steady. Then move the timing back and forth to see if the engine increases with the movement. Where it revs the highest is where your engine wants the timing with the springs you have in the distributor.
If the base timing ends up being too low or too high after doing this you’ll need to play around with the springs and or the vacuum advance pod if you have one to get the base timing and the total timing where they need to be.
#1072598 - 11/29/21 10:31 PM Re: won’t idle/ running lean. [Re: 8T7AERO]
tom demarco Offline
tom demarco  Offline
Mooresville
The best test is propane enrichment at idle, put propane in the air filter area and see it the colors goes back to normal, if it does you know it is not a rich issue, it could be lean, or retarded timing but you said you where driving it for a bit and it was fine. do you have spark plug wires that can handle MSD, you did not say it was skipping so I am going to assume your wires are for MSD, I am thinking the MSD has gone bad or the distributor, or the wiring to and from, A timing light may give you an indication but that is not a solid diagnosis. If the propane makes it idle and no red headers odds are all is good with your MSD. I have seen carbs go bad and cause this issue but usually both banks. how much vacuum does a gauge say? Good Luck 18 inches is what you want.
#1072601 - 11/29/21 11:41 PM Re: won’t idle/ running lean. [Re: 8T7AERO]
88ssBrent Online content
88ssBrent  Online Content
Badss is correct in what he is saying. When I built my engine the first time I fired up I didn't have my distributor where it needed to be. Headers where so hot that it flaked off my new ceramic coating, glowing red, and melted anything and everything within 6". It was about a $600 mistake, timing is the first thing I would check. I seem to think that there might be a issue with the msd.
#1072729 - 12/14/21 05:56 PM Re: won’t idle/ running lean. [Re: BadSS]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
#1072863 - 01/05/22 01:10 AM Re: won’t idle/ running lean. [Re: tom demarco]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
#1073111 - 02/05/22 06:08 PM Re: won’t idle/ running lean. [Re: 8T7AERO]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
#1073117 - 02/06/22 12:03 AM Re: won’t idle/ running lean. [Re: 8T7AERO]
Probably late, but did you check the intake manifold for warpage? I had intake vacuum issues and it turned out the manifold was warped.
500/thumbs/Monty_ps.JPG
by 85RESTOSS
528/thumbs/ForceGeometry.jpg
by SickSpeedMonte
by Ritttzz
957/thumbs/DSC00003_1_1.JPG
by SSLANE
500/thumbs/143.JPG
by CashMoneyMotorsports
