#1072285 - 10/22/21 02:06 AM Intake manifold warpage
Buick Runner Online content
Buick Runner  Online Content
After fighting stubborn vacuum leaks, I determined that the intake manifold gaskets were leaking on both banks, especially bad by cylinders 6 and 8. Pulled the intake which is a used GM ZZ4 intake manifold and took a straight edge to it. The passenger side is pretty straight but the driver side has a .015 warpage at the 6/8 cylinder ports. Next step I guess is to measure the old intake gaskets tosee how crushed they are in various spots.
#1072289 - 10/24/21 04:24 AM Re: Intake manifold warpage [Re: Buick Runner]
Researching online about this issue I found that for V8s, the intake manifold should not be more than .004 out of flat from end to end. This means the .015 warpage I have is more than triple the max deviation.
I still have the original L69 intake in the barn. Checked it out with the straght edge and its flat. However, the rear coolant ports have pretty bad erosion and likely also requires repairs. Sigh.
#1072294 - 10/25/21 04:20 PM Re: Intake manifold warpage [Re: Buick Runner]
It's always something... Glad you got the problem diagnosed at least. Seems that is more than half the battle sometimes.
#1072295 - 10/25/21 06:26 PM Re: Intake manifold warpage [Re: Buick Runner]
88ssBrent Online content
88ssBrent  Online Content
Vacuum leaks are never fun but as Shawn said atleast you have it narrowed down.
#1072317 - 10/27/21 04:19 PM Re: Intake manifold warpage [Re: Buick Runner]
The leak didn't show up with the smoke test. Through I performed it while the engine was cold so maybe they were sealed enough when cold not to leak? Once the engine heated up the leaks became worse. Unlit torch test sure found the leaks.
#1072416 - 11/06/21 04:06 AM Re: Intake manifold warpage [Re: Buick Runner]
Finally got a replacement used ZZ4 intake. Good news is that its nice and flat. Bad news is that the bottom isn't drilled for a heat shield like my old ZZ4 intake. The replacement has the bosses for the rivet holes but they aren't drilled. Probably GM cost cutting.
#1072421 - 11/07/21 01:00 AM Re: Intake manifold warpage [Re: Buick Runner]
Glad you found a replacement - drilling and tapping holes for a machine screw with lock washer (dab of loctite to boot) isn't that bad a deal. I know you'll be happy to get rid of the vacuum leak!
#1072437 - 11/09/21 01:42 AM Re: Intake manifold warpage [Re: Buick Runner]
Bolted the intake on today, hopefully it will seal and remain sealed this time. Bought a new set of GM metal shim style intake gaskets but using RTV on the china walls. Used my old beam type torque wench as I trust it more than the clicker types. The space for the middle bolts are so tight I have to use a 9/16 U joint style socket. Not enough room for a regular socket and a separate U joint. I can see why GM changed the intake manifold bolt angle in 87.
548/thumbs/DSC004871.JPG
by 84supersport
500/thumbs/10-13-06_4_.JPG
by Monte83
500/thumbs/DSC_0024.JPG
by wanadrv
500/thumbs/DCFN0004.JPG
by madmax74
500/thumbs/Resized_Choice_1.jpg
by s10bowrider
