#1069362 - 01/26/21 06:24 PM HVAC Control Panel
tom demarco Offline
tom demarco  Offline
Mooresville
Guys
I made a "dyno" to test your HVAC control on the dash. vacuum pumps blend dors etc. If your not sure if it is broken and I can test it for you and possibly rebuilt your 9 port switch if it isn't working. Not looking to make money just looking to help. if my pm is full email me a tdemarco1@windstream.net, and if you have some units laying around, and you would like to send them to me to test or use for parts to help other guys, most of GM part numbers for these are gone or hug money If it tests well I will mail it back for shipping costs only
Tom DeMarco
#1069372 - 01/27/21 05:40 PM Re: HVAC Control Panel [Re: tom demarco]
That is awesome... I've got HVAC on my list for the next year, I think my issues are mechanical only (I think the blend door actuator rod popped out and jammed up, but I'm not sure, haven't tried to mess with it in years since none of the HVAC worked except the blower anyway), but when I dig in to it, I might be sending you one to test if the problem isn't clear.
#1069377 - 01/28/21 02:19 AM Re: HVAC Control Panel [Re: tom demarco]
Shawn, check this out too. www.montecarloss.com/SS_FAQ_16.html#4
#1069392 - 01/28/21 08:42 PM Re: HVAC Control Panel [Re: tom demarco]
That last one is similar to my issues, except for the floor/vent switch. I'm assuming there's a similar broken plastic piece, but I haven't torn into it to see... And after that, I have no idea if the rest still works after sitting so long.
#1072200 - 10/08/21 02:29 AM Re: HVAC Control Panel [Re: tom demarco]
tom demarco Offline
tom demarco  Offline
Mooresville
the heater control cable mechanically moves a plastic lever that breaks Mikes Monte has them getting the old one out no fun
#1072201 - 10/08/21 02:30 AM Re: HVAC Control Panel [Re: Hunter79764]
tom demarco Offline
tom demarco  Offline
Mooresville
Shawn the blend door actuator connect to that lever too
#1072213 - 10/09/21 02:09 AM Re: HVAC Control Panel [Re: tom demarco]
check this tech post. www.montecarloss.com/SS_FAQ_16.html#4 an good luck!
#1072249 - 10/14/21 01:58 AM Re: HVAC Control Panel [Re: tom demarco]
Ghost Car Offline
Ghost Car  Offline
Houston, TX
Thanks for this post. I was having the same problem. Opened my glovebox and slipped my into the heater box area and moved the temperature control. Found the cable and the lever arm was broke. Ordered the part today.
#1072274 - 10/18/21 09:04 PM Re: HVAC Control Panel [Re: tom demarco]
Ghost Car Offline
Ghost Car  Offline
Houston, TX
Replaced part today. Took only about 30 minutes and I didn't break anything. Instructions helped. The only thing to add is the slot of the T is oriented left - right or driver - passenger on top of the heater box. Also, I got a thin-wide blade screw driver and slipped between to box and part. With a slight upward pressure, the lever arm popped out while turning. Given this lever is plastic, I bet about 80% of our cars need replacing this part. I live in Houston, so my temp control lever is pegged full cold 99% of the time. Maybe once a year, I will turn the heat and defrost on and move the temp control to hot just to exercise the heater control valve.
#1072275 - 10/19/21 01:01 AM Re: HVAC Control Panel [Re: tom demarco]
thumbs
#1072581 - 11/28/21 02:39 PM Re: HVAC Control Panel [Re: tom demarco]
tom demarco Offline
tom demarco  Offline
Mooresville
GMHVACCONSOLERESTORATION.COM he has everything
500/thumbs/ss_update_012.jpg
by justgettinby
614/thumbs/amp_wiring_diagram_lg.JPG
by StripedSS
500/thumbs/Grill_08_resized.jpg
by IowanSS
500/thumbs/ss01.jpg
by fever53
500/thumbs/61847448412_0_BG.jpg
by monteperformance
