#1072098 - 09/25/21 10:16 PM Wheel offset and fitment question.
johnz138 Offline
johnz138  Offline
Sterling Heights, Mi
Looking at some 18x8 wheels, 4 inch backspace, 5X120.65 and says zero offset. This offset shouldn't be an issue correct?
Also with that I shouldnt have any rubbing issues using a 255 tire? Or stick with a 235 (i believe) in front and 255 in rear?
Thanks.
wave
#1072100 - 09/26/21 01:15 AM Re: Wheel offset and fitment question. [Re: johnz138]
88ssBrent Offline
88ssBrent  Offline
Type in your current wheel and tire setup and what you want to go with and it will show you the difference.
https://www.rimsntires.com/specspro.jsp
#1072101 - 09/26/21 03:49 PM Re: Wheel offset and fitment question. [Re: johnz138]
johnz138 Offline
johnz138  Offline
Thats a great site. Doesnt really tell me much about offset. The 18x8 wheel with 4" backspace will fit, but will zero offset matter? I dont think it will, but wanna be sure before clickin the order button.
wave
#1072103 - 09/27/21 01:59 AM Re: Wheel offset and fitment question. [Re: johnz138]
Zero off-set on an 8" rim would be 4.5" backspacing. 4" backspacing on an 8" rim would be -12mm. So, either they have the backspacing or the offset wrong.
Stock off-set is -6 (7" rim with 3.75" backspacing). If you use that measurement with the stock 215/65/15 in the calculator posted along with either measurements above with the tire size you want to run it will tell you how much the wheel tire combo would move in (0 offset) or out (-12 offset).
#1072104 - 09/27/21 02:37 AM Re: Wheel offset and fitment question. [Re: johnz138]
Pay attention to how wheel width, offset and backspacing relate to each other. Offset and backspacing are measured using the outside measurement of a wheel, not the bead flange. An 8" alum wheel will generally be 9" outside, + or - a 1/16" or so. A zero offset 8" wheel would measure 4 1/2" backspacing.
When choosing wheels it necessary to sometimes do the math yourself to know exactly what the wheels measurements are.
500/thumbs/MVC-012S.JPG
by hot rust
500/thumbs/carlo5.jpg
by rj
500/thumbs/hot2_2_.jpg
by blkcharlotteman
by MikePEI
500/thumbs/rims_003.JPG
by bootlegger
