#1071983 - 09/08/21 02:07 AM Decal on Purge TVS to Vapor Canister vacuum line
Ghost Car Online content
Ghost Car  Online Content
Houston, TX
From the factory, our cars came with a vacuum line which ran from the Purge TVS with a short vacuum line to the Canister Control Valve and a longer line to the vapor canister. This part had molded ends that were glued. I saved my original as a reference. Recently found some matching smooth vacuum line. I cut off the molded ends, used a box cutter to slice the inner hose and with a screw driver and needle nose pliers was able to get the old hose out of the molded ends. I glued the original ends to the new hose. Looks a lot better than 3/8 fuel line.
The long vacuum hose ran behind the AC compressor, went inside a loop holder on the driver's side fender into the vapor canister. Just past the loop, it had a white paper tag. It was only intended to identify the right part on the assembly line. I remember it had a part number without any bar code similar to the yellow tags on the transmission cooler lines.
If this decal survived on your car, please post a pic and measurements. If I know the number, I can play on the computer and make a close copy.
This is the last missing engine bay decal.
#1071985 - 09/08/21 11:46 AM Re: Decal on Purge TVS to Vapor Canister vacuum line [Re: Ghost Car]
69hurstolds Offline
69hurstolds  Offline
Aiken, SC
Those line tags are the same size and font as the Oldsmobile vacuum line number tags.
I already have what you seek.
523/thumbs/DSC_0620.jpg
831/thumbs/carlos51.jpg
by Frenzy
500/thumbs/IMAG0120.jpg
by 86 monte carlo ss
500/thumbs/466097435l.jpg
by Joe87monteSS
1191/thumbs/10391661_101613966532734_4955026_n.jpg
by DLV555
