#1071910 - 09/01/21 02:15 PM
Re: Paper sticker on evaporator box
[Re: Ghost Car]
upflying
Like this? https://www.bing.com/images/search?view=detailV2&ccid=lcs2q3xi&id=5894432E681464DBE6E7728F663A8A0853BEE8AC&thid=OIP.lcs2q3xiRBF_J0I6J5TlqgHaGY&mediaurl=https%3a%2f%2fcdn-0.gbodyforum.com%2fattachments%2f442-ecm-distributor-and-canada-shipping-decals-jpg.155333%2f&cdnurl=https%3a%2f%2fth.bing.com%2fth%2fid%2fR.95cb36ab7c6244117f27423a2794e5aa%3frik%3drOi%252bUwiKOmaPcg%26pid%3dImgRaw%26r%3d0&exph=647&expw=750&q=ecm+sticker+gm+cars&simid=607997756694668760&FORM=IRPRST&ck=D5AB2479A813622C25E2AA013412C82F&selectedIndex=4&qpvt=ecm+sticker+gm+cars&ajaxhist=0&ajaxserp=0
#1071915 - 09/02/21 02:13 AM
[Re: upflying]
69hurstolds
Aiken, SC
Like this? https://www.bing.com/images/search?view=detailV2&ccid=lcs2q3xi&id=5894432E681464DBE6E7728F663A8A0853BEE8AC&thid=OIP.lcs2q3xiRBF_J0I6J5TlqgHaGY&mediaurl=https%3a%2f%2fcdn-0.gbodyforum.com%2fattachments%2f442-ecm-distributor-and-canada-shipping-decals-jpg.155333%2f&cdnurl=https%3a%2f%2fth.bing.com%2fth%2fid%2fR.95cb36ab7c6244117f27423a2794e5aa%3frik%3drOi%252bUwiKOmaPcg%26pid%3dImgRaw%26r%3d0&exph=647&expw=750&q=ecm+sticker+gm+cars&simid=607997756694668760&FORM=IRPRST&ck=D5AB2479A813622C25E2AA013412C82F&selectedIndex=4&qpvt=ecm+sticker+gm+cars&ajaxhist=0&ajaxserp=0 Wow. Yeah, those are for an 85 442. Those are ones I had done. They're made of mylar, which isn't paper and they're water resistant. They'll last a lot longer. If I had the right codes and ECM numbers, etc., I could probably make some for those that need them. Is it CPY code for 85 MCSS? I can do something with that, perhaps.
#1071926 - 09/03/21 01:27 PM
[Re: Ghost Car]
69hurstolds
Aiken, SC
I'm going to guess yours is CDM ECM box. Something that looks like this. The stickers came in two parts, with a perforation between them. One went on the ECM box, the other went on the HVAC housing. Or should have. This only occurred on the Arlington built cars in the 84 and 85 model year, best I can find. There may be others, but I haven't seen any...good intentions I guess. Take a decent picture of yours (readable) and I can duplicate it. Even out of paper if you're daring.  But it's better if it's done in mylar (plastic). Not factory correct down to the core, but it won't simply curl up and fall off it if gets wet. And doesn't attract dirt. They're not impervious so don't wash the decals with anything stronger than mild soap/water. Or scrub them hard, and they should last a long time. If you look at your ECM box, it might look something like this: ![[Linked Image]](https://i.postimg.cc/VLC7Cm94/CDM-84-MCSS-ECM.jpg)
#1071941 - 09/04/21 04:34 PM
[Re: Ghost Car]
69hurstolds
Aiken, SC
I am going out of town this weekend and will take a look next week. For sure, I will take a picture and measure the tag. If it is loose enough to take off without destroying the decal, I will try it and scan a copy.
The first and last time that I removed the kick panel was in 1986 to put in a HyperTech chip.
Thanks. If you can simply take a readable picture of it, that should suffice.
by clyde
by Ted88SS
by FuzzyDnkn
by ls1_monte
by montess406
