Page 19 of 19 1 2 17 18 19
#1071666 - 08/18/21 01:21 AM Re: 88ssBrent's Build! [Re: 88ssBrent]
Brent you need to add in 0 bucks an hour for your labor. That something we all take for granted. Thankfully it's that labor of love that's one of the rewards, doing it your self.
Again, welcome to the MMC.
At a car show last weekend i was approached, nope, not for sale, yet. Wow, what would that number be? At a dollar an hour, need to get 20K for labor. And at 10 cents on the dollar return for all the parts, another 7K. Gotta love playing with cars.
Don't send that rain here. I spent a week playing golf in Lenoir, TN and they had some really, really nice back roads for a cruise, at speed. Smokey mountains in your backyard. Tell the weatherperson you need to drive that car to break it in, two nice weeks would be good.
#1071670 - 08/18/21 02:08 PM Re: 88ssBrent's Build! [Re: 88ssBrent]
88ssBrent Online content
88ssBrent  Online Content
I cant remember if I touched on it in this thread but I ended up adding idle bypass air to the ccc and thats all it needed and it cleared up all my issues with the carb leaning out during idle. At this point I've done quite a bit of tuning and feel that I'm pretty close on the carb. Also the smaller pulley on the alternator helped with the power issues at idle when running everything. But the whole time the manual would have solved it all, lol.
#1071671 - 08/18/21 02:36 PM Re: 88ssBrent's Build! [Re: 88ssBrent]
AkronAero Offline
AkronAero  Offline
Brent - Meant to ask you earlier - how much smaller is the current pulley (model etc?)
thanks,
#1071673 - 08/18/21 03:03 PM Re: 88ssBrent's Build! [Re: 88ssBrent]
Gordon, hope you are doing well, any luck on getting the cam changed on your car? I will have to look at my notes on the oem pulley size bit here is the pulley I purchased. If I remember correctly the oem is a 5 rib and this is a 6 rib 1 3/4". I aligned the belt and tightened like normal and everything works fine.
https://marchperformance.com/aluminum-alternator-serpentine-pulley-110-08.html
Here is a picture of the pulley compared to oem.
#1071678 - 08/18/21 08:33 PM Re: 88ssBrent's Build! [Re: 88ssBrent]
T5montecarlo Offline
Lederach, PA
Brent, are you going to put the original pulley back on since the idle speed will now remain a constant that you control?
#1071684 - 08/18/21 10:18 PM Re: 88ssBrent's Build! [Re: 88ssBrent]
Probably give it a try and see what happens.
#1071714 - 08/20/21 03:19 PM Re: 88ssBrent's Build! [Re: 88ssBrent]
Nothing but rain here for the last few days, got some clear skies and put another 20 miles on it last night. It sure is a lot more fun to drive now and with my engine combination that Kevin (Badss) dialed in on my 305 the trans really makes it shine as far as fun factor.
My ac compressor has not been kicking off and air was only coming out at around 50°so I did a little testing and I went through the flow chart in my gm manual. Said that I was over charged or a restriction in orfice tube. I had some extra cans of 134 so just to do it I discharged the system, put the vacuum pump (loaner from parts store) on for 30 minutes and sucked it down to around 29" vacuum. Let it sit for an hour needle didnt move. Weighed in 2.6 lbs (80% of r12 charge) of 134a. Got the charge in and compressor was still not kicking off low side stayed at 40 psi and high side was at 275 psi, definitely high. Outside temp was in the low 80's. Temp coming out of vent was around 45°. Ac controls blower on high ac selector set to normal. Fans were in failsafe mode so they were set to high speed. Im really not sure when this started I did notice temp was not up to par, didn't notice the compressor didnt kick off until Bob started digging into his system and I realized I hadn't heard it kicking off.
Hopefully getting close to cooler weather so I will probably ride it out for a while and do a upgrade come next spring. Parallel flow condenser, barrier hoses, variable orfice tube, new accumulator/drier, and maybe look at other compressor options. After my latest transmission upgrade I dont think my wife would be too thrilled if I said I was going to throw another $800-$1000 on my cars ac. She never really says anything but im not willing to push my luck, lol.
A few projects that I do have coming that I have all the parts for is build a dual intake air filter, I have a dui distributor tuned for my engine combo and a Bob built non ccc quadrajet that im going to give a try. For the rest of nice weather im probably just going to drive and enjoy. I still have full plans to dyno the 305 once the cold gets here and see what I can get out of the little 305 just too have a number.
#1071725 - 08/21/21 01:06 PM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: 88ssBrent]
At a cars and coffee cruise in at downtown Lenior City this morning.
#1071727 - 08/21/21 02:57 PM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: 88ssBrent]
A little video of my hooker exhaust with the tkx, im not really getting on it maybe running it up to 3500-4000 r.p.m.
https://youtube.com/shorts/msBz6P668cU?feature=share
#1071728 - 08/21/21 03:36 PM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: 88ssBrent]
Lederach, PA
Sounds great!
How does it sound at idle?
#1071732 - 08/21/21 08:40 PM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: 88ssBrent]
CM1SCW Offline
CM1SCW  Offline
Lenoir City, TN
Sorry I missed you I was in Oak Ridge at cars for canines car show. I plan on being at Napa know how auto fest Sept 4 at foothills mall may see you there. Glad you are enjoying your 5 speed.
#1071754 - 08/23/21 12:25 AM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: CM1SCW]
Sounds great!
I think its got a great idle, video really doesn't do it justice. Of course I'm not one to like a real loud car.
https://youtu.be/68evkfpB7LQ
Not a real big crowd at cars in coffee, I almost went to the cars and canines but I wasn't sure how many would be there. Looks like it had a good crowd.
#1071756 - 08/23/21 12:42 AM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: 88ssBrent]
I also need to add that im at 260 miles now, me and my wife have took 2 pretty good back road trips the last 2 evenings. The car sure is a lot more fun in the twisties and now I'm a little past half way on break in.
#1071763 - 08/23/21 10:21 AM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: 88ssBrent]
CM1SCW Offline
CM1SCW  Offline
Lenoir City, TN
Yeah, there was well over 100 cars and a good crowd of people. Large variety of vehicles.
#1071806 - 08/25/21 06:09 PM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: 88ssBrent]
Just too start figuring and planning what is everyone's experience with different rearends? It will more than likely be January or February before I can even think of spending the money but planning never hurt anything. I will actually start a new thread on this in drivetrain section as it won't be lost in my build thread and hopefully more eyes will see it.
http://www.montecarloss.com/communi...flat&Number=1071807&#Post1071807
#1071809 - 08/25/21 07:49 PM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: 88ssBrent]
AkronAero Offline
AkronAero  Offline
Brent - you are assuming we are not all hanging on each of your entries? Lost indeed!
I'm running a 383 with AFRs and getting 535 HP / 490 FtLb at the flex plate and have a significantly upgraded 200-4R (Janis Transmission).
I discussed rear options for a one time upgrade with Henderson Driveline & Axle - like Janis they are very much used by serious/pros.
He put in a 3" DOM drive shaft w/ 1350 & 3R non-greaseable Spicer U-joints. They talked me down from 3.5" or aluminum.
I asked about 12 bolt or 9" but they strongly advised sticking with the 10 bolt case for cost and time.
Nice because they got parts in advance and I was able to drive in for the day and wait.
Put in a 3.73:1 Eaton - Detroit Truetrac and Moser 28 spline axles. New bearings and seals too.
Unless I am running super stickies on the track regularly, they say this is more than enough.
I'm not used to folks talking me out of spending money - So many good ideas on this site...?
BTW - Thanks for asking about updates. Got the triangulated chassis brace (SC&C) and new front antisway bar (1-3/8" QA1 hollow) installed along with a new heater core and evaporator coil. The Comp Cam for the 383 which Kevin (BadSS - He's always volunteering help!) modeled/speced is in and the engine is back in place. Expect a very minor loss in high end HP. Lots more low end performance and with significant inc in vacuum (Kevin's est from 5 to 13+) so the vacuum pump is now gone too. Should make for a much more streetable ride. Wife is more supportive as this will make the ride much quieter so she can come along and monitor me??? Weak justification, yes, but everything helps. Finishing replumbing and prep for break-in. Been a long 9 months of purgatory with labor issues in the shop. I do what I can to help, but you are not here to do the heavy lifting so its slow.....
Thanks and keep up the posts....
#1071810 - 08/25/21 10:50 PM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: 88ssBrent]
First off Janis does good work as far as I've heard, one of my friends is a grand national guy and they all swear by Janis when it comes to the 200-4r.
Interesting that is your setup, my original plans were to stick with the 10 bolt, use the Detroit truetrac, stick with my current gm 3.73 ring gear and pinion gear, 28 spline axles, differential cover with main cap jacking bolts and weld up the axle tubes to the center section. As with most things the more I searched it seemed that approach was frowned upon due to main cap movement and teeth not being strong enough on ring gear and pinion. Of course that is reasearching on google and other forums and there is no telling what they were trying to do and you are hearing this from professionals so I will take that as an option. To add to the above I have 1330 and 3r non greasable Spicer u joints. Only the 1330 on output shaft and 3r at the rearend but using stock driveshaft just to get by at the moment.
Gordon, im glad your getting close to having your car back on the road with the upgrades it will be much more enjoyable. Any time you can find a way to justify parts in some way with your wife its a good thing. I've said many times on here that my wife has never really said anything about the money I spend but I know where the line is. If I were close to you or any other member I would be glad to help even though a lot of the times im learning as I go as seen on this forum.
#1071951 - 09/05/21 09:05 PM Re: 88ssBrent's 305 build and tkx 5 speed! [Re: 88ssBrent]
Took the car for a long ride today, the plan was to head up over the dragon at deals gap (318 corners, 11 miles). Its about 30 minutes away from my house, once I headed up 129s it was obvious that it was just to crowded and not what I planned so I cut off 129 and headed across the foothills parkway towards the smoky mountains. Hardly any traffic, about 15 degrees cooler, plenty of turns for some spirited driving , and nice views .
523/thumbs/DSC_0606.jpg
920/thumbs/100_1918.jpg
by butcher
500/thumbs/interior1_1_.jpg
by Rodney
by chocolatethunder41
500/thumbs/OldSSPlate.JPG
by SilverBullet86
