#1071077 - 06/14/21 04:48 PM EGR stem seal.
I have been trying to find a stubborn vacuum leak. Smoked the engine and saw a little smoke coming out of the stem seal at the base of the EGR valve. The diaphragm is good and holds vacuum, its leaking from where the stem enters the base of the EGR valve. Searching online has not turned up much about this issue. Only thing I found was a Turbo Buick posting where a guy found he was losing boost through a leaking stem seal on his EGR valve and deleted it.
The stock EGR valves for L69s seems to be the negative backpressure type. The cutaway diagrams I have found don't list a seal but it appears there is one in the drawing. Using a inspection mirror there does appear to be a staked washer on the EGR valve that could be a seal retainer, similar to the staked washers for the stem seals on the airhorn for the accel pump and TPS plunger.
#1071092 - 06/15/21 01:52 AM Re: EGR stem seal. [Re: Buick Runner]
to be certain of the positive or negative back pressure of your EGR valve, there will be a P or an N preceding the part number. I don't believe the stem seal can be serviced, good luck!
#1071097 - 06/15/21 05:49 AM Re: EGR stem seal. [Re: Buick Runner]
The valve has neither letter. The valve opens when I apply vacuum so its not a positive type EGR valve. My GM repair manual states most 305s have the negative type. Seems like the only fix is total replacement.
#1071101 - 06/15/21 11:46 AM Re: EGR stem seal. [Re: Buick Runner]
T5montecarlo Offline
Lederach, PA
I like to take things apart to see how they work. Try taking apart the original valve and see if there is a PN on the seal, then see if you can trace the manufacturer or replacement part number.
In the worst case, you have to replace the entire valve, which is the most likely outcome.
#1071632 - 08/16/21 03:56 AM Re: EGR stem seal. [Re: Buick Runner]
I replaced the EGR with a GM NOS unit and its stem seal doesn't leak smoke.
#1071641 - 08/16/21 06:44 PM Re: EGR stem seal. [Re: Buick Runner]
thumbs
500/thumbs/1122091338a.jpg
by 85lolo
500/thumbs/143.JPG
by CashMoneyMotorsports
500/thumbs/Z65_Paul-7.jpg
500/thumbs/IMG_1565.JPG
by T-Top Tony
728/thumbs/rearendside1.JPG
by THEmean1
