#1071221 - 06/29/21 05:43 AM Front sway bar project
As another part of the evolving suspension changes to the 86 to make it handle a little better on the street and navigate an autox course a little quicker requires gaining some knowledge about the 'big bar theory".
The suspension/frame projects have made huge improvements in the cars handling. Only the original frame and front LCAs remain and both of those have been modified. Modified front LCA relocation, rear LCA relocation, adj rear bar, springs, shocks, braces, body bushings, suspension bushings, steering linkage, the list goes on and on on all the parts changed or modified.
The one thing lacking was bigger wheels to mount a fat sticky 275/40x17 200 tire, that piece of the puzzle was recently done and made 14 runs at an autox event. Surprisingly the car did pretty good but there is still room for improvement.
Most of the CAM T cars that are fast run huge front bar rates. This is the area to concentrate my next research and project. Do some bar rate measurements, see if it's possible to install a higher rate bar using easily obtainable parts, and see if it's possible to easily swap bar rates for the 98% of the time the car spends on the streets.
For years with the basically stock suspension ran the stock 1 /14" solid SS bar. with good links.
When front suspension upgrades were done in 1999 installed an Addco 1 1/8" solid bars. Advised by Global West that was the bar i needed with their front suspension package.
After pulling a 36 mm from an 3rd gen F donor, swapped that into the car and have been running it since 09, over a decade now. I think it's a good match for the car on the street.
In my sway bar rack there is a stock 1 1/4", the Addco 1 1/8", a 34 mm F bar and a spare 36 mm F bar. One thing I have never known as fact is what their rates truely are. Very few venders of G-body sway bars advertise their bar rate, just mine is bigger and badder. So you find virtually no info anywhere on stock replacement bars rates.
First piece of this sway bar project is to build a rater and test those four bars to see what the actual rates are. About a year ago a rater was made to test several rear coil springs to use in the 86. That rater can be repurposed with a few dozen mods to check sway bar rate. I believe all those bars will test out significantly less than 500 lbs per inch, even the big 36 mm I suspect 400ish. But the rater should give me good numbers.
The stock configuration of these bars with all the twists, turns and bends make it a little difficult to get accurate measurements to plug into sway bar rate calculators. This one I found may be the most accurate calculator, it's from Fred Puhn.
http://www.gtsparkplugs.com/Sway-Bar-Calculator.html
With that calculator and rates i get from my bar rater I can end the what is the rate of that bar question.
Once I know what a 36 mm bar rate is and knowing how it behaves on the street I will be more able to apply that info to what happens if you double the rate just for a fun day at the autox.
My shop has been cooking hot, my time is kinda limited right now. The spare 36 mm bar has already been on the bench at the shop eyeballing what a rater needs to look like. The MIG is buried over in the corner, there's enough steel laying around,, incentive in short supply.
Going to schedule the Aug 7 autox event to run the car 16 more runs. Another very hot day i would suspect, this time will be prepared with copious amounts of cold water, not for me.
A new sway bar will not be installed for that event, maybe the Oct event I also plan to run. Trying to catch up on the autox time we didn't have last year. That will total about 40 runs on the car this seasons. Should have a better understanding of what the car is capable of and what to improve upon.
One thing that will be done for the Aug 7 event is a little more camber. Now have 1 1/4 degree set for my street setup. Will mike the shim stacks again and make solid shims for that street setup. Then add a shim to every location to add another 1/2 to 3/4 degree of camber. This is not a new trick, been around for decades. You can actually make a one piece shim unit for each UCA and just change them out quickly, a 1 1/4 and 2 degree drop in. Something I was going to do when doing the 9 1/2 degree caster mods to the front suspension, just never got around to it.
So begins the sway bar project.
#1071224 - 06/29/21 02:02 PM Re: Front sway bar project [Re: mmc427ss]
I'd be really interested to know the bar rates myself, same with the rear. As you said, manufacturers often don't cover the specs just bigger is better, shiney-new, etc. I did talk to Ridetech last week, their rear stock style bar is rated at 200 ft lbs, he had to look it up, now I forget the size but I think it's 1/8" larger than the stock bar I believe. Their adjustable I have the rates or can find the range online. In spring I called and asked them the rate for their new one piece front bar and their older 3 piece bar, I recall the newer one piece is rated higher but didn't write down the rates anywhere. I never could find anything on the stock bars.
#1071226 - 06/29/21 03:15 PM Re: Front sway bar project [Re: mmc427ss]
One thing to keep in mind, and Bob, I'm sure you already have a good handle on it but just wanting to state it early on for all of us to keep in mind... There's a difference between forces, moments, torques, etc on these bars. If you take the same bar and use longer or shorter arms, the "bar rate" stays the same (since it is the same cross section), but the force applied to to other wheel will be different. Longer arms should make the bar act "softer" and vice versa. That also holds for moving the point on the suspension arms that the bar connects to ((just like changing the coil spring position on the A-arm changes the overall car rate).
That is probably a good chunk of why there isn't much listed information out there. The bar cross section will dictate the strength IF the arms are the same length and mounted the same way, but the farther you get from stock applications, the less you can count on that similarity and the more likely a force measurement is needed to get apples to apples information (i.e., Bob's rig he'll be building). So unless all the measurements are done the same way and readings listed the same way, one manufacturer's ft lbs vs another's pound-feet vs another's pounds per degree are all pretty much irrelevant to each other.
#1071230 - 06/29/21 05:48 PM Re: Front sway bar project [Re: mmc427ss]
A lot of what we attribute to a "weak" bar is a too high of roll center height and vehicle that is under sprung.
an example of a very capable car with a stock style bar is the UMI Green Machine with a UMI 35MM? bar and 850lb front springs. The motion ratio of the g-body front suspension turns what appears to be high rate springs into soft wheel spring rates. I just got my full UMI Cornermax kit, in a week or so I'll have it installed and tell you how it rides. going from a 550 front spring to a 750 was an improvement, so I'm imagining going to 850 will be even better.
The other areal to look at it the amount of deflection in the poorly designed sway bar end links on these cars. I am POSITIVE we're losing spring rate through deflection with the factory style double bushing ends. I was going to modify some things and try a double ball style endlink on my existing suspension, then i decided to just buy what was is proven to work from the UMI catalog.
#1071233 - 06/29/21 06:13 PM Re: Front sway bar project [Re: mmc427ss]
Big front bars are better...WAY better... Wish I would have done mine years ago, would have saved a lot of hassles, time and expense.
I'm pretty sure I can still get all the pieces like mine from Allstar, you could build a clone. Then for daily use all you'd have to do is swap out the center bar.
Like said above though, the swing arm length is key. If you want to still go over the tie rods, you'll need a stock style 12" long arm whereas I use a 8.25" short arm that drastically stiffens my rate. You just make up for that difference with the center bar rate.
#1071243 - 06/30/21 04:46 AM Re: Front sway bar project [Re: mmc427ss]
If, when, I build a front bar is will be a fixed tube to the frame and the bar inside the tube. But as Lance said the 12" arms would need to be used. Have sourced all the parts already, torsion bars are pretty much produced from just two companies. Arm spline count is one factor limiting whose arm to used with what bar spline/length.
UMI has some links that may fit my install, rod end on top, poly stock type on the bottom.
At Carlisle this past weekend the hood was up on the Green Machine. Looking at the front bar at first i thought it was a 36 mm factory configuration, shape, bar. Looking at UMIs site they only show a 1 1/4" solid front bar for the G, 32 mm give or take. The bar on the Green Machine is their 3rd Gen F 35mm solid bar. UMI says 22% stiffer than a 36 mm hollow 1LE bar. interesting.
UMI's 71 Camaro uses their own three piece setup, 1 1/4" solid with 5 holes for rate adjustment.
Might call UMI tech and see if I can get some numbers on their bars.
It's getting the correct shape arm to fit my install which is the biggest issue.
I see the bar's arms length and shape as the big problem. On pass side the idle arm and the swaybar are side by side fighting for the same real estate. To run a short arm the sway bar would need to move rearward 4", or as Lance did mount the bar using standoffs to lower the bar, move it rearward to run a 9" arm. The arm length of stock appearing G sway bar is 13". The sway bar links and how they stay close to perpendicular as the suspension moves through full travel is important. So arm length is important to not stressing the links. When you start to get very high bar rates the load is on the links, to much misalignment can't be good.
As with pretty much all my projects they end up a little over built. When you start to look at some of the cool NASCAR sway bar setups you can see the time and effort and quality bar bearings and trick parts they use. Super strong, over built and lite weight. The bar tubes are used as part of the front frame strength. Intention is to make something similar that also adds some rigidity to the front suspension. And to simply, easily change to a lower rate bar is also required.
#1071246 - 06/30/21 01:19 PM Re: Front sway bar project [Re: mmc427ss]
Something to watch with mounting the tube up on the frame...can you still get the center bar out without removing a fender?
#1071267 - 07/01/21 02:01 AM Re: Front sway bar project [Re: mmc427ss]
Yep, that was something very necessary, Once you have everything installed it's no big deal to swap out those bars, couple bolts on the arms.
The shop was near 100 degrees today but found time to dig out some steel. A nice 7' length of 2x2 square tube, 1/4" wall. Should do nicely for the test frame. Just need to mount a pump jack/inch scale on one side and my analog weight gauge on the other.
Today took the 86 to drop off, donate, some 15x8 rally wheels my slicks were mounted on at a friend's garage. Temps in the mid 90s that black car just sucked up the heat. In the next day or so will stick the gauges on the A/C to insure it's up to snuff. Been 15 years since the R&R of the R12 system. With possible 800 miles of 90 degree driving in the very near future it's nice to have ice cubes coming out the vents.
#1071315 - 07/10/21 08:07 PM Re: Front sway bar project [Re: mmc427ss]
Hi Folks,
Just to transfer the comment here - sway bar stiffness, measured at the ends of the swing arms, goes as the inverse square of the side-view swing-arm length. That means if we double the length, the bar stiffness goes down by a factor of four, so the sensitivity is very high.
Yes, please measure all stiffnesses with the actual bushings that would be used in the actual installation.
About the front RCH, it's when it's too low, rather than too high, that makes the car roll too much. For reference, the stock front MCSS RCH is very roughly -3" to -4". The steady-state roll angle goes as the product of the car's roll compliance with the normal distance from its roll axis to its COM. Don't forget that the car's roll axis location includes the effect of tire compliance.
Also, since the discussion seems to be headed in the direction of a very stiff front roll bar, please remember that the car is very loosey-goosey and hardly reacts as a rigid body. Some years back I took a measurement of the frame's torsional rigidity between the front and rear axle CLs (attached with OE rubber bushings to the body) and got roughly 2,100 ft-lb/degree. IOW, terrible. Many modern cars, even economy models, are five times higher. Some, even thirty times. Here's an eye-popping link: http://youwheel.com/home/2016/06/20/car-body-torsional-rigidity-a-comprehensive-list/ (N.B.:1N.m = 0.738 ft.lb.)
You could make the front sway bar infinitely stiff on our cars and the abysmal lack of front-end rigidity alone would allow the car to roll.
HTH,
#1071321 - 07/11/21 07:11 PM Re: Front sway bar project [Re: mmc427ss]
Just to continue a bit about chassis rigidity - the FOM I hear most often is that the chassis should have at least 10x the torsional rigidity of the suspension. We can actually take a stab at what this number should be for a 3,800lb MCSS (this includes the driver) that rolls 2.5 deg at 1g cornering acceleration. I'll assume 1/4 of this roll angle comes from the tires, so the suspension alone rolls about 1.9 deg/g. If the car's roll axis, including the effect of tire compliance, is about 12" high at the rear axle and about 0" high at the front (I'm assuming the front of the car has been lowered from stock, which raises the front RCH,) then the car's COM height of about 21" gives us a roll moment arm of roughly 16". The total moment in roll with respect to this axis is therefore roughly 5,000 ft-lb/g. If the car's suspension is rolling 1.9 deg/g, then the car's torsional suspension stiffness is about 2,700 ft-lb/deg. Using our 10x FOM, the chassis' torsional stiffness should therefore be higher than about 27,000 ft-lb/deg. Once again, I measured a measly 2,100 ft-lb/deg, so we're lacking by a factor of about 13. This explains why stiff tires and stiff everything else basically don't play well at all with a floppy chassis like ours. Yes, the numbers might still look great on a track, but on the street, the car will ride like a Caterpillar tractor, with all due apologies to Caterpillar. Thanks, GM...
IMO we consistently attack handling and ride problems with our MCSSs from the wrong end. Fix the chassis first, and everything else will fall into line with little fuss. But do it backwards, and the car's basic design will fight us every step of the way.
The purpose of this isn't to deflect from the topic of the front sway bar stiffness, but to highlight that front sway bar stiffness alone doesn't give us the entire picture of what the car is doing in roll. We had the same problem with Project Sound at my former employer: in a meeting with MB engineers, I highlighted that active suspensions don't work wheel with a floppy chassis, and they agreed. Unfortunately, fixing that problem is hardly trivial, even at the OEM level.
HTH
#1071322 - 07/11/21 08:00 PM Re: Front sway bar project [Re: mmc427ss]
Hi Bob - back on center to your sway-bar quest - that Puhn formula does indeed take a stab at bending stiffness of the side swing arms with that c^3 term in the denominator. Because of the units, it's hard to tell whether the swing arms are assumed to be cylindrical or a rectangular solid. While the number of significant figures in the denominator term constants are unjustified, the basic form of the equation is spot-on and is as detailed as you can get without doing some actual FEA modeling of the part.
#1071325 - 07/11/21 10:24 PM Re: Front sway bar project [Re: MAP]
HTH,
Coming from someone that has tested this theory extensively...and has the track time and video evidence along with the seat of the pants feel to back it up...these cars with their 57-58% front weight bias love a 1500ish pound front sway bar.
My car (which regularly sees 1.3 lateral Gs) stopped lifting the inside rear tire on corner entry when I put my big front bar on. This alone made the car tons faster on course and easier to drive.
Bob's car is like mine, the front grip is great. More or less roll is not going to change it's front grip much, but less front roll is most certainly a great way to fix the rear grip loss that Bob's car is experiencing now. Undisputedly... And with basically zero side effects as well.
#1071332 - 07/12/21 06:29 AM Re: Front sway bar project [Re: mmc427ss]
I said that infinite bar stiffness would still allow the car to roll; I didn't say how much - I'm guessing 0.5-1.0 deg, not counting the rear's roll stiffness contribution.
My point about the car's poor torsional stiffness supplements the discussion about the front sway bar; it doesn't negate its inherent attributes.
#1071463 - 08/01/21 01:27 AM Re: Front sway bar project [Re: mmc427ss]
Have been a little busy with getting a working A/C system back in the car, so no progress on deciding what to do about a front bar upgrade. In the near future will get back to building a bar rater to test 4 commonly used front bars. Have shopped all the suspension parts venders who sell a front bar for a G to see what they offer. Typically their big bars are around 400 lb per inch and a couple bars are high 5s and UMI comes out the winner with their 3rd gen F bar at 618 rated. The steel type used (materiel), bar OD and hollow verses solid are the choices. Pretty much all will have the same shape so just bar OD and hollow or solid determine the winner. UMI bar is 35 mm solid and isn't sold for a G, it's sold as an F part. But we all know front G and F bars are interchangeable. The brackets that hold the bar to the frame are different though, gotta use a G on a G and an F on a F.
My guess is the 36 mm hollow F-body bar which I have run for years is in that 400ish+ range. So looking for a lot higher rate bar would need to be a three piece.
Building a three piece bar requires sourcing several parts which may be a little more difficult these days. A three piece has it's arms splined to the torsion bar. There is no bolt-in 3 pieces bar available today for a G, you need to buy a bunch of parts and make them work on your car. Just makes the project a little more entailed.
I get the torsional chassis stiffness thing and how much it impacts handling. But for years haves made numerous subtle changes to improve the noodle. In the end it's still about polishing the turd and it's the turd I chose to drive. Pretty happy with the marriage of the body and chassis after all the mods.
Last time the car was scaled was years ago, 58.75 front, 41.25 rear, nothing to be proud of. Every time I turn around seems another lb or two gets added to the front end. And no plans for any car diet to lose 100 pounds. With a slightly higher CG run on the car due to needing a little higher ride height, and ALL that weight over the front tires, and knowing front roll angle is more than wanted, it makes the monster front bar install look like something I need to do just find out for myself what it's all about. Already can see, fell the drawbacks out on the crappie intersections.
The biggest reason to try one is see if a huge up front bar can really help the rear tires. Less roll in the front should mean less roll in the rear. It's a follow the leader game.
The prime goal of my suspension mods lately is more rear stick, it has always been the problem child. The newly installed Falken RT660 were a major improvement front and rear, just looking for more yet without cutting the car to do rear roll center changes.
#1071464 - 08/02/21 01:09 AM Re: Front sway bar project [Re: mmc427ss]
Hi Bob,
To minimize weight, definitely go with a hollow bar if you can get enough stiffness out of it. To say that differently, for the same stiffness, a hollow bar will always weigh less than the equivalent solid bar.
Yes, with a front-heavy car, and even with a lot of floppiness in the chassis, I can see where a stiffer front bar in the front is generally going to help. I say that not only theoretically but from direct experience as well.
#1071466 - 08/02/21 02:03 AM Re: Front sway bar project [Re: mmc427ss]
You and Cory should work together on this Bob as he's now convinced one is in his future as well. Can't wait to see you and your car in a couple weeks...
#1071471 - 08/03/21 06:12 AM Re: Front sway bar project [Re: mmc427ss]
When I saw Cory at KOTM he was busy, a very short conversation.
Bill, me and the car will be there. But i will tell you the old 16" Comp tires and old wheels will be on the car, not the new setup. That's a 550 mile trip for the car and can't see a reason not to wear the old tires and save the new soft Falkens for autox.
#1071575 - 08/13/21 07:49 PM Re: Front sway bar project [Re: mmc427ss]
Hi Bob,
OK, taking this back to essentials, I'm getting that you want more roll stiffness in the front in order to keep both wheels in the rear in better contact with the pavement.
You could do this by lowering rear vertical stiffness at each wheel, through some combination of reducing rear roll stiffness via the sway bar and reducing rear spring stiffness.
But you're doing it instead by increasing front roll stiffness.
I know you spent a ton of digital ink talking about how you optimized your rear suspension, but for the sake of clarity going forward, could you summarize in a couple of sentences why you are where you are?
This isn't necessarily to question the configuration, but a clear answer could better inform where you're going with the front suspension. For example, you could just as well increase front roll stiffness by using stiffer springs rather than a stiffer sway bar.
#1071591 - 08/14/21 02:00 AM Re: Front sway bar project [Re: mmc427ss]
Funny you mention front springs.
We have a Dingo 5 hp yard cart at the shop, knobby tire thing. My 12 year grandson tore up the back acre earlier this week. While me not paying attention my 8 year grandson videoed the 12 year old cornering on two wheel around a big Chestnut tree. A projecting bump in the soil under tree he hits while turning and it's both inside wheels 12" of the ground. Of course my 8 think Pop needs to see it right away not knowing Pop would put an end to that foolishness instantly.
The cart back in the shop and note the front coil springs are broken, collapsed and doing nothing. I've hooked that same tree a dozen times and never had an issue. Those coils are only 15/16" OD, 2.25" long and .125 wire, not a lot of rate. Thinking when the 12 was hitting that bump with no suspension the front just got shocked light real quick and the rear tire followed suit.
Picked up a new spring coil to cut and fit to the cart today. Will mostly be a fit and rate check thing. The car is over 20 years old now, didn't shop for an OEM spring, maybe later.
For my car being near 700 lb up front now adding more rate is easy, even GM had a 1000 pounder in the part catalog for the 3rd Gen F way back then.
But as we know something will suffer, my butt ride quality meter will be able to tell.
I feel anything you do to improve cornering is a trade off in these cars, ride, or handling.
#1071596 - 08/14/21 04:03 AM Re: Front sway bar project [Re: mmc427ss]
If we look at an axle's bump time input, we could call the right side R(t) and the left side L(t). We could decompose these into common-mode CM(t) and difference-mode DM(t) signals as CM(t) = (R(t)+L(t))/2, and DM(t) = (R(t)-L(t))/2. Then, going backwards, we could say that R(t) = CM(t) + DM(t), and L(t) = CM(t) - DM(t). This is exactly how electrical signals are composed/decomposed for differential amplifiers in the electrical domain.
OK, the purpose of this is only to show that springs affect both the CM(t) and DM(t) responses, while sway bars only affect DM(t). So, springs make the ride stiffer for all kinds of bumps, whether seen as common-mode or difference-mode, while sway bars make the ride stiffer only for the difference-mode. So, for a given desired roll stiffness, a stiffer sway bar will make the car ride moderately stiffer, but stiffer springs will make the car ride stiffer yet. To repeat, this is for the same target roll stiffness.
I agree it's all a trade-off, as is true about 98% of the time in engineering virtually anything. But in the case of the A/G body design, we're unusually poorly handicapped. That's why I'm always talking about removing the handicap. I know that sounds near-impossible to do, but when you look at all the mountain-moving effort we exert to try to "polish the turd" as you say, it's not as infeasible as it seems. Too bad you wouldn't be open to an EV conversion - it solves an impressive array of problems in one fell swoop.
#1071610 - 08/14/21 09:24 PM Re: Front sway bar project [Re: mmc427ss]
Hi Bob,
Just to carry the conversation a bit further...
1. About being open to an EV conversion, I already know how you'll respond, so I'll say pre-emptively that I fully understand and appreciate the reasons. Too bad we can't turn back the clock 10 years and have $100k magically fall down from the sky. Even so, if you could add up all the time and money dealing with this and that A/G body issue over the years, and assign a reasonable value to your time, I don't think $100k would sound crazy anymore.
2. Again, what I'm hearing is a desire to keep both rear tires in contact with the ground for a greater fraction of your driving time, or at least your auto-xing time. I return to the question, why not reduce rear roll stiffness? I think you answered that somewhere in the multitudinous multifarious manifold multiplicity of multiplied millions of words you've written in your "Rear spring options for handling" thread, but for the benefit of those with less-than-perfect memories, like me, could you summarize the reason(s) here? (That's a friendly stab, not sarcasm!)
Just trying to help.
#1071638 - 08/16/21 05:31 PM Re: Front sway bar project [Re: MAP]
Hi Bob,
I'll take this one as I've tried just about every method available to do just this. There are two ways to accomplish this using existing roll center heights and several others using altered RCHs.
First off using existing RCHs a stiffer rear sway bar or stiffer rear springs are your choices, the stiffer rear sway bar just lifts the inside tire and makes everything worse. The stiffer rear springs work pretty well actually and I had great success with high speed cornering Lateral grip with 600# rear springs in the car. The downside to that setup that I eventually decided I just couldn't live with any longer is reduced weight transfer to rear tires under acceleration which resulted in excessive wheel spin. Switching back to a 250# rear spring greatly helped in weight transfer and added rear forward bite, enough so to more than make up for the loss of a little lateral grip. Adding an adjustable soft rear sway bar back in the mix fine tuned with some shock adjustments tailored the rear lateral grip to "acceptable" form for me. The huge front sway bar actually made the whole setup have better rear lateral grip than the 600# spring setup I ran before.
Going down the "adjustable rear roll center height" rabbit hole is an option and I know several friends that are working on this setup now in their G Bodys. I choose to sit back and watch and see how they do first as it can be a daunting task to do correctly and I want to see if the results are as magically as some claim before making these changes to my car. I am going to need to see a 3 link rear perform better than my current setup on track before deciding for sure to try this. The few that I've ridden in, driven, and watched race haven't convinced me yet that it's worth the trouble but I remain hopefully someone will hit on something.
#1071645 - 08/16/21 10:05 PM Re: Front sway bar project [Re: mmc427ss]
Hi Lance,
Let me try to parse your answer:
1. "First off using existing RCHs a stiffer rear sway bar or stiffer rear springs are your choices, the stiffer rear sway bar just lifts the inside tire and makes everything worse. The stiffer rear springs work pretty well actually and I had great success with high speed cornering Lateral grip with 600# rear springs in the car."
So stiffer rear springs help but a stiffer rear sway bar doesn't. Since both methods raise rear roll stiffness, then rear roll stiffness tuning alone isn't the whole answer to the problem.
2. If springs are affecting rear bite under longitudinal acceleration, then that's a consequence of anti-squat or anti-lift, in addition to the springs. So adjusting the side-view instant roll center location can help or hurt that significantly. The stock rear design is 25% anti-squat as I recall, but with a live axle, it's easy to get that above 100% so the rear of the car lifts instead of squats under acceleration. And if the rear lifts, then the upward force required to generate that lift is seen as a downward-force reaction at the tire patches which increases traction.
So, combining lateral and longitudinal aspects of rear traction with a front-heavy car, there are now at least three tools for the rear instead of just two: springs, sway bar, and anti-squat. Shocks have a transient effect and so that's somewhat a separate discussion.
About the rear RCH, on a flat surface, there is little consequence. High RCH makes the rear "bite" laterally faster than a low RCH, so that steering response feels more instantaneous and synched between front and rear axles. With a low rear RCH, the rear needs time for car roll to cause lateral weight transfer to be communicated to the rear tires so that appropriate slip angles are generated and the rear develops its full lateral grip. In other words, with a low RCH in the rear, the car has a distinct "1-2" steering response: front first, then rear roughly 1/4-1/2 sec later. With a high rear RCH, it feels like one immediate hit, so the steering response is sharper.
On the street is where it gets a lot more fun and interesting, and where the low RCH really shines.
Back to Bob's quest: increasing front roll stiffness should accomplish nearly the same thing as reducing rear roll stiffness. Bob, it's certainly your prerogative to keep the discussion restricted to measuring and then selecting the correct front bar, but that's likely to cost money and even more weight on the front axle. Beyond this, the car will roll a bit more with the second option, but we're probably only talking a fraction of a degree, and even then, through playing around with caster and camber in the front, you can more than compensate without undue ill effects. Given the excessive front caster you've got plus what you've done with camber, you're probably fine as you are - HTH.
#1071648 - 08/16/21 11:02 PM Re: Front sway bar project [Re: mmc427ss]
He just needs more front sway bar... laugh Like a LOT more...
#1071649 - 08/16/21 11:07 PM Re: Front sway bar project [Re: mmc427ss]
So, how do you know?
#1071655 - 08/17/21 12:11 PM Re: Front sway bar project [Re: mmc427ss]
Direct personal experience...
I have felt many times over the exact ill that Bob now feels with his car when on course, and more importantly I have felt exactly how a much stiffer front bar corrected that ill.
#1071658 - 08/17/21 06:36 PM Re: Front sway bar project [Re: mmc427ss]
Mark, apologize for not responding. Have been to caught up in the current issues with A/C and cooling system plus the other life events to have time to think about the front bar.
But one thing is do understand is how Lance with a 1000 autox runs under his belt has a pretty good idea what works to make these cars better. Not saying his parts choices are the only choices just that he has run a lot of combos looking for the best for the old turd. And his car is very competitive with other Cam T cars. If looking at that class of cars dominated by old live axle rear suspensions iron huge front bars seem to be one of the ways to make them much better in the autox.
Not saying they are better when used for street duty, just they do seem to make a difference on track.
Being I'm running out of time as a competitive driver, 7th decade is underway, and actually events to run what ya brung for testing being less it's hard to evaluate your setup. So you take suggestions, see if they are a viable choice and make a decision if you want to go that route.
I can say what I've heard time and time again, tires, tires, tires, make the biggest improvements. The RT660 Falkens are noticeably a big improvement.
Oh, bought a front spring for the yard cart at the local hardware store. Cut it in half and get two new springs, same OD, same wire size, correct length, $3. 89 well spent. Ride and handling much better without a floating spindle.
#1071660 - 08/17/21 07:50 PM Re: Front sway bar project [Re: mmc427ss]
Lance - Got it. And I'm not even slightly disputing that. What I am questioning is whether that's the best, or only, solution to the problem.
I can't even begin to count the number of times in an engineering setting where people jumped to conclusions and fell into the trap of OFAT (One Factor At a TIme) thinking about solving problems. Questioning concepts down to first principles yielded better results, along with multiple-factor thinking, as embodied by the philosophy of DOEs (Shawn, if you're reading, I'm sure you're getting this.) But you folks aren't engineers - I get that too.
So, Bob, I'm pretty sure a stiffer front bar will get you better results. If that's enough to float your boat, and yes I do understand the pressure of time at this stage of life, then I genuinely wish you the best with that.
#1071663 - 08/17/21 08:45 PM Re: Front sway bar project [Re: mmc427ss]
There's definitely something to be said for taking a systemic/holistic approach for design, but there's also a lot to be said for optimizing a system based on correcting the biggest offender and picking off the lowest hanging fruit at each step, wherever you are in the process. More like Continuous Improvement vs R&D.
I'd love to have the budget for R&D efforts, but taking the "Thousand Dollar" approach of spending $1000 to fix the biggest problem you can seems to be the more common route, personally and professionally, for me.
#1071664 - 08/17/21 09:22 PM Re: Front sway bar project [Re: mmc427ss]
Not quite the answer I was expecting but that's OK. I'm not talking outside the bounds of correcting the biggest offender, and I'm not even talking outside the bounds of a small budget (aside from a very short but worthwhile excursion into the benefits of electrification.)
But I am talking outside the bounds of small thinking.
#1071672 - 08/18/21 03:01 PM Re: Front sway bar project [Re: mmc427ss]
Sutton used to always ask me what my limiting factors were, or more importantly what were my sacred cows that I wasn't willing to part with in order to achieve greater track results.
You sometimes have to pick your poison when trying to make a street car act like a racecar. One of my limiting factors then and still today is the desire to not completely rearrange the rear suspension geometry and style on a whim. Packaging is tough under there and trying to keep full exhaust tucked as well as ride height where it is complicates matters even more, not too mention the immense amount of fabrication and parts that would be required to do it the way I think would be necessary to achieve the results I would want.
I may get there someday, we'll see. Right now I seem to be way more interested into personalizing my new truck and making it better so the car just sits waiting for race season to start up once again.
I just wish I would have tried the huge front bar WAY earlier instead of fifteen other types of bandaides...that would have saved me 5 years worth of headaches and not too mention cubic dollars. My desire to help others in similar situations is the only reason why I keep preaching this. I know of at least 4 other G bodies currently competing that would LOVE the results of a 1500# front bar...maybe one day some o them will try it as well.
#1071677 - 08/18/21 08:18 PM Re: Front sway bar project [Re: mmc427ss]
Well, as I said before, the larger front bar will almost certainly get the job done. I've already gotten on my soap box about other options so I'll let it lie. I'm amazed at the hoops we force ourselves to jump through in order to make a front-heavy car handle well.
Increasing front roll stiffness, along with having most of the car's weight on the front axle, puts the overwhelming burden of cornering acceleration on the outer front tire. This is fundamentally a recipe for understeer and reducing the car's lateral grip. Yes, you can use other factors to compensate, but it's not the quickest way around a corner, even if you're already at 1.2-ish g or whatever. That's one of the main reasons why that Tesla 3 beat you and everyone else, Lance.
Btw, "1500#" is only half of a (presumed stiffness) specification. What's the other half - e.g., per inch of deflection at the end of a swing arm on the sway bar?
#1071685 - 08/18/21 10:47 PM Re: Front sway bar project [Re: MAP]
mrengineer Offline
mrengineer  Offline
The D, MI
There is another option that I am frankly surprised does not get mentioned more often. You can easily remove about 150lbs off the front end by going with an LS and trust me you will feel the difference.
Mr. Engineer
#1071698 - 08/19/21 04:15 AM Re: Front sway bar project [Re: mmc427ss]
I couldn't agree more. Just switching the battery from the engine bay to the trunk was instantly discernible, and that was only 40lb.
#1071699 - 08/19/21 01:02 PM Re: Front sway bar project [Re: mmc427ss]
My left front is already heavier than the right front, removing weight from the right front by relocating the battery would only make that worse while at the same time make the cross weight ratio worse as well. There are times and certain courses where my car gets noticeably faster when I put a 150# passenger on the right front seat. Lighter is not always faster.
There are also plenty of real world examples as of late where guys have put smaller width tires back on their cars and went faster as well. I suppose there is an engineering formula for the amount of weight pushing down on a tire vs tread width for finding maximum grip but I'll stick with what I see actually working for people on course who are going faster.
#1071703 - 08/19/21 07:09 PM Re: Front sway bar project [Re: mmc427ss]
mrengineer Offline
mrengineer  Offline
The D, MI
Great reference for all.
I recommend this book to every Formula SAE team when doing tech inspections. If you want to run fast, this book will help you understand what it takes.
Fundamentals of Vehicle Dynamics R-114, by Thomas Gillespie
https://www.sae.org/publications/books/content/r-114/
Mr. Engineer
#1071704 - 08/19/21 07:42 PM Re: Front sway bar project [Re: mrengineer]
Cory Carstensen just corner balanced his recently LS swapped G body and the weights came out very similar to what they were before with his SBC. His car is a bit different than mine as it has no AC and is a T-Top car but here's his scale sheet (includes driver weight).
This was mine when I weighed it recently also with driver weight.
#1071705 - 08/19/21 10:04 PM Re: Front sway bar project [Re: mmc427ss]
Some interesting points:
  • Crossweights and such: a car is a three-dimensional body. Front-to-back weight distribution is only one dimension. There are two more to play with. I never think in terms of crossweights because I find it unhelpful. I get all I need from comparing all four weights and looking at F/R, R/L symmetries. It amounts to the same thing, but is more direct.
  • LS conversion and essentially the same weight: if the motor reduced weight, then something else added it back unless we find a way to violate physics. That, or the swapped LS engine had an iron block. A 150lb weight reduction would be for an all-aluminum engine like the LS-7.
  • Lateral maximum friction / normal loading: the lighter the load, the higher this ratio; the relationship is monotonic. Tires don't obey Coulombic laws of friction. If they did, tire width would make no difference.
  • Narrower tires in the back make the car faster in corners: with a front-heavy car, no surprise. Narrower tires increase slip angle, so doing that at the rear reduces understeer.
Lighter is always faster when properly balanced. Correcting an imbalance by adding weight is always a sub-optimal solution. It's like taking a dish of spaghetti with too much sauce and adding more spaghetti to restore balance. Someone will get heartburn...
Mr. Engineer - thanks for the link but the price of entry is high. Great book with a great reputation. I have RCVD by Milliken and that answers most of my questions: I hope there's significant overlap here so I'm not missing too much by not getting this book (?) "I recommend this book to every Formula SAE team..." Sometime you'll have to tell us more about yourself.
Also, you'll understand that when I speak of weight, what I'm really referring to is the entire inertia tensor.
Bob - if you're still reading, I hope this doesn't discourage you in any way in your sway bar efforts! All the stuff I'm talking about is kind of second-order for you; just ignore it if you don't find it helpful. smile
Everyone - I wish I could take you all into this hypothetical situation: you're doing some enthusiastic corner-carving in your MCSS, and suddenly, I remove 400lb from the front end while conserving ride height. I predict you would be so gobsmacked floored with the improvement in handling that you would think, "Why on earth didn't I do all I could to reduce front-end weight before all of those years of band-aiding the problem?"
#1071712 - 08/20/21 01:33 PM Re: Front sway bar project [Re: mmc427ss]
I wholeheartedly agree that taking 400#s off the front of these cars would make them much faster on track.
The surgery and sacrifices needed to do that though are unrealistic for most of us that still use these as street cars also. Whereas adding a big stiff front sway bar is still pretty street car friendly.
Regarding vehicle dynamics engineering...this is what I've run into over the years but realize my experience is pretty limited on that kind of research. Most of the examples and data that I've read regarding handling, lateral load transfer, front vs rear grip and neutral balancing are all done and practiced on vehicles that were designed to handle in the first place. I've yet to see any engineers try to use math to get a 57% front heavy car to handle. Does that mean they can't get those cars to handle also or just that they've never tried?
My personal extensive experience in doing just that proves that it can be done fairly well but does take a bit of a different approach than what most of the books say. The difference is. I don't say they are wrong, I just contend that I've found a different way to skin that cat that works pretty well also. What I've also found (by real world on track experience) is that a lot of the "rules" that are used and applied on the books don't really apply to a setup like mine. For instance, a huge front sway bar will induce understeer...that just flat out hasn't ever happened...even though the books all say it will. My point is, yes it's unconventional but it also works pretty damn well and reality and practice is actually much easier than trying to confirm these cars to the type of vehicles the books say to use.
Oh and Mark, I've seen guys put smaller tires on the front of our big front heavy cars and go faster. More weight on a smaller contact patch actully pushes the tire harder onto the surface and creates more grip. I watched racers learn this first hand when Good Guys limited front tire size on a lower class couple years ago so racers went from 315s on the fronts back down to 275s to get into the lower class...and they went faster...not slower than before. When they win an event, they get bumped up a class anyway so theoretically they could put the 315s back on but several guys I know stayed with the 275s anyway.
Again, first hand on track experience...using out of the box methods.
#1071717 - 08/20/21 04:34 PM Re: Front sway bar project [Re: MAP]
I want to explain a situation that I've been in often on course to help make my point about adding a passenger to help get faster. Our cars are NOT properly balanced and they will never be in their current form. They are ALWAYS left side heavy unless there has been a ton of surgery done. When we have a course that has an overabundance of right hand turns or one or two very critical long right handers...my car will most certainly be faster overall with a 150# passenger in the right seat. 100%...every time. Like a LOT faster... Like the difference between winning an event or finishing third faster.
The mod of putting a passenger in the right seat is WAY easier than removing 150 pounds of fixed weight from the left side of our cars. Plus, it's more fun for both the driver and the passenger.
We are allowing guests at our autocrosses again this fall Mark, I can't wait for you to come up for an event and go for a ride-along with me.
2021
Sept 19 Sat
Oct 16 Sun
Nov 13 Sat
Dec 12 Sun
2022
Jan 16 Sun
Feb 12 Sat
Ma 12 SAT and Ma 13 Sun (Two day event)
Ap 23 Sat
Sept 18 Sun
Oct 22 Sat
Nov19 Sat
Dec 11 Sun
#1071718 - 08/20/21 08:24 PM Re: Front sway bar project [Re: mmc427ss]
Thank you, Lance. Much appreciated. I'm not planning any trips to PHX soon, but looking to move possibly to Tucson. Housing prices are over-the-top crazy right now in all of AZ; looks like the tidal wave from CA is responsible at least in part...
With a sole occupant in the car, yes, the car will always be left-heavy. The factory designed the car to be kind-of L/R weight neutral with a certain cabin load that one must assume was not just a single occupant. If I were building an MCSS now, and knowing that about 99% of the time I'd be the only person in the car, I'd shift a lot of weight (read: battery weight) to the right to give me nominal L/R parity.
Yes, if you start left-heavy, adding weight on the right will probably help. But it's still not the optimal solution; heavy surgery is.
None of what I'm proposing to do is easy, but again, when you look at all the compromises and contortions and struggles we go through to "polish the turd" as Bob likes to say, in the end I think radical surgery is best and probably the path of least total resistance.
But do it at the beginning of a project, not at the end. That's why if I had a blank-sheet MCSS on my hands right now, the first order of business would be the radical surgery. A good rolling chassis that needed a paint job would be the best starting point. I'd lower it a bunch and widen it to conform to the width of a Tesla S/Y or thereabouts. Unibody conversion, of course, to maximize chassis stiffness in relation to weight.
#1071742 - 08/22/21 03:26 AM Re: Front sway bar project [Re: mmc427ss]
mrengineer Offline
mrengineer  Offline
The D, MI
You guys are going to force me to look up the weight delta between LS w/ iron block vs. SBC, asm as shipped. I have a detailed comparison somewhere, but from what I remember it's approximately 150 lbs. Also, G body w/LS, non AC & w/t tops weighing the same as Lance's....... does not sound right. Devil is in the details when comparing weights. And MAP, my kids cheapest text book for school was about $180 in 2019, books ain't cheap!
Mr. Engineer
#1071752 - 08/22/21 10:06 PM Re: Front sway bar project [Re: mmc427ss]
Lance, somehow I didn't see your post 8/20/21 1:33PM (1071712) until now.
Addressing that: Stiffer front bar versus heavy surgery - of course, the stiffer sway bar is a couple of orders of magnitude easier. I'm not saying anything to the contrary. What I am saying is that when you add up all the years and dollars and head-scratching and digital-ink spilling and GoPro recording and consultant consultations and autocross testing and trying this, that, and the other thing and then the other, other thing, and then the other, other, other thing, you could have been ahead by this time doing the heavy surgery at the beginning. That's what I'll certainly do once the opportunity presents itself.
"I've yet to see any engineers try to use math to get a 57% front heavy car to handle." Nonsense. Engineers do it every day, but mostly with FWD. Today, I don't think any OEM in their right mind would design RWD with 57% of the vehicle's weight on the front wheels. GM might have gotten away with it back in the 70s and 80s, but the base model in this case was a vehicle designed for transporting families in comfort. (The Fiero was a curious exception in several ways.)
Huge sway bar and less understeer: in an A/G body, decreasing body roll does a bunch of good things that reduce understeer such that increasing front lateral weight transfer at the front with the stiffer bar relative to the rear, can still result in a net reduction of understeer. Further, we're often surprisingly insensitive to how much our cars may be understeering. Taking a corner faster than before tends to make a much bigger impression, from which we may falsely (or rightly) conclude that our cars are understeering less. Did you ever test your car?
"More weight on a smaller contact patch actually pushes the tire harder onto the surface and creates more grip." If you mean the same weight on a smaller patch, contact pressure goes up, but the tire isn't being "pushed harder" into the pavement. Provided that the contact patch area is relatively conserved as a function of tire loading, grip will go down, not up. A narrower tire may still corner a little faster if there's a significant camber problem. Basically, wider tires are more sensitive than narrower ones to tire verticality. But mismatches between tire width and rim width can be exploited to cancel camber errors to a certain extent - in the case of positive camber, using a tire that's narrow in relation to the rim can be helpful.
I know it's tempting to think that if a set of solutions works on the track yet theory says it shouldn't, then the theory is wrong. Far more often, the truth is that the theory is simply incomplete or only partially applied. In 1933 Einstein said, "It can scarcely be denied that the supreme goal of all theory is to make the irreducible basic elements as simple and as few as possible without having to surrender the adequate representation of a single datum of experience.” Or, as it's often misquoted, "Everything in the universe should be as simple as possible, but no simpler." The problem I've seen nearly every time in my engineering experience is that we oversimplify. I think we're seeing that here...
So, Lance, you've done amazingly well with the tools at your disposal. No one's denying that. But you haven't achieved the last word in what's possible, and that's where you'll need theory.
Mr. Engineer - yes, I know about crazy-expensive college textbooks. That's a captive market that's often unfairly exploited in my opinion. But no matter the market, that Gillespie book is too rich for my blood at the present time. But I repeat, I'm assuming RCVD can tell me all I need to know? I do have that book. Also, an LS-7 relative to an iron-block SBC-1 with aluminum heads is about 130lb lighter as I recall - I'm guessing that's where you're getting 150(ish) lb. The presence, or not, of various accessories may be obscuring the true weight difference.
#1071770 - 08/23/21 04:44 PM Re: Front sway bar project [Re: mmc427ss]
I don't have scales to back anything up, but I went from a 4.3 all-iron V6 to a 5.3 iron block/aluminum head/plastic intake V8, and my soft front springs stayed the same, if not possibly sit a little higher. If you are starting with an SBC with aluminum heads and intake already, there is less difference when keeping the iron block, but otherwise there should be a noticeable difference. I've researched to see how much, and it is amazingly difficult to get reasonably accurate weights on engines, especially apples-to-apples with accessories etc included.
#1071783 - 08/23/21 09:29 PM Re: Front sway bar project [Re: mmc427ss]
Over the years I'd had many engineers tell me that "by theory" what I've done will never work. I guess I just look at things differently because I'm out there wrenching on my car, then racing it, figuring out what doesn't work to my liking, then wrenching on it some more, until I get it like I like it. I've learned a ton along the way about suspensions and how to make them work as well as how to drive to best suit that day's setup. It takes the whole complete package to be near the top of the charts these days. I know that target is getting harder and harder to chase these days especially with our handicaps, but that doesn't mean we still can't have fun nipping at their heels in our old luxury cruisers.
Fall of 2019 at Good Guys in Scottsdale, I was on my small 275s on my big, fat, front heavy, street car and I had ALL of the Speedway Motors team with their professional drivers and their team of engineers scratching their heads because I was 5th overall on the speed charts and ahead of all of their cars and drivers except for Al Unser(and I was only about a half second off of his time).
I'll never forget watching them send one engineer over at a time to walk past my car, bend down to take a look under and feel my tires to see if they could figure out what I was doing to be so fast. It was awesome!! By Saturday the majority of the fast guys had worked their way back up the charts and things were "more normal" but I was still ahead of two of the Speedway drivers (one was Mary Pozzi if that rings a bell in a 600 hp 68 Camaro). Two of the cars that got past me...did it by bolting smaller tires on if you can imagine that. There were circumstances that day that just worked in my favor and I was able to take advantage of them...it happens.
I know this, I'm not going to try to tell the engineers reading this that they are wrong...but I am going to keep sharing what I KNOW works with those that I feel can take advantage of my experiences and learning at the school of hard knocks. I KNOW that if Bob welded a front sway bar similar to mine on his car, he'd have a hard time getting the grin off his face after his first run on an autocross course with it. It's life changing...and not that hard to do with hardly any side effects. If I would have done it 5 years earlier, it would have saved me a TON of years and dollars and head-scratching and digital-ink spilling and GoPro recording and consultant consultations and autocross testing and trying this, that, and the other thing and then the other, other thing, and then the other, other, other thing... Just saying...
#1071850 - 08/29/21 07:50 PM Re: Front sway bar project [Re: mmc427ss]
That's all fine, Lance. There's no motivation to attack. Only to learn what's really happening down to first principles which oftentimes can be a nastily difficult thing to achieve.
So, you say you know x,y,z. Bob will copy/paste x,y,z and will probably get great results. But are those results truly the best? Almost certainly, no. I repeat that a Tesla 3 beat you and the whole rest of the group - that's one powerful existence theorem. Even so, if copying/pasting x,y,z puts a grin on your face and makes you happy, then have at it and enjoy it to the fullest. But there's still more - there's always more - on the table.
You said engineers couldn't figure out why you do as well as you do, but this is based on what - a five-minute exterior judgment? I doubt that they said what you do "couldn't work," but that it was improbable that it could work as well as it does. A deeper dive will always reveal why, and from the why, we will always learn ways to improve even more on what's already been achieved. You have not re-invented the wheel, Lance, although I'm not saying that you haven't done very well.
(Btw, one more question about the stiff front sway bar and going faster around turns. Is this while coasting the throttle, or while applying throttle to accelerate? What about braking while turning? The answer could exert a powerful influence on best front/rear roll stiffness balance. Basically, the more we're asking the rear to longitudinally accelerate a front-heavy car while turning, the less rear roll stiffness we want. That maxim should be etched in our frontal lobe...)
About what you could have done five years ago or however long it's been since you bought your car, there are other things you could have done that would have likely helped you even more than just using a very stiff front sway bar. Usually, at the start of a complex project, we vastly underestimate its difficulty and cost, and thus relegate too many options as being inviolable "sacred cows." Then we rue the fact years later after struggling so hard to work with just the un-sacred cows. I know you've dug-in your heels too far to want to admit it, but if you had started with an LS-7 years ago - another sacred cow - I contend that you would have been ahead by now.
I will repeat, as I have over the years to hundreds of engineers, never underestimate the power of questioning assumptions at the level of first principles.
(Bob - I've done a lot of talking on your dime. If you want me to stop, just let me know. Thx.)
523/thumbs/DSC_0620.jpg
831/thumbs/carlos51.jpg
by Frenzy
500/thumbs/IMAG0120.jpg
by 86 monte carlo ss
500/thumbs/466097435l.jpg
by Joe87monteSS
1191/thumbs/10391661_101613966532734_4955026_n.jpg
by DLV555
