#1006730 - 07/04/14 01:18 PM
Shift Cable Bunching up, wont go into Park or R
toastedoats
Fitchburg, MA
Last weekend my shift cable broke, so I ordered a new one from MikesMontes. I got the cable installed no problem, however when trying to put the car in P or R the cable bunches up rather than pushing the linkage forward. I have tried adjusting the cable with no luck, also none of the column linkage is currently installed. This is frustrating the hell out of me, hope someone can help!
#1006870 - 07/06/14 07:55 AM
Re: Shift Cable Bunching up, wont go into Park or R
[Re: toastedoats]
Fred SS
Glassboro, NJ
Strange problem. I would suggest to detach the cable from the transmission lever. Then rotate the lever by hand through the positions, P, R, N, D, etc. The lever should rotate easily with a positive detent felt at each position. If the lever is hard to rotate, then something is wrong internal to the trans or the lever shaft is bound up some how. Hope this helps.
87 SS, Harwood cowl induction hood, UMI trailing arms. Hooker 2050 TES Headers (Jet Hot Coated). Goodwrench 350, Ported TPI, Trick Flow 56cc alum heads, SLP runners, Comp Cams 260AH-12 cam, Trick Flow 1.5 roller rockers, Bilsteins, TCI 2400 stall converter, Ramcharger fans, Denny's 3.5" Driveshaft, GBodyParts GNX Wheels 18x8 & 18x9.
#1006934 - 07/07/14 03:48 AM
[Re: toastedoats]
Nice Sunny Hawaii
How's about the linkage that connect to steering column? Maybe something is binding there...........
#1006949 - 07/07/14 03:23 PM
[Re: toastedoats]
Gary_86SS
Ridley Township, (South Easter...
Is it possible that the shift lever on the trans is not properly keyed onto the shaft or that it's not the correct shift lever ?
Gary '86 White/Maroon Notchback original owner 2002 Maple Grove Super Chevy Runner-Up Street Class 1970-1986
#1007031 - 07/08/14 12:11 PM
[Re: Gary_86SS]
toastedoats
Fitchburg, MA
Is it possible that the shift lever on the trans is not properly keyed onto the shaft or that it's not the correct shift lever ? I hightly doubt it, I have not touched any of the parts aside from the shift cable personally and the car was one-owner low miles, all original when I bought it. It doesnt seem like something that could be incorrect... I have not yet removed the new cable from the car but from looking at the old cable I am assuming that the rod at the end of the cable is coming too far out of the center metal shaft inside the dust boot and exposing the cable where it is pliable enough to bend rather than push. It almost seems like it could be the incorrect cable no allowing enough forward movement before overextending and the length between the clip on the trans and shift lever is very tight. I have been assuming that getting it from Mike's Montes I would be ensured it was the correct part. I see that there is a lot of debate on the forum about what shift cable may or may not be correct for this application. Does anyone have a confirmed good part number that should work?
#1007042 - 07/08/14 02:04 PM
[Re: toastedoats]
PB86SS/87LS
Administrator 20+ Year
Stock shifter and 200-4r, correct? Almost seems too obvious but thought it's worth asking. There are different cables for the 200-4r based on what car/shifter setup you have. I know I got the wrong one from NAPA a few years back when my cable seized up, I think the Olds application. Since then I have a couple correct ones, might look to switch mine again since it "slips" when going through the gears quickly from drive to park. Can turn the column by hand easily, cable or cable connection issue of some sort.
Have you taken the shift plate off and double checked how it's connected at the shifter? In case something is binding or slipped out of place.
#1007044 - 07/08/14 02:25 PM
[Re: toastedoats]
toastedoats
Fitchburg, MA
Yes, stock shifter and 200-4r.
I have removed and re-installed both ends of the cable from their mounts and observed what appears to be normal operation without binding or slipping up top or in the lower mount, just where the cable bunches up at the gear selector on the trans.
I have ordered an ATP Y239 cable from rock auto to see if that one works any better
#1070308 - Yesterday at 10:35 AM
[Re: toastedoats]
69hurstolds
Aiken, SC
Considering the thread is about 7 years ago, I'm assuming it got fixed.
GM p/n for their cable for 200-4R (MW9) is 10026082, but it's discontinued and hard to find new.
For aftermarket, there seems to be only 2 brands.
ATP has Y239, and Pioneer offers CA1102. I cannot speak to the quality of these two companies from personal experience as I've never used aftermarket cables.
You would have to take the boot off to see, but if I were to guess, it appears the cable sheath inside the boot may have broken or have been compromised, basically turning the transmission end of the cable into a wet noodle under pressure. If you couple that with the potential cable stretch that inevitably occurs over time, it just makes things worse. Not saying this is what happened, as there's been no autopsy on any of these issues that I've seen.
by wcked_ss
by marksSS
by mightymonte10
by sick84cl
by cs85ss
