#1069893 - 03/14/21 11:53 PM Switched power for multiple relays?
spacemanspif Offline
Sewell, NJ
Hi all,
Been away a while with a new baby but have the car down for an engine upgrade and want to address some short cuts I took over the years.
What is your preferred method of distributing switched power to multiple items the cabin or engine bay?
I have relays for fans under the hood and want to add another for a wide band O2 sensor soon. Maybe nitrous down the road. My fan relays are currently piggy-backed on the choke circuit. I know relays don’t draw much but don’t want to add more to that circuit. I’ve looked at bus bars and power posts online but don’t know if there is something better out there. Or should I just run a wire loop around the engine and pull lines off wherever I have a relay close by?
I’m looking for simple, safe, and expandable. Might be asking for too much but better to ask than never try, right?
-Mike
Killed a few cones too
#1069904 - 03/15/21 02:25 PM Re: Switched power for multiple relays? [Re: spacemanspif]
I used something like this that I was able to grab from the trash bin at work. It looked a little different, and had 1/4" spade terminals on it and 3 different sections (I used one for 12V constant, one for 12V ignition, and one for ground). Fed it off of a relay for the ignition source so that I've got one relay powering the block, and then multiple relays feeding each device. If that relay dies, I don't have computer, fuel pump, fans, or a few other items so I keep a spare on hand at all times, but it will also be easy to troubleshoot. And if you are going for clean, you can mount this at a good location (close to battery?) and keep wire runs short to the high amp stuff. Stuff like a wideband could pull straight off the block since you have ~30 amps to play with. I like the ground block too, not only because it keeps it simple but because if you have weird issues, it will likely affect multiple things and any one of them will trace back to that location.
https://www.amazon.com/Recoil-Studs-Screw-Terminals-Distribution/dp/B08C9MXVFQ/ref=sr_1_11_sspa?dchild=1&keywords=Distribution+Connecting+Blocks+1%2F4%22&qid=1615817820&s=audio-video-accessories&sr=1-11-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExU1ExVDZOTUlKUjY1JmVuY3J5cHRlZElkPUEwNTcxNDk0Q0o3VUxOVFdQWDVLJmVuY3J5cHRlZEFkSWQ9QTAxODE4OTMzT1NVVDJPWkdHQ0daJndpZGdldE5hbWU9c3BfbXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
#1069905 - 03/15/21 02:52 PM Re: Switched power for multiple relays? [Re: spacemanspif]
Here is the post where I showed the relay box I installed during my EFI upgrade.
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=1062092#Post1062092
I think the box was like $19 on Amazon and came with all weather pack connectors and a cover. I pulled the constant hot straight from a battery post to a distribution block, same with ground block, and the switched power from the purple wire to the distributor that turns on all the key on relays.
#1069906 - 03/15/21 02:57 PM Re: Switched power for multiple relays? [Re: spacemanspif]
#1069907 - 03/15/21 02:59 PM Re: Switched power for multiple relays? [Re: spacemanspif]
#1069911 - 03/15/21 05:12 PM Re: Switched power for multiple relays? [Re: spacemanspif]
Saw your link to the part, thought I'd repost here for reference. That is a nice looking setup for multiple relays, looks factory.
#1069917 - 03/15/21 09:55 PM Re: Switched power for multiple relays? [Re: spacemanspif]
Sewell, NJ
Ok I like your style guys and am reading you loud and clear that I should clean and consolidate. But still my question remains. What do you use to power all these relays? My fans are ground controlled and I’d want my wide band on with the ignition, so do I just leaf-frog my switched power wire from 1 relay to the next?
-Mike
#1069918 - 03/15/21 10:11 PM Re: Switched power for multiple relays? [Re: spacemanspif]
I found one ignition source (can't remember what it was from, might have pulled it from the column or the original ECM feed, maybe just an IGN labeled fuse in the box? 10 year old memory is getting fuzzy...), ran it to a single 30A relay that got it's feed from the battery and is switched on with ignition.
That relay gave me 30 amps available power at the terminal block where all my ignition-powered relays and minor draws fed from, making it easy to add relays or accessories without having to tap into that one little wire over an over.
How I did it was physically ugly, but it worked out well from a system operation standpoint vs trying to find ignition sources and piggy-backing off of random other wires that would make it hard to troubleshoot later. I know you have mentioned trying to keep wire clutter out of the bay, only reason I mentioned clean, absolutely no judgement from me on clean wiring!
#1069919 - 03/15/21 10:18 PM Re: Switched power for multiple relays? [Re: spacemanspif]
Speaking of ugly, how about a text-drawing to confuse things?
`****Ign wire ******* Battery +12 **************
`************ 85 *** 87 ***************************
`************ RELAY ***************************
`*********** 86 **** 30 ***************************
`Ground** / ********** \ ***************************
` ********************* Distribution block ********
`**************** Acc#1 Acc#2 Acc#3 Acc#4
#1069920 - 03/15/21 10:41 PM Re: Switched power for multiple relays? [Re: spacemanspif]
I used the Pink wire going to the distributor, extended it to the front area by my relay box and split it up to each of the relays I wanted to come on with the key. I didn't need it for my distributor any longer but if you still do, just splice into it by distributor and extend it to your relay box.
#1069925 - 03/16/21 03:01 AM Re: Switched power for multiple relays? [Re: spacemanspif]
Sewell, NJ
I appreciate the help guys. I gotta check my wiring for unused wires that have switched power. My distributor pink powers my MSD box and choke still runs to the carb’s choke. I deleted A/C so maybe the fan wire or something else will give me my leg to leap frog to all the relays.
Thanks again for the links and ideas.
-Mike
#1070109 - 03/28/21 10:11 PM Re: Switched power for multiple relays? [Re: spacemanspif]
tom demarco Offline
tom demarco  Offline
Burlington
auto rod controls has what you need
500/thumbs/monte_ss.jpg
by LM7MCSS
500/thumbs/003_4_.jpg
by pazzo1969
500/thumbs/SSLSsig2.JPG
by PB86SS/87LS
500/thumbs/PC110331.jpg
by 02intimidator
527/thumbs/88SS_RSB.jpg
