#1069897 - 03/15/21 10:51 AM Disc Brakes
Wilson Offline
Wilson  Offline
Brighton il
Currently building a 9" and researching disc brake setups. What are the do's and don't setups? I have read about caliper to frame issues. What are the go to brands and stay away from. I haven't bought a housing just yet. Going to be purchasing in next few months thanks.
#1069923 - 03/16/21 02:24 AM Re: Disc Brakes [Re: Wilson]
200kSS Offline
200kSS  Offline
Bloomsdale, MO
I've been warned to stay far away from the cheap kits that have the parking brake included in the caliper. I prefer the drum style parking brake inside the rotor hat.
#1069934 - 03/16/21 10:50 PM Re: Disc Brakes [Re: Wilson]
Wilson Offline
Wilson  Offline
Brighton il
So looking at kits. GM metric calipers vs the explorer brakes. Which is the preference?
#1069935 - 03/16/21 11:49 PM Re: Disc Brakes [Re: Wilson]
200kSS Offline
200kSS  Offline
Bloomsdale, MO
Explorer brakes IMO.
#1069949 - 03/17/21 06:30 PM Re: Disc Brakes [Re: Wilson]
No problem with my 9" swap with explorer brakes. Just the caliper/frame issues, fixed by clocking the calipers on the backing plate down and away from the frame.
If I did it again, I'd go with drums.
#1069951 - 03/17/21 10:36 PM Re: Disc Brakes [Re: Wilson]
Wilson Offline
Wilson  Offline
Brighton il
That is my biggest concern is the fit of the caliper to the frame with the space that is given which isnt much.
#1069955 - 03/18/21 02:43 AM Re: Disc Brakes [Re: Wilson]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
80% of brake stopping power is in the front discs. We spent the money on the front and upgraded to 12" ls1 brakes. On the rear we made a slight improvlement to the rear drum cylinders (Raybestos 37644 wheel cylinders, 7/8"), from 85 S10 2.8L pickup, plus new wheel cylinder clamps, new springs and holder pins along with new shoes.
#1069974 - 03/19/21 01:45 PM Re: Disc Brakes [Re: Wilson]
Wilson Offline
Wilson  Offline
Brighton il
Hey there Upflying. How far did you have to clock the calipers?
#1070014 - 03/22/21 09:45 PM Re: Disc Brakes [Re: Wilson]
aeroocoupe Offline
aeroocoupe  Offline
Lindenhurst, NY
I did the explorer rear disc brakes. My car is lowered 2in. In the rear 1 1/2 in the front.The ebrake hit the frame rails. Hope that this helps you.
Rob
#1070042 - 03/23/21 08:51 PM Re: Disc Brakes [Re: Wilson]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Kore 3 makes a few kits for the Ford 9" using GM parts. Used to be you could buy just the brackets from them, maybe still can. Can use this & if you need parts you can get them from your local GM dealer.
http://www.kore3.com/products.php?cat=12
They still have just the brackets:
http://www.kore3.com/proddetail.php?prod=10350-01
#1070907 - 06/01/21 12:30 AM Re: Disc Brakes [Re: Wilson]
Wilson Offline
Wilson  Offline
Brighton il
Has anyone used Willwood rear disc brakes on their 9" build?
#1071039 - 06/12/21 01:29 AM Re: Disc Brakes [Re: Wilson]
the_merv Offline
the_merv  Offline
Northern, Florida
over 10 years ago when I built my SS I used LT1 Fbody Rear Disc Brakes, cleared 15" drag wheels perfectly. My front brakes are the C5 Z06 setup, and they work excellent. As mentioned above the front is where the stopping power is, rear isn't that much.
1984 MONTE CARLO SS 6spd
#1071046 - 06/12/21 08:45 PM Re: Disc Brakes [Re: Wilson]
Wilson Offline
Wilson  Offline
Brighton il
I have ordered a Strange Engineering 9 inch woth big Ford housing ends with 31 spline axles. It is transit now. I was going to do drum brakes but think the 11" are somewhat overkill. Hearing stories of clearance issues probably going with a wilwood setup.
548/thumbs/DSC004871.JPG
by 84supersport
500/thumbs/10-13-06_4_.JPG
by Monte83
500/thumbs/DSC_0024.JPG
by wanadrv
500/thumbs/DCFN0004.JPG
by madmax74
500/thumbs/Resized_Choice_1.jpg
by s10bowrider
