#1069593 - 02/18/21 04:13 AM Loose parking brake release handle
FinallySS Offline
FinallySS  Offline
Nice Sunny Hawaii
Aloha guys.
I meant to ask this from long time ago and just didn't get around to it (truth is, I'm getting old and just keep forgetting.....................).
Anyway, as the title reads, I have a really loose parking brake release handle. Also, the handle does not retract on it's own, and I need to push it back manually. My original handle did retract on it's own, but I had to replace it because the handle broke (can't remember if the handle broke or cable snapped). Ever since, it does not retract on it's own.
I haven't pull off the driver side panel yet to take a look as I'm still dialing in the carb right now (white smoke is gone at the moment). At the same time, I need to work on my DD Lincoln for rear wheel bearing replacement (weather is not cooperating right now). can anyone shed some light on this? New cable perhaps? I can't remember if the replacement was used or new as it was while back.
Any thought?
#1069613 - 02/20/21 06:02 AM Re: Loose parking brake release handle [Re: FinallySS]
The E-brake release on the dash has no return spring on it, just a T-handle and a short cable. The return spring is part of the mech for the E-brake. Look at the mech on the left kick panel area and you may see the return spring may be broke or missing.
#1069650 - 02/23/21 02:31 AM Re: Loose parking brake release handle [Re: mmc427ss]
FinallySS Offline
FinallySS  Offline
Nice Sunny Hawaii
Thanks Bob. Been busy with my DD Lincoln so haven't pull the panel off yet. As soon as I finish with my Lincoln, I'll go ahead and take a look!
872/thumbs/GoodmarkAirCleaner11.jpg
1045/thumbs/IMG209.jpg
by Bonafide2k9
500/thumbs/carb.jpg
by tommy64red
500/thumbs/418047_2871250312786_1605735519_2500601_95493983_n.jpg
by 02intimidator
871/thumbs/Foose_11.jpg
