#1069169 - 01/11/21 08:57 PM
speedo gear
markg
nj
i have a 84 monte with a 325 rear and a 200r4 trans and i run 30 in tall tires in the rear. i put a 115 stock speedo in it. apparently this combo is way off for my speedo calibration because it reads way low. whatgear can i get for the trans?i dont want to chage the one on the shaft if i dont have to.
#1069177 - 01/12/21 02:16 PM
Re: speedo gear
[Re: markg]
upflying
#1069179 - 01/12/21 03:47 PM
Re: speedo gear
[Re: markg]
markg
nj
thank you.....do any of you know what the stock gear is for a 87 ss with a 200r4?
#1069197 - 01/13/21 11:11 AM
Re: speedo gear
[Re: markg]
markg
nj
thanks....its a 200r. the car in my signature is a different vehicle. thank you!
#1069261 - 01/16/21 05:43 PM
Re: speedo gear
[Re: markg]
markg
nj
thank you.....the calculator says i need 457 and i have 333 now. it looks like the closest i can get without changing the one on the trans shaft is 385 which is a 26 tooth. this would bring me much close and i would be happy with that. im having difficulty finding a single 26 tooth one though. any ideas?
#1069263 - 01/16/21 06:51 PM
Re: speedo gear
[Re: markg]
Fred SS
Glassboro, NJ
You could try gbodyparts.com for speedo gears.
by Tony K.
by 345HP87SSAC
by MonteDawn
by 85lolo
by tonys57chevy
