#1069076 - 01/04/21 09:56 PM
Re: 1987 MC SS LS2/4L60e swap
[Re: jmireles]
Hunter79764
Baby steps, baby steps... Troubleshooting is always fun. Good luck on getting it nailed down and fixed. I forgot another issue I had, where the screw terminal on the aftermarket fuse block was loose. It killed the fuel pump power and I think another circuit, might have been a feed to the ECM too. Might take a look there as well, depending on how your system is wired and routed. Don't forget wires that might be bumped by the steering shaft, or by the engine torquing differently when in reverse than in drive. Basically, anything that moves when you go to reverse. Even though that isn't causing it to stall, it used to and you still have the same problem with a different cause.
#1069298 - 01/19/21 02:17 PM
[Re: jmireles]
Hunter79764
Go-Pro's are awesome. You might look into a magnetic base for it. We use them for work, and built a handful of bases with some strong neodymium magnets and a 1/4"-20 screw stud for the mount to screw onto (with a locknut). We put a couple layers of tape on the magnet to make it easier to remove and easier to clean. On flat steel, it was almost impossible to budge. We launched them on barges dropping into the water, some of them getting hit full force with jets of water, others getting jolted 10g's and barely moving at all, but no drilling or gluing required to mount them. Tie a string on it just in case if you want an added layer of protection against losing it.
I was about ready to buy a knock-off GoPro before we bought a handful of them for work that I can use when needed... Anyway, sounds like a plan. Good luck.
https://smile.amazon.com/Mutuactor-Powerful-Neodymium-Threaded-Pull-Force/dp/B07JKWCVTX/ref=sr_1_5?dchild=1&keywords=magnet+stud+1%2F4-20&qid=1611065852&sr=8-5
by Tony K.
by 345HP87SSAC
by MonteDawn
by 85lolo
by tonys57chevy
