#1069042 - 01/01/21 04:10 PM Grey Wolf to Redline
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
It's been a long time coming, but my Monte is going to get finished finally. Teamed up with Kenny's Rod Shop here in Boise and with his help she'll get done.
So now a little visual history.
Here she is stock in '93
After her first paint job, the beginnings of Grey Wolf. Check out the oversize emblems grin
Now a defunct local car show, McDonald's Picnic in '94. A glimpse of a Hurst 442 in background
In the next post, where she was before I tore her apart.
1985 Monte Carlo SS
Under construction with a LS376 with a 4L70E
#1069043 - 01/01/21 04:31 PM Re: Grey Wolf to Redline [Re: BoiseSS]
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
A visual history continuation
The 355 I built
Now Grey Wolf in her glory laugh
Next some deconstruction
1985 Monte Carlo SS
#1069044 - 01/01/21 04:42 PM Re: Grey Wolf to Redline [Re: BoiseSS]
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
Continued
Front clip removed
Clean frame horn
Clean floor pan
The 355 is out
The empty engine bay
Now to build her up again, into Redline
1985 Monte Carlo SS
#1069045 - 01/01/21 04:48 PM Re: Grey Wolf to Redline [Re: BoiseSS]
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
Now we are here today. Again Kenny's Rod Shop (KRS) will be helping me get her back together. Once a slot opens up with his painter, I'll get her to KRS. There he'll shave the door handles to flush door handle, get her off the chassis and put on the rotisserie. Then I get the chassis back to do my part. The body will go to strip and paint while I work chassis. So for a sneak peek at what will be going in.
LS376/480 495 HP
Hopefully I can keep posting on this thread on a consistent basis. That means she's getting close to driving again.
Stay Tuned!
1985 Monte Carlo SS
#1069054 - 01/02/21 02:29 AM Re: Grey Wolf to Redline [Re: BoiseSS]
88ssBrent Online content
88ssBrent  Online Content
Looks good! Interested to see your progress.
#1069058 - 01/03/21 01:19 PM Re: Grey Wolf to Redline [Re: BoiseSS]
dns87ss Offline
dns87ss  Offline
Timmins, ON
Looking good, will be watching.....
black 87 SS,grey int,355, Edelbrock rpm intake and rpm heads,xe262,holley 600 vac,x-stream k&n,goodmark cowl, 18" Billet Specialties wheels, Nitto 245/45 and 275/40 tires, GN rear diff. Baer brakes 13"front, 12" rear, Street-Comp AFX front suspension
#1069276 - 01/17/21 11:13 PM Re: Grey Wolf to Redline [Re: dns87ss]
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
Just a quick post for a tiny update. I got some dress work done on the LS3. I'm still waiting on the hose fittings for the fuel rail crossover. But got the valve covers painted and installed. Helpful hint, if anyone ever gets the Proform coil pack relocation kit that I have, assemble it off the engine. If you drop one of the washers, they WILL make it under the manifold onto the valley pan.. So I had a set of valve cover stickers made for an old school look. Here is what it looks like now.
Now I have a question for you all. What should I do with the oil pan? Should it stay bare aluminum, paint it red or paint it black?
1985 Monte Carlo SS
#1069277 - 01/18/21 12:27 AM Re: Grey Wolf to Redline [Re: BoiseSS]
Hi Boise - I'd go with a thin layer of black paint to improve surface emissivity. The idea here is to make the oil pan a good heat sink.
#1069278 - 01/18/21 12:43 AM Re: Grey Wolf to Redline [Re: BoiseSS]
I think it would look good black. Kind of tie in the top, front, and bottom.
#1069458 - 02/03/21 09:16 PM Re: Grey Wolf to Redline [Re: BoiseSS]
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
Just a quick update. Got some parts in last night. I'm going with the Dakota Digital RTX gauge set up. I want to use the two gauge set up to replace the ash tray in front of the console. So I had Dakota Digital make two gauges for me, a trans temp and fuel pressure. They turned out perfect. Here are the visuals.
More parts are in, I'll get those posted soon.
1985 Monte Carlo SS
#1069533 - 02/10/21 02:57 AM Re: Grey Wolf to Redline [Re: BoiseSS]
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
Just a parts update. Finally the entire suspension kit showed up. Friday the Currie rear end shows up. Now I just have to wait on the shop to say they're ready for me. They'll remove the body and give me the frame back to work on it while the body is at paint. Getting itchy to start work and all the parts piled up in the garage doesn't help.
Here are all the pretty bits.
1985 Monte Carlo SS
#1069534 - 02/10/21 12:44 PM Re: Grey Wolf to Redline [Re: BoiseSS]
CM1SCW Offline
CM1SCW  Offline
Lenoir City, TN
Looks good, that is the same suspension I put in mine 87 monte carlo SS aerocoupe. Currently in shop getting ls3/6l80 swap. Engine, trans installed exhaust being installed. I also had dakota digital istrument panel installed. Again good looking car and setup.
#1069539 - 02/10/21 06:24 PM Re: Grey Wolf to Redline [Re: BoiseSS]
The one I went with from mikes montes. Its a quality piece. I should have my vacuum gauge from speedhut this week. Man, those Dakota digitals are nice.
I must say everything you have done so far with that car is A+, top notch. Keep it up.
#1069543 - 02/10/21 08:31 PM Re: Grey Wolf to Redline [Re: BoiseSS]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Steven, that is a beautiful build. You will have an awesome machine when you are done. It gives me some inspiration to do some upgrades. Good Luck
Fred
#1069609 - 02/20/21 04:34 AM Re: Grey Wolf to Redline [Re: BoiseSS]
Hi Boise,
Everything looks great except for the rear control arms, and specifically, those cylindrical TPU bushings. They're a big mistake in the rear, because they'll greatly inhibit articulation of the suspension.
#1069808 - 03/09/21 03:29 AM Re: Grey Wolf to Redline [Re: BoiseSS]
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
Just a quick update. Just got back my rendering from KEG Digital Garage. I'm really happy with it. They even chose an appropriate background without asking.
What do you think?
1985 Monte Carlo SS
#1069835 - 03/10/21 04:54 PM Re: Grey Wolf to Redline [Re: BoiseSS]
Looks nice!
#1069868 - 03/12/21 04:09 AM Re: Grey Wolf to Redline [Re: BoiseSS]
Looks great, nice build/thread. Cool to see the different iterations your SS has had, stock, dark silver(dig that color/shade) with the 355 to the update to more modern suspension and the LS3.
#1071769 - 08/23/21 03:44 PM Re: Grey Wolf to Redline [Re: PB86SS/87LS]
BoiseSS Offline
BoiseSS  Offline
Boise, Id.
Finally!!!!!! The car is at the paint shop! They're going to put all panels back on so they can block with proper gaps. Then they're going to blow her back apart and get me the chassis. Then I can post pictures of all the fun That I get to have. Stay tuned.
1985 Monte Carlo SS
#1071775 - 08/23/21 07:47 PM Re: Grey Wolf to Redline [Re: BoiseSS]
Progress!
#1071795 - 08/24/21 08:09 PM Re: Grey Wolf to Redline [Re: BoiseSS]
Sadly, if you want the car to be both low and handle, you're going to hate the QA1 front suspension kit.
500/thumbs/nightmare_5.JPG
by NIGHTMARE
500/thumbs/IMG_0550.JPG
by montesleeper83
by SickSpeedMonte
500/thumbs/20150423_185351.jpg
by MANDS480
500/thumbs/IMG101.jpg
by dub562
