Page 3 of 3 1 2 3
#910763 - 01/01/12 05:15 PM Re: Is this something I should take the time to do? [Re: SSLance]
345HP87SSAC Offline
345HP87SSAC  Offline
Stanberry, MO
Not sure how I missed this thead. I will be using this info now that the Aero is home. I have a few wires that need help and now I have this handy reference.
Thanks Lance.
#910815 - 01/01/12 11:43 PM Re: Is this something I should take the time to do? [Re: SSLance]
tall t-top Offline
tall t-top  Offline
San Antonio, Texas
yep tach feed is brown wire. the green wires i had went through the fire wall and were were connected to each other with a wire nut! scared Don't know what happened there! dunno
Andrew
#910822 - 01/02/12 12:12 AM Re: Is this something I should take the time to do? [Re: tall t-top]
That green plug next to the M/C plug is for diagnostics only. You hook up a dwell meter to it to check M/C sol dwell.
#910838 - 01/02/12 01:32 AM Re: Is this something I should take the time to do? [Re: Buick Runner]
345HP87SSAC Offline
345HP87SSAC  Offline
Stanberry, MO
Anyone have any pics of the wires under the dash ect?????
#910887 - 01/02/12 04:35 AM Re: Is this something I should take the time to do? [Re: 345HP87SSAC]
On the passenger side, there are two harnesses, one is for the computer, the other is for HVAC.
#910903 - 01/02/12 05:36 AM Re: Is this something I should take the time to do? [Re: Buick Runner]
I have pics of the wiring under the dash, although it is minus the computer harness. There not the good but if anyone needs them here they are.
#910976 - 01/02/12 10:35 PM Re: Is this something I should take the time to do? [Re: 406monte]
Thanks for posting those pics, i did not know there is a terminal block way up in there...My fuse box has a spider web of accessories hanging on it..
#914716 - 01/23/12 06:22 PM Re: Is this something I should take the time to do? [Re: SSLance]
kycarnut Offline
My First Post!
kycarnut  Offline
My First Post!
Owensboro, Ky.
Thanks for going to the trouble to post these pics and descriptions. I know you spent a lot of time on this and it is much appreciated.
#914981 - 01/25/12 06:11 AM Re: Is this something I should take the time to do? [Re: kycarnut]
That terminal dist block with the orange wire is used for the several HOT all the time lights, dome, vanity mirror, trunk light, rear quarter lights if equipped. The CTSY/CLK 20A fuse supplies the power. That fuse supplies all the rest of the things that will be powered when the key off. cigar lighter, underhood, footwell and glove box lights, memory for the radio, audio alarms (key minder), horn relay, the door lock switches (not the actual solenoids), along with what is also powered by the terminal block mentioned above. So that 20 amp circuit has a lot of little jobs to do.
That junction block would be a good place to pickup HOT ALL THE TIME 12 vdc for low amp draw uses. Just a shame it's stuffed way up there in an inconvenient spot.
#914999 - 01/25/12 01:32 PM Re: Is this something I should take the time to do? [Re: mmc427ss]
Wow, thanks Bob...I didn't know what it was for. I never really even tested it to see either. Now I know and think I will employ it somehow. I might move it down lower so it is more accessible.
#935534 - 06/12/12 03:43 PM Re: Is this something I should take the time to do? [Re: 406monte]
joyride Offline
joyride  Offline
Tacoma, Wa
This thread is epically awesome. I wish I would've seen this a long time ago but the search button doesn't function all that well...
My question if I may ask, is where is the oil pressure sending unit? I've been told somewhere down on the driver side of the block near the oil filter...but I can't find it to save my life. I do have some sensor on the front of the driver side block right between the headers #1 and #3 cylinder's primary tubes, except it has a wire connected to it already...I imagine one sensor for the computer, one for the gauge...
TIA.
Brian
Had an 88 Monte SS in HS, sold that!
07' MC SS black, all stock (for now)
85' Monte SS project car. Flat Black, 305 w/ LT headers, drop spindles, CPP 2 inch A-body rear springs, 18" Boss 338s
http://www.youtube.com/watch?v=HeKFlFEG_Bk&feature=share&list=UUiPzUj6CEffDt2J4Rv0Iwfw
#935547 - 06/12/12 05:35 PM Re: Is this something I should take the time to do? [Re: joyride]
This is the best picture I have of the oil pressure sending unit
See that silver canister behind the header above where the oil filter goes? It is actually on a short piece of pipe and a 45 degree fitting to be3 able to get it around the header.
#935548 - 06/12/12 05:55 PM Re: Is this something I should take the time to do? [Re: SSLance]
joyride Offline
joyride  Offline
Tacoma, Wa
Oh ok, thank you very much! I'm gonna just assume my motor is just so greased up and dirty that it's hard to see it because it's probably just caked in it and black. Now I know where to look I should be able to find it I would think. Thanks again!
Brian
#943277 - 08/25/12 01:14 AM Re: Is this something I should take the time to do? [Re: SSLance]
PATRON_89 Offline
PATRON_89  Offline
Sacramento, Ca.
sslance i currently have removed my stock headers for shortys, my oil presure sender was on the header so i figured id swap out my top sensor with my bottom sencer would this work? do i swap connections?
#943491 - 08/27/12 07:39 AM Re: Is this something I should take the time to do? [Re: Buick Runner]
phils_super sport Offline
creedmoor,nc
thanks for posting that I dont even have to ask now lol.mine is just hanging there and I looked all over and never found where it plugged up now I know why lol.
#1040247 - 06/14/16 01:25 PM Re: Is this something I should take the time to do? [Re: SSLance]
Lobito Offline
Lobito  Offline
North Bergen, NJ
Fast forward a couple of years, and this post is still helping people like me out. Thank you very much for all of the time you spent on this.
#1040420 - 06/19/16 04:38 AM Re: Is this something I should take the time to do? [Re: Lobito]
uba Offline
uba  Offline
Thatcher AZ
Wow!! I'm so pumped I found this post. I'm finally getting my engine back together after doing a rebuild and I didn't label some of them, or the labels fell off.... anyways, Thanks for posting this info! I was just in the garage banging my head because I was frustrated that I couldn't find some of these connections. This saves me lots of time and heartache.
edit:
oh hey, Lobito, thanks for posting and putting this at the top of the list...That's how I found it.
#1041811 - 07/25/16 08:37 PM Re: Is this something I should take the time to do? [Re: SSLance]
Lobito Offline
Lobito  Offline
North Bergen, NJ
This should definitely be a sticky.
#1045141 - 11/07/16 04:28 PM Re: Is this something I should take the time to do? [Re: SSLance]
Tquis08 Offline
Tquis08  Offline
Dayton,OH
On the second picture under the headers is that the temp sensor at the bottom right above the oil pan?
#1045803 - 11/27/16 11:13 PM Re: Is this something I should take the time to do? [Re: SSLance]
Tquis08 Offline
Tquis08  Offline
Dayton,OH
Is the bottom picture distributor power? It getting any spark looking for the problem
#1045820 - 11/28/16 03:04 PM Re: Is this something I should take the time to do? [Re: SSLance]
I'm not exactly sure which pictures you are referring too...there are many in this thread. Quote the actual picture and we'll help you figure out what you are looking for.
#1068679 - 11/21/20 04:19 PM Re: Is this something I should take the time to do? [Re: SSLance]
OhioMonteSS Offline
OhioMonteSS  Offline
Canal Fulton, OH
I know this an old post but this is the one I came across. Great information. I need to purchase a new engine harness, the one on left side from under brake booster that goes to alternator, starter, coolant temp sender etc. I have had no luck. Do you happen to know the part number for it, where I might find one, and what all models/years may be interchangeable with it?
#1068685 - 11/22/20 01:53 AM Re: Is this something I should take the time to do? [Re: SSLance]
There are some one here that part out these cars and www.mikesmontes.com is an approved vendor. If you don't see it on his website page, call and ask and good luck!! http://www.montecarloss.com/community/ubbthreads.php?ubb=postlist&Board=5&page=1 Check out this forum too!!
Page 3 of 3 1 2 3
527/thumbs/88SS_355TPI_1.jpg
846/thumbs/th_P32802641.jpg
by
500/thumbs/my_monte_4.jpg
by 85montanezcarloss
500/thumbs/100_0389.jpg
by montemarc
500/thumbs/Pewter_Wrangler.jpg
