#1068270 - 10/15/20 12:33 AM Power for heated o2 sensor
88ssBrent Online content
88ssBrent  Online Content
Friendsville,Tn
Have the headers installed still have to run the rest of my exhaust. Im pretty happy with the fitment of the patriot 8096. Not the greatest picture.
My question is where did you pull power from for the heated o2? Also going to put a wide band and speedhut a/f ratio gauge in the other exhaust so im trying to think ahead. What kind of amps does the heating element pull in a 3 wire o2?
#1068271 - 10/15/20 01:18 AM Re: Power for heated o2 sensor [Re: 88ssBrent]
I just tapped mine into the electric choke power circuit.
#1068274 - 10/15/20 01:31 AM Re: Power for heated o2 sensor [Re: Buick Runner]
Friendsville,Tn
Thank you! I have a tendency to make things more difficult that they should be. I didn't even think about the electric choke power circuit.
#1068275 - 10/15/20 03:15 AM Re: Power for heated o2 sensor [Re: Buick Runner]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
That is what I did also. Has been working good for several years now.
#1068278 - 10/15/20 12:45 PM Re: Power for heated o2 sensor [Re: 88ssBrent]
Tunedss86 Offline
Tunedss86  Offline
Eastern Virginia
Separate thought, those headers are raw steel? Expect them to rust quick. Even painted ones rust quick, the heat burns the paint off.
#1068281 - 10/15/20 01:59 PM Re: Power for heated o2 sensor [Re: Tunedss86]
Friendsville,Tn
Thank you! I actually ordered them raw because I needed to tig weld the bungs in and knew I would need to make a couple more modifications. Most companies do crap job on coating. I have a shop local that I use that will blast then coat inside and out.
#1068284 - 10/15/20 02:35 PM Re: Power for heated o2 sensor [Re: 88ssBrent]
Friendsville,Tn
I was looking through the electrical supplement for the 88 monte carlo. What I find odd is there is only one mention of the choke heater. All the diagrams stop at the idle speed control and oil pressure switch.
#1068289 - 10/16/20 05:01 AM Re: Power for heated o2 sensor [Re: 88ssBrent]
The C/H 20A fuse supplies power to the choke heater, and the fast idle relay which activates the idle stop solenoid on the carb, when and only when the ECM command the throttle to be open a little on deceleration. That function is to lower emissions. As far as I know that function isn't used often under normal driving. Something that could be deleted from a ZZ4 PROM.
Looking in the Helm's Electrical Supp you will only find the C/H circuit mentioned used in:
Computer Command Control: V8 Vin G 22-2
The Fuse Block Details 11-3
Instrument Panel:Indicator Cluster in my 87 Helm's 80-2
So the Idle speed solenoid shouldn't pull to much current, maybe 3A, and the Choke Heater Coil may pull 8A. A three wire heated O2 sensor may pull another
3A. So it should be safe to have all three on the C/H 20A fuse. 75% load on a 20A fuse is 15A. The choke coil and heated O2 would need to be turned ON when the engine has oil pressure. The oil pressure switch to the left of the dist has that distinct function. It's the only way to wire an electric choke and a heated O2.
I've been running the choke and O2 for the wideband A/F that way for years off the C/H fuse. The idle speed solenoid on the carb is now wired directly into the low pressure switch's load side. When the compressor turns on the solenoid is activated. Sometimes I find the solenoid gets a little lazy when the compressor turns on. You need to tap the pedal to allow the solenoid to extend fully. Being a stick shift it's not a big deal.
#1068290 - 10/17/20 01:17 AM Re: Power for heated o2 sensor [Re: 88ssBrent]
Friendsville,Tn
Thank you all for your help! I used the c/h circuit and everything worked out.
500/thumbs/monte_carlo_0044.jpg
by 85lolo
500/thumbs/IMG_0660s.jpg
by Turbo5
500/thumbs/ang.jpg
by mrengineer
500/thumbs/monte81.jpg
by johnnybravo21
500/thumbs/carlo2.jpg
by rj
