#1058953 - 09/04/18 11:20 PM Transmission pan leak
WaSSted Offline
WaSSted  Offline
Kennewick
It's been years since I've posted but I'm at the end of my rope with my car. I might put 500 miles a year on it. Anyway 3 months ago I changed the pan gasket cause I got tired of the leak. I cleaned everything. Made sure the stock pan sealing surface was as flat as possible. I used a felpro gasket and tightened in an alternating pattern to I think 12 ft lbs. Drove it and double checked the pan bolts, then parked it.
So it has been sitting all summer. I checked it every month and no leaks, until just recently (last weekend). I don't understand how it leaks when I don't even drive it.
Cork gasket? Silicone? What do I need to do to get this thing to stop? I've been told to get that $250 aluminum pan. But why can't I get the stock pan to seal?
Please help
Kirk Herres
#1058957 - 09/05/18 01:15 AM Re: Transmission pan leak [Re: WaSSted]
When a vehicle sits a lot, the torque converter drains out, you may have a leak at the TV cable exit point or possibly the fill tube connection, check out these possibilities!
#1058965 - 09/05/18 01:34 PM Re: Transmission pan leak [Re: WaSSted]
Agree with Leo, those two points are possible leaks to check.
Had similar problem with friends Bowtie Overdrive 200 R, gasket leak. We swapped in my old 200 R pan and fixed problem.
With pan tightening I loosely snug the bolts and then go around the pan several times, not across.
#1068263 - 10/13/20 06:37 PM Re: Transmission pan leak [Re: mmc427ss]
WaSSted Offline
WaSSted  Offline
Kennewick
I finally found the culprit, it was leaking where the speedo cable attaches.
Kirk Herres
#1068264 - 10/14/20 12:02 AM Re: Transmission pan leak [Re: WaSSted]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
Great that you found the leak. Do you know what size O-ring? That is something I need to replace too.
#1068265 - 10/14/20 12:06 AM Re: Transmission pan leak [Re: Fred SS]
WaSSted Offline
WaSSted  Offline
Kennewick
No clue. I found a kit on Amazon for 15 bucks
Kirk Herres
669/thumbs/P1010330.JPG
by Matt?
500/thumbs/Sherrys_SS_Monte_Carlo_1988_007.jpg
by SherryDiMauro73
500/thumbs/1286827947051.jpg
by ChrisB86
500/thumbs/DSCF0835s.JPG
by TriumphoverU
500/thumbs/Rollsteer.JPG
by SickSpeedMonte
