#1067758 - 08/25/20 02:49 PM 700R4 Mount Location
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Hello...I have a 85 Monte with a 700R4 tranny. The tranny has the 2 mount bosses (from a Caprice)...One close to the oil pan and the other close to the tail housing. Does it matter which mount location I use? BTW: I have a G Force Crossmember. Thanks
#1067762 - 08/25/20 09:18 PM Re: 700R4 Mount Location [Re: MisterAdam]
BladeOfAnduril27 Offline
Doylestown, PA
I'm not sure that I understand your question, but I suspect that the crossmember, when bolted to the frame is going to dictate the used of the rear mount location on the trans.
~ Matt H.
#1067766 - 08/26/20 12:23 AM Re: 700R4 Mount Location [Re: MisterAdam]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
copy that. Sorry for the confusion.
I think I need the shorter transmission mount. That should correct my problem.
#1067771 - 08/26/20 03:34 AM Re: 700R4 Mount Location [Re: MisterAdam]
MattsMonte Offline
MattsMonte  Offline
Johnston, Iowa
#1067772 - 08/26/20 11:49 AM Re: 700R4 Mount Location [Re: MisterAdam]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Excellent...Thanks...Just what I needed
Why reinvent the wheel?
500/thumbs/P_Tour.jpg
by 396 MonteC
694/thumbs/DSC02195.JPG
by halfdozenbuzen
500/thumbs/ss_body_work_2.jpg
by itslvbaby4
681/thumbs/T5_in_place.jpg
500/thumbs/sneak_peek_2.jpg
by THEmean1
