#1066303 - 05/06/20 12:28 AM parasitic battery drain HELP!!!
8T7AERO Offline
8T7AERO  Offline
Corona, CA
Hello I need some help and advise on trouble shooting a parasitic drain on my battery after the car been sitting for a couple of days, Its ruined 2 Optima redtop batteries (one brand new and the other was out of my other car, so bad that it wouldn't take a charge) The Monte has the ECM removed and the harness that goes with the removal of it. Wondering it that could be a cause it? I thought of using a millimeter connected to the battery and pull the fuses one at a time to see if the load on the battery car not running drops? I also have a MSD ignition (box,coil and distributor), electric fans with a relay and a torque converter lockout switch installed ,which was just installed prior to getting the car running about a month ago and Its was sitting since 2014 the garage. I checked the the charging system and grounds and checked out good, prior to realizing that it might be a parasitic problem. Thanks
87 Aerocoupe,Rapp Racing 383.Leather interior. headers, flowmasters, k&n filter,MSD Ing, 17x8 iroc w/ 245/45/17 s.s.b.c.calipers & cross drilled rotors. Kenwood sound system..
#1066309 - 05/06/20 08:14 AM Re: parasitic battery drain HELP!!! [Re: 8T7AERO]
AkronAero Offline
AkronAero  Offline
If you have a volt-ohm meter, pref with DC amps, you can disconnect the battery and start taking measurements through the meter. Start with the lights in trunk, under hood and glove box; disconnect and look for change when bulbs removed and closed (before/after). I think my MSD had a draw too, so I put in a disconnect on the battery ($15). Swapped out so not sure now. You can check for a bad diode in your alternator which will allow a continued drain when shut off. You can also try to isolate portions of the fuse box or related circuits but its a lot of effort. Like to hear OP experiences too.
Good hunting.
#1066312 - 05/06/20 03:03 PM Re: parasitic battery drain HELP!!! [Re: 8T7AERO]
I had a bad diode that would kill a battery in 2-3 days on a truck I had. Installed a battery disconnect since I didn't use it much, didn't figure out the cause until I replaced the alternator because the bearings went to crap. I also had my glovebox light switch on the Monte act up and stay on, it would kill it in after a while.
Otherwise, you are on the right track. You might go in and pull a handful of fuses, then add them back in and look for changes.
#1066316 - 05/07/20 12:23 AM Re: parasitic battery drain HELP!!! [Re: 8T7AERO]
MC96 Offline
MC96  Offline
St. Johns MI
Put a test light between the battery ground wire and the battery ground terminal, if it lights up pull fuses until it goes out.
That will narrow it down to what system the draw is in.
86 SS
In progress
#1066318 - 05/07/20 12:59 AM Re: parasitic battery drain HELP!!! [Re: MC96]
This^^^^^^
#1066329 - 05/07/20 02:57 PM Re: parasitic battery drain HELP!!! [Re: 8T7AERO]
I have a knife blade disconnect on my negative terminal. Not that I have a parasitic drain but more for fire prevention. If I smell wiring burning, I can quickly save the car.
A quick disconnect could temporarily solve the problem until you track down what circuit is on.
1166/thumbs/106660_584aa629c4_low_res.jpg
by lonk
500/thumbs/0711111817.jpg
by tetamcssmokin
622/thumbs/IMG_0806.JPG
by cj84ss
510/thumbs/100_0302.JPG
by 85_SS
519/thumbs/DSC00028.JPG
by Ted88SS
