#1065599 - 03/21/20 12:21 AM Alternator/Starter Issue
sg5492 Offline
sg5492  Offline
Basehor, Kansas
I have a Proform mini starter on my 87' Monte Carlo SS and I'm not sure I have it wired right. I did have a bad alternator so I replaced it and still not charging, so I'm thinking I might not have it wired correctly or do I have some other wiring issue? The ignition wire goes to the top spade on the starter, I have the positive cable on the positive terminal on the starter, and the only way I can make the car run is the accessory wire (for lights, power windows, etc.) on with the positive cable. If I move it to any other terminal on the starter the car will not run. When the car is running it is still not charging. I'd appreciate any help!
Thanks!!
87 Monte Carlo SS (original owner) Pro Street, 388SBC, 400 Turbo Manual Valve Body w/trans brake 4,500 Converter, 4 link
#1065629 - 03/22/20 10:46 PM Re: Alternator/Starter Issue [Re: sg5492]
tom demarco Offline
tom demarco  Offline
Burlington
The wire from ign goes to s terminal, so when key is on in start position it will light a test light when you try to start car and go off when it is running, the battery positive goes to big lug on starter, nothing else to do. I think you have a bad positive battery cable rotted inside, or a bad negative cable bad ground to block or bad cable, you could do a voltage drop test, check ut utube for voltage drop test to starter, you will need a multimeter, as far as alternator goes, if it only has one wire it needs to be live all the time, if you have two wires one live all the time and one key on engine running, it may be a good idea to check fusible links, if what i said doesnt work
#1065637 - 03/23/20 01:31 PM Re: Alternator/Starter Issue [Re: sg5492]
jmireles Offline
jmireles  Offline
El Paso, Tx
How about posting some pictures of your set up? Snap some shots of your battery, alternator and starter. It will be easier to help, I think.
in '08. 3K
#1065644 - 03/23/20 10:02 PM Re: Alternator/Starter Issue [Re: sg5492]
sg5492 Offline
sg5492  Offline
Basehor, Kansas
Thanks for the the information, I checked the fusible links and everything seems to be okay. I will try to post some pictures off of my phone. If it doesn't work I will try to download on my work computer and give it another shot.
#1065669 - 03/24/20 09:28 PM Re: Alternator/Starter Issue [Re: sg5492]
tom demarco Offline
tom demarco  Offline
Burlington
I hope you tested them with a meter not visual
#1065810 - 04/01/20 10:13 PM Re: Alternator/Starter Issue [Re: sg5492]
sg5492 Offline
sg5492  Offline
Basehor, Kansas
Update
After checking all wiring connections and cleaning every ground wires on the car also had the battery checked it turns out it's a faulty NEW alternator. It would charge once in a while but, most of the time it would not. Thanks for all the responses.
#1065814 - 04/02/20 02:23 AM Re: Alternator/Starter Issue [Re: sg5492]
Fred SS Offline
Fred SS  Offline
Glassboro, NJ
What brand alternator is it?
#1065818 - 04/02/20 05:21 PM Re: Alternator/Starter Issue [Re: sg5492]
sg5492 Offline
sg5492  Offline
Basehor, Kansas
O'Reilly Ultra part number ULT R111651A
it would test good they had to test it 3 times in a row for it to fail.
#1065824 - 04/03/20 01:09 AM Re: Alternator/Starter Issue [Re: sg5492]
because it has to get up to operating temp!!
957/thumbs/0014.JPG
by SSLANE
787/thumbs/85SS_04.jpg
by
500/thumbs/20121008_161230.jpg
by ray396
523/thumbs/DSC_0617.jpg
500/thumbs/Monte_001_1_.JPG
by BaerMonteSS83
