#1065145 - 02/21/20 12:32 AM TH-200-4R transmission
ray6914 Offline
ray6914  Offline
pittsburgh pa
I got the transmission from a 87 Monte Carlo SS V8 I'm putting in a 1984 Monte Carlo SS I was wondering about the lockup for the torque converter do I need to buy a kit or can I run that just off the brake switch my car does not have the computer it was deleted
#1065147 - 02/21/20 02:13 AM Re: TH-200-4R transmission [Re: ray6914]
You'll need some kind of kit, do a search here for ideas and good luck!!
#1065148 - 02/21/20 02:18 AM Re: TH-200-4R transmission [Re: 86ttop]
ray6914 Offline
ray6914  Offline
pittsburgh pa
Okay thank you
#1071676 - 08/18/21 05:42 PM Re: TH-200-4R transmission [Re: ray6914]
bcoz Offline
bcoz  Offline
ManchesterNH
Hey
I am in similar boat or SS. I deleted the computer and have a 383 stroker. Does the 200 R4 has been upgraded to handle the 425hp but curious do you need the computer for shifting issues or is it a non issue. ??? Any help appreciated
87 AEROCOUPE - 383 STROKER
#1071691 - 08/19/21 12:57 AM Re: TH-200-4R transmission [Re: ray6914]
The computer only controls lock-up, as I stated above, you can get a kit to make it work, good luck!!
#1071696 - 08/19/21 04:04 AM Re: TH-200-4R transmission [Re: bcoz]
FinallySS Offline
FinallySS  Offline
Nice Sunny Hawaii
Originally Posted by bcoz
Hey
If you have problem shifting, check your TV cable. Maladjusted cable with that much HP will kill the trans in no time. Stock engine kills trans with maladjusted cable in short time. Imagine with that much power.
Also, what kind of upgrade did you get? From where? There's only few places that understand our beloved 200-4R.
#1071710 - 08/20/21 11:57 AM Re: TH-200-4R transmission [Re: FinallySS]
bcoz Offline
bcoz  Offline
ManchesterNH
Thanks. Lock up kit is definitely in the next step, the upgrade itself was done by a local transmission shop in NH that works on a pretty wide variety of cars to include hot rods. Changed out the torque converter and upgraded the internals to handle the hp. Seems good, just seems have to really get on it high rpm's in order for it to shift to second. May be by design, i will hook up witht the tranny shop and see if maybe the cable needs adjusting. thanks.
#1071711 - 08/20/21 01:19 PM Re: TH-200-4R transmission [Re: ray6914]
88ssBrent Online content
88ssBrent  Online Content
To me this is a great article on diagnosing and setting the TV cable. Art Carr is well known in the 200-4r world.
https://www.cpttransmission.com/tech_tvcable.htm
Diagram that goes with the above link.
https://www.cpttransmission.com/Files/tec2.jpg
#1071713 - 08/20/21 02:47 PM Re: TH-200-4R transmission [Re: 88ssBrent]
bcoz Offline
bcoz  Offline
ManchesterNH
Thanks Again!!
500/thumbs/Monte_carlo_Aero3.jpg
by MaverickMonte85
500/thumbs/032.JPG
by dcvp
500/thumbs/553980_10151521178838662_1180743004_n.jpg
by UNOH_MONTE
531/thumbs/draw_monte11.jpg
by tonys57chevy
500/thumbs/car_0041.JPG
by gunga
