#1065088 - 02/12/20 09:17 PM Leftover parts from EFI swap MSD Intake AFR etc
Clearing out some OEM parts left over after EFI upgrade
MSD Programmable Digital 6AL-2 Ignition Box 6530 ($200)
https://www.summitracing.com/parts/msd-6530
Comes with everything you need to hook up and control the timing in a MSD Pro Billet style distributor. This was my backup MSD, I verified it worked then stored it and took it with me on the road but never ran it.
MSD Programmable Digital 6AL-2 Ignition Box 6530 ($250)
This one includes a cable to hook the MSD box to a laptop for programming and monitoring and a MAP sensor as well as everything else you'll need to install. I ran this on my car for about 4 years and had it setup to control the timing on my 383 using both RPM and load (via the MAP).
Chevrolet Performance Vortec Low-Rise Intake Manifolds 12496820 ($200.00)
https://www.summitracing.com/parts/nal-12496820
This dual plane intake came on my HT383 crate engine, it is for Vortec heads, has EGR (with block off plate) and accepts both spread bore and squarebore style carbs. Comes with all plugs you see and the OEM thermostat housing but no thermostat. Just need gasket areas cleaned up, then bolt on and go.
Parts are all at my house in Phoenix, I can securely box up and ship anywhere, you pay my discounted UPS or USPS rate whichever is cheaper.
#1065113 - 02/14/20 06:04 PM Re: Leftover parts from EFI swap MSD Intake AFR etc [Re: SSLance]
MSDs are sold, looks all that is left is the intake manifold.
#1065118 - 02/16/20 10:44 PM Re: Leftover parts from EFI swap MSD Intake AFR etc [Re: SSLance]
Intake sold, everything gone...Mod can delete if they like.
500/thumbs/DCP01731.JPG
by BAD ASS 87
989/thumbs/my_monte_12.jpg
by 85montanezcarloss
500/thumbs/DSCN3957.JPG
by NY GiantSS
564/thumbs/oscars_LS_MONTE_CARLO_003.jpg
by Big Reazon
500/thumbs/100_1275.jpg
by RocknSS
