#1065074 - 02/09/20 01:21 AM Opinions on Monster Transmissions lockup kit?
JesusCPenney Offline
Fort Worth, TX
I have a stock 200-4R and I'm running computer delete but I'd still like to have torque converter lockup for highway cruising. This Monster Transmissions kit seems simple enough:
https://youtu.be/wmyIEV69pRA
Any opinions on this, or anything I should know before I spend the hundred bucks? Thanks guys
#1065075 - 02/09/20 03:49 AM Re: Opinions on Monster Transmissions lockup kit? [Re: JesusCPenney]
If you want to save some money and electrically inclined, I squirreled away the sensor number that can be used to put the kit together yourself. Buy the switch of your choice and a fuse holder (if you don’t already have them) . You could get the 1/8” NPT 90-degree fitting and some wiring (if you don’t already have it) at your local hardware store. You could use the Monster video and the diagram on their site for the wiring. It takes less than $30 worth of parts to do it yourself.
Normally Open Oil Pressure Switch - $12 at Napa (don't know the cross-reference for other brands)
https://www.napaonline.com/p/ECHOP6624
Eaton Fitting - $2.14 at Amazon (should be about that at the local hardware store)
https://www.amazon.com/Eaton-Weatherhead-Fitting-90-Degree-Female/dp/B00USZZ3LS
4 Pin Weather Pack Connector - $6 from eBay (it has the female ends and the pins (some sell the connector without the pins)
https://www.ebay.com/itm/Delphi-Weather-Pack-4-Pin-Sealed-Connector-Kit-12-10-GA/322467001279?epid=1862818997&hash=item4b1487f3bf:g:oxkAAOSwJ3Rb~IHb
Switch of your choice – starting at $2 from Summit
https://www.summitracing.com/search?SortBy=DisplayPrice&SortOrder=Ascending&keyword=toggle%20switch&N=part-type%3Aelectrical-switches
#1065077 - 02/09/20 08:23 PM Re: Opinions on Monster Transmissions lockup kit? [Re: JesusCPenney]
kevins88ss Offline
kevins88ss  Offline
Southern Maine
The only thing I noticed missing from the Monster kit is a brake interrupt so when you press the brakes it disengages lockup. I have the Bowler kit but it's twice the money and not worth it. It's a really simple system and I think BadSS has a great solution - you may want to incorporate tying it into the brake pedal switch to complete the circuit.
#1065078 - 02/09/20 11:43 PM Re: Opinions on Monster Transmissions lockup kit? [Re: BadSS]
Fort Worth, TX
This is some great info, thanks for taking the time to type all this out! That's probably what I'll do.
#1065079 - 02/09/20 11:45 PM Re: Opinions on Monster Transmissions lockup kit? [Re: kevins88ss]
Fort Worth, TX
Could I expect driveability issues without a brake interrupt? Like will it stall when I stop? I assumed the lockup would disengage when the transmission shifts out of 4th
#1065080 - 02/10/20 11:40 AM Re: Opinions on Monster Transmissions lockup kit? [Re: JesusCPenney]
Brake interrupt would be a benefit.
The reason being if you forget to turn off the switch when out of 4th gear or accelerating after slowing down and not in 4th gear.
#1065081 - 02/10/20 04:34 PM Re: Opinions on Monster Transmissions lockup kit? [Re: kevins88ss]
200kSS Offline
200kSS  Offline
Bloomsdale, MO
Having that switch p/n is valuable information, thanks for passing it along.
I've used very similar kits and used the cruise control brake interrupt switch to power them. This allows the stalk mounted cruise control switch to turn power on/off to the circuit, and incorporates a brake pedal switch into the circuit as well.
My only issue with this style of wiring/circuit is the converter locks immediately and always when the transmission is in 4th gear. I'm spoiled with the stock ecm's ability allow 4th gear operation with the converter unlocked in situations like high load and low coolant temp.
#1066167 - 04/24/20 08:33 PM Re: Opinions on Monster Transmissions lockup kit? [Re: JesusCPenney]
8T7AERO Offline
8T7AERO  Offline
Corona, CA
I used a Lectric Limited P/N 500412 lockup kit, I had everything needed in the kit. The website is www.lectriclimited.com
87 Aerocoupe, Rapp Racing 383 with AFR aluminum heads.Leather interior,Hedman headers,Flowmaster Super 40's, k&n filter,MSD Ing, 17x8 IROC w/ 245/45/17, Wilwood front & rear disc brakes, UMI Performance Stage 2.5 suspension, Kenwood sound system..
#1066169 - 04/24/20 09:57 PM Re: Opinions on Monster Transmissions lockup kit? [Re: 8T7AERO]
FYI - looked up that part number and it is $72 at Summit (and Jegs)
https://www.summitracing.com/parts/aww-500412
That's the lowest price for a kit I've seen but it doesn't have the toggle switch the monster kit has to turn off the lockup in times you would rather it not be locked. Switches are cheap though.
Still wouldn't be that hard to piece together if you're electrically inclined and have some of the parts already laying around.
500/thumbs/monte_2010_front1.jpg
by montesleeper83
500/thumbs/IMG_0697.JPG
by 565bbchevy
500/thumbs/Photo_8.JPG
by Chief Jimbo
500/thumbs/yhuii.JPG
by juangomez22
500/thumbs/p9290119p_copy.jpg
by Nycore
