Page 6 of 6 1 2 3 4 5 6
#1058548 - 08/09/18 05:22 AM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
Its been long overdue..... But some things just take time.
I finally have tires for the wheels I purchased.
I have a set of the Center Line wheels. American muscle series MM6B. I know there not the best wheels, but they were budget friendly. Also, it didn't hurt that ebay had a 20% off deal at the time I purchased in 2017. Wrapped them in the also wallet friendly Federal performance tires on a 15% off deal. Its not the G-Force Sport Comp 2 tires I wanted, but its something.
Front: 245/40/17 on 17x8
Rear: 275/40/17 on 17x9
Swapped the alternator yesterday evening. I also learned something new. I have the Torque app on a tablet for my gauges. The app reads the voltage at the OBD2 plug. Even though the alternator was bad, I still wasn't getting an accurate reading.
Next thing I want to do, is clean up some of the wires under the hood. It will take time, but should be cheap to accomplish.
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1058573 - 08/11/18 01:23 PM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
84ss355*4spd Offline
Edmonton,AB,Canada
Like the wheels looks good
84ss current restoration
86 ss gone
85 ss new
85 z28 tpi
#1058619 - 08/15/18 04:17 AM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
Originally Posted by Witness86SS
Welcome back!
Thanks. The break was entirely too long.
Yea, I obsessed over the color options. There is an Anthracite Grey color that I liked, but the lip was machined and seemed too shiny for my taste.
Took my first test drive on the new tire setup. I took my normal loop, with a S-curve that I usually take going 30ish mph. When tempted I sometimes hit 40 mph. On those moments I get a decent amount of tire squeal through this curse. This time no squeal, but it was a completely different steering wheel feedback feeling. Also, the ride quality was significantly different. I was feeling all the bumps I usually glide right over. Got on it a few times, usually the rear would be on skates. This time, a chirp or two. I actually missed the stock tire lighting up whenever I get on it.
I put the stocks back on, to save the 17's for an autocross event. Hopefully, I'm at a event in September. Did some wire tucking in the engine bay. Its starting to look like something presentable. But now I want to take the entire 3-wire setup out. Redo the fuse and relays wiring and mounts.
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1058972 - 09/06/18 04:47 AM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
Took a ride on the interstate to hit a car show. It was a 25 mile run wide open, 60 - 70 mph the whole way. Running at 70 mph, I was turning around 2500 rpm on the 275/40/17. The Federals do have some road noise, but it was drowned out by the exhaust. Got to the show, but my old faded primer car wasn't what they was looking for. A few looks and nodes as I parked on the outskirts of the shows.
September 23 is the next autocross. The only thing I can think of, is an alignment. 2 years of f-ing around and now I'll finally get the chance to screw with the CAM guys.
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1059099 - 09/17/18 01:15 AM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
Beautiful day for a drive. One of the New Orleans Cars and Coffee takes place on the lakefront. I cruised down a few miles of sunny lakefront. Looked at a few cars and let the kid take in the water sights. .
Butttttt all good things come to an end. Started the drive home and about half a mile in, the engine starts to sputter under acceleration. Pulled over to check under the hood, nothing funny. Decided to limp home, and the sputtering increased to even happen at stops. I had just put 5 gallons in the tank on the drive. So, i will go through the standard list items.
Bad gas
Clogged filter
Spark plugs
Wires
Coils
Anything missing??
Also, with some internet research. I need to look into the MAF. Damn, I think I can get through the list before Saturday's autocross. Damn.....
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1059111 - 09/18/18 05:27 PM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
carlss Offline
carlss  Offline
Glen Ellyn Il.
Loose distributor ?
#1059119 - 09/19/18 01:03 AM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
That sucks dude. I had random sputtering from weak ignition last year. No problems since I fixed up the electricals. My guess is sensor issue or weak power to ignition overall. Not an individual plug cable or coil
Good luck!
Justin
1986 Black SS
#1059120 - 09/19/18 02:00 AM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
Z65_Paul Online music2
McDade, TX
Don't forget to check the rotor under the distributor cap. I had mine fail on a drive.. started as a sputter that got worse to the point the car shut off. Screws had come loose.
Good Luck
PaulC
#1059122 - 09/19/18 01:11 PM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
He's got an LS, so it isn't a distributor, but you should probably check grounds on ignition coils and/or fuel injectors. I had a stumbling under load problem on mine, ended up being the ground on the back of the head that was loose by a couple of turns, and under load the engine pulled away from the harness and lost contact. The "under load" part was what threw me the most, I was looking for fouled plugs, weak fuel pressure, bad sensors, etc before I finally saw it happen in the driveway when I pulled on a wire harness and killed the engine...
Anyway, good luck on tracking it down. Drain your gas to rule that out, check fuel pressure, and check grounds. A single plug, wire, or coil should be a miss, but not necessarily a sputter. And the odds of multiple similar parts failing at the same time is much less likely than a single ground or power circuit that is giving you issues. As for sensors, probably MAF and MAP are the ones that come to mind to throw off the driveability like that. I'd guess MAF over MAP, but it would probably throw a code.
#1059175 - 09/22/18 05:27 AM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
Thanks for the suggestions. Well, I started with the easy stuff. Pumped the tank (electric fuel pump), changed the fuel filter, checked the grounds, and cleaned the MAF. All the quick cheap options, no dice.
I think I found the issue. Popped a spark plug out just to see the condition. Saw it and knew to pull and replace them all. I had to wait a few days to get new plugs.
Those poor electrodes were limping to the finish line. Car runs, but I have to work the weekend so no more Autocross.
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1059254 - 09/29/18 03:15 PM Re: The Rebirth of my nameless 87 Monte Carlo [Re: Hunter79764]
jmireles Offline
jmireles  Offline
El Paso, Tx
Lol!! conf
I hope you find the fault soon. It's frustrating to wrench on your car when it has recently been put together.
in '08. 3K
#1059368 - 10/10/18 06:07 PM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
I think our cars share a soul or something.
I stepped on the gas last night and it just sputtered and tried to flatline. Tried that 3 times before i limped home at 1200 RPM.
Alternator was not keeping up. I shut off everything but the fans and headlights, but the volt meter wouldn't go above 10. =[
Justin
1986 Black SS
#1059415 - 10/15/18 08:06 AM Re: The Rebirth of my nameless 87 Monte Carlo [Re: Witness86SS]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
Damn. Hopefully your fix is cheap and easy.
As for me, I've just been reading all these Cam swap 5.3 stories and articles.
http://www.cpgnation.com/the-100-horsepower-upgrade/
I'm slowly convincing myself this needs to happen. But this might be something for a shop
Other moneypit items....
Coilovers
Posi and rearend upgrade
Bodywork and paint...
or I can take a vacation with friends to the Keys this July........ decisions
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1059418 - 10/15/18 03:01 PM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
Witness86SS Offline
Witness86SS  Offline
Hatfield, PA
Cam should be cheap and doable. Can probably scrounge up a 7.5 posi for next to nothing. Feed the beast!
Justin
1986 Black SS
#1059706 - 11/04/18 02:27 PM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
Edmonton,AB,Canada
Is the motor popping at accel and idle ? Does it pop when hitting the gas?check valve lash on the rockers .if the cam is going flat u will notice loose rockers. If its popping the charge in the cylinder is 3scaping out the intake valve or the exaust because of valve control.hope u figure it out
86 ss gone
85 ss new
85 z28 tpi
#1061320 - 03/31/19 01:29 AM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
I finally ordered a harness.......
Or something close to it. Only 2 more months of school, then hopefully I can afford to play with the Monte again.
Current lazy time research is as follows
1. Stock 5.3 computer tuning
2. Still reading about CAM swaps
3. Dropping the 4L60E for a Man Trans
Also, fingers crossed I can run at the local AutoX on the 6th.
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1064827 - 01/19/20 08:27 PM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
WB of NOLA Offline
WB of NOLA  Offline
New Orleans, LA
I've started collecting parts for my better than "G-Body stock" posi swap.
Parts collected do far
• LS1 F-Body torsen posi
• Moser 28 spline Monte Carlo axles with Moser studs
• Moser 10 bolt reinforced diff cover
Future purchase
• Quick Performance rebuild kit with solid pinion spacer
• QP 3.73 gears?????? I'm researching if this is what I need or should I step it up.
Called a few shops.
$800 with no guarantee because the parts acquisition didn't go through them
$500 with no guarantee. Haven't heard much about this shop.
Family willing to help, saying to follow the deep gauge diagram on a website.
Still calling around
1987 Monte Carlo SS
5.3l/4l60E
One Wheel Peel
#1064880 - 01/22/20 08:45 PM Re: The Rebirth of my nameless 87 Monte Carlo [Re: WB of NOLA]
Future purchase
Called a few shops.
That's the setup I have well I have proform girdle cover, but it's been pretty good to me. One thing you will notice if you autocross the car is that when the inside tire lifts, its like an open diff, but in a straight line she hooks great.
500/thumbs/monte39.jpg
by PB86SS/87LS
500/thumbs/IMG_5371.JPG
by BAD ASS 87
500/thumbs/SS_for_sale_1.jpg
by 86BAM
500/thumbs/003.JPG
by SSPARKY
500/thumbs/Power_Tour_08_.jpg
by 396 MonteC
