#1063129 - 08/12/19 07:49 PM Misc. Parts Clear Out - Almost all $20 or less
PB86SS/87LS Online beer
PB86SS/87LS  Online Beer
Help me clear out my miscellaneous parts stash. Combining items will lead to better deals and combining shipping wink. I've tried to put a price on each item, if you don't see it or have any questions post or PM me. Buyer to pay shipping, most items should be fairly cheap except the rear sail panels.
Battery trays, some rust but not rotted - $10/each
Alternator brackets (87-88 305's) - $5/each
Rear lower sail panels from a 86' Monte - $20
Smog pump setups(hoses, brackets, etc) off 86-88 305's, pumps spin freely - $20/each setup
Throttle cables off 305/Q-Jet 86-88's - $5/each
Stock clutch fans - $10/each
Steering shafts (also have one 78' specific splined version) - $5/each
Water pump pulleys (86-88 305's) - $5/each
87-88 SBC distributors/caps - $10
Gas pedals - $5/each
Fuel sending unit (fuel/return, no vapor line), very clean - $10
Kick panel sets - $15/each
Malibu rear plate holder, some kind of modification on bottom - $5
Visor pairs - only sage green passenger side remains
Malibu/El Camino bezels - $10/each
ECM from a 86' Monte with LG4 - $20
Wheelwell extensions from Montes (longer ones are for the Luxury Sport) - $20/pair
Seat belts in so-so shape - $5/each piece
Dash side trims in various colors - $10/set
Package tray end trims in various colors - $10/set
Stock air cleaner from a 86' LG4, a little rusty but solid - $20
86-88 maroon/claret original GM floor mats - $50 for the better set, the worse front mats - $15
T-Top center bar, has some rust issues but maybe usable to someone - $15
Exhaust manifolds off a 86' 305 - $20
Malibu tail light top trim sets - $10/set
Crank pulley off a 86-88 305 - $5
Alternator off a 88'SS, ran fine - $10
80' Malibu/El Camino bezels, no cracks but rough/painted finish - $10/each
Wiper arm set - $20, $10 for the lone single
LeMans rear license panel - $20
SS top air dam, some rust but not rotted - $15
Headliner trim for a hardtop, one set from a sage green interior, black from a Malibu, other maroon/gray from Monte's - inquire
One hood hinge, not sure what side yet, the other side is seized, can include it - $10
Seat belt retractors - all passenger sides - $10/each
Door handles, all used $5, one new aftermarket black one with a good used escutcheon ready to go, just didn't use it - $10
VSS wiring - $5
Stock valve covers off a 86' 305, nice shape with retainers- $20
Speedo cables, off Monte's with the 200-4r if that matters - $10/each
Bench seat driver side headrest seat belt guide, one dark blue one maroon - $5/each
Pontiac radiator support brackets/ducts, off an aluminum support on a Grand Prix - $10 for all of it
HVAC wiring from a 86' Monte I believe - $10
Door jamb vents, not broken - $5/each
Horns, one dual setup - $15, one single horn - $5
Hood latch - $5
Hood latch portion that bolts to hood - SOLD
Dome light with wiring lead - $5
Rear sail panel set off a 85' Monte without inserts, fair shape, no dry rot but a few scratches - $25
Rear sail panel inserts off a 86-88 Monte, very nice shape - SOLD
Plan to add a little more but this is the bulk of it as I organize/shuffle parts around.
#1063135 - 08/13/19 12:06 AM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
markg Offline
markg  Offline
nj
do you by any chance have the chrome trim for the rear wheelwells of an 84 cl?
#1063148 - 08/13/19 03:57 AM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: markg]
Sorry, I do not
#1064241 - 11/22/19 07:00 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Are these items still available? thanks
mr.awhite07@yahoo.com
#1064260 - 11/23/19 06:23 AM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
Yes they are
#1064461 - 12/15/19 10:59 AM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
mrbillisme Offline
mrbillisme  Offline
San Dimas, CA
Hi, Have a requirement for 1987 305 smog set up. The first image shows brackets but I don't see the upper smog pump adjustment bracket. Please verify that you have the Smog pump, lower mount bracket, upper adjustment bracket and valves. Regards Mrbillisme.
#1064463 - 12/15/19 04:09 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
I have 2-3 smog setups, I believe complete. Do you have a picture of this bracket to make sure we’re on the same page?
#1064466 - 12/15/19 06:28 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
Rocco_Q Offline
Rocco_Q  Offline
Rhode Island
Hi Paul,
I'm interested in the good set of maroon mats, maroon, dash trim, maroon package tray trim, and a set of door jamb vents.
#1064467 - 12/15/19 07:05 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: Rocco_Q]
Originally Posted by Rocco_Q
Hi Paul,
Hi, the good set of maroon mats was sold. I do have the dash side trim and a set of door jamb vents.
#1064469 - 12/15/19 09:25 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
mrbillisme Offline
mrbillisme  Offline
San Dimas, CA
Thanks for the quick response regarding Smog set up for 87. Actually in a bit of a unknown situation. This is actually a 87 El Camino that has had the smog pump and brackets removed along with the catalytic converter. We have replaced the air condition compressor and know that it is the same one that is used on my 85 Monte so it looks like the same smog set up should work on the 87 El Camino. I'd send a image of my 85 but you probably know what that looks like already. That upper bracket is the long slotted adjustable type for tightening the belt I don't see a way to attach a photo to this post.
#1064472 - 12/15/19 09:52 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
Ok. I'll try to take some pictures of what I have, I think I know what bracket you speak of but will take a look. Off hand the adjustable slotted one on top is for the alternator, the smog one is probably adjustable as well.
#1064473 - 12/15/19 10:00 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
T5montecarlo Offline
Lederach, PA
The slotted bracket for the air pump also has a square hole in it to insert a 1/2" drive ratchet or breaker bar, to use as an adjusting tool.
#1064475 - 12/15/19 10:10 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
mrbillisme Offline
mrbillisme  Offline
San Dimas, CA
Yes, that square hole by the attachment bolt in the bracket is important other wise who knows what you might break trying to pressure the smog pump back. GM must of had trouble tightening it.
#1064476 - 12/15/19 10:20 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
mrbillisme Offline
mrbillisme  Offline
San Dimas, CA
One other thing that is missing is the passenger side exhaust manifold heat shield that has the connector to attach the heat tube from the air cleaner snorkel.
And Yes, the smog pump is located on the passenger side below the alternator.
I see now that images can be included by up loading to a site like Flicker and embedding the URL here
#1064477 - 12/15/19 10:35 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
Rocco_Q Offline
Rocco_Q  Offline
Rhode Island
Paul,
If the other Mats are available and the package tray trim are aviailable I’ll take them.
#1064503 - 12/18/19 03:04 AM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: Rocco_Q]
Paul,
Ok, I gathered up the parts, I do have the complete “good” mat set after all. Can send a pic of all parts together or post it here.
#1064504 - 12/18/19 03:07 AM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: mrbillisme]
I see the adjustment bracket, have two of them still attached to the pump/setups. I can post or send a picture. Two of the pumps still turn by hand, if that matters too. Often the used ones and one other that I have are seized.
#1064519 - 12/18/19 08:59 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
PM's sent
#1064677 - 01/06/20 02:58 AM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
Do you still have the door ham vents? What condition r they n? Tks
#1064691 - 01/07/20 09:39 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
I do still have several vents, good shape, no cracks, I toss the ones that are cracked.
#1064713 - 01/08/20 10:27 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
MisterAdam Offline
MisterAdam  Offline
Blythewood, sc
How much for 2 door vents and the lower steering shaft? Tks
#1064765 - 01/13/20 08:48 PM Re: Misc. Parts Clear Out - Almost all $20 or less [Re: PB86SS/87LS]
Sorry for the delay, PM sent
500/thumbs/HPIM3730.JPG
by miker82
902/thumbs/monte114.jpg
by SKIDMARK
500/thumbs/100_16041.jpg
by myfirstmontess
500/thumbs/04.JPG
by Ole Blue
892/thumbs/S3010011.JPG
by Intmdatr3
