#1064569 - 12/25/19 07:38 AM Fuel tank and sending unit
jmireles Offline
jmireles  Offline
El Paso, Tx
When I LS swapped my Monte, I kept the original tank and sending unit. I bought a retro kit from Tanks Inc. that enabled me to use fuel injection. The conversation did not go as smooth as I'd hoped for. So, I'm planning on buying a new tank for a V6, which we all know has the baffling first fuel injection. I also intend to purchase the stock V6 fuel pump hanger and sending unit. I'll just transfer the Walbro 255 pump to the new unit.
Now for my question, which is wiring...
The stock carbureted V8 sending unit has a spade connector for the fuel gauge and the ground wire. The fuel injected V6 hanger looks different (at least from the pictures I saw on Rock Auto). It appears as there is no provision for the stock fuel gauge wire to connect to. How do I do this?
in '08. 3K
#1064578 - 12/26/19 05:50 AM Re: Fuel tank and sending unit [Re: jmireles]
Assuming the tank you are looking at is this? Good tank, have the a GM306C installed in my car. Not using it for the FI but for it's sump for a custom pickup.
https://ecat.spectrapremium.com/products/GM306C
Can't speak directly to what others have done for a FI pickup/sender for that tank. Specte has this one for the 87 FI 4.3 Monte. I think the pics are a little inaccurate and don't show the wires correctly. Whether the Welpro pump is a direct bolt in I don't know.
https://ecat.spectrapremium.com/products/SP172A1H
One thing I would do if I would ever buy a new tank for the SS is install a revent to make fill up much easier. A 1/2 tube from the top of the tank to the right or left of the fill tube, running up to an inch below the fuel cap. This would allow the tank to burp/purge the air in the tank when filling. Now having this 86 for 25 years and hundreds of fill up way to many times has gas came back up the filler. Venting would fix that and wouldn't effect emissions.
#1064582 - 12/26/19 05:24 PM Re: Fuel tank and sending unit [Re: jmireles]
jmireles Offline
jmireles  Offline
El Paso, Tx
Those look like the ones I saw on Rock Auto. I guess I'll have to order the unit and see how I can modify the wiring to work with my setup.
in '08. 3K
#1064586 - 12/27/19 03:15 AM Re: Fuel tank and sending unit [Re: jmireles]
From the 87 Helms Electrical Supp for a FI V6 pump/sender wires:
Purple-gauge
Black-gauge ground
Tan- pump +
Black/White- pump ground
Making sure the pump has sufficient power all the time is important. The GN boys have wire upgrade kits available. Here's some DIY info on the subject.
https://buickturboregal.com/diy-fuel-pump-hotwire-kit-buick-grand-national/
#1064589 - 12/27/19 02:43 PM Re: Fuel tank and sending unit [Re: jmireles]
jmireles Offline
jmireles  Offline
El Paso, Tx
Thank you. I bought a Racetronix fuel pump harness that the Buick GN guys use. I had to modify it slightly to make it work with the Tanks Inc. set up I have now.
in '08. 3K
#1064678 - 01/06/20 08:50 AM Re: Fuel tank and sending unit [Re: jmireles]
jmireles Offline
jmireles  Offline
El Paso, Tx
I finally finished installing the new tank today. I had to modify the hanger a bit so here's what I did:
1) cut off the fuel pump connector to wire in the connector that came with the Tanks Inc. set up. I had to do this in order reuse the Walbro 255 pump.
2) I had to separate the pump ground wire and the sending unit ground wire.
3) cut off the spade connector from the old tank sending unit power wire and wired it to the new unit.
4) cut off the tips of the feed line and return line so I could install A/N compression fittings.
5) I had to bend the lip of the tank to clear the frame and tank straps.
I made sure there were no leaks. I'll have to check the vent line since it is not relieving pressure adequately. I hear a hiss but not from the gas cap. When I tried fueling the car, it spat fuel back! I reduced the amount flowing in and slowly took it to half tank. I'll need to research the emissions system of the Monte to see where I might have gone wrong.
in '08. 3K
#1064744 - 01/10/20 03:27 PM Re: Fuel tank and sending unit [Re: jmireles]
I have a Buick GN tank and a Walbro 255gph pump and 58psi regulator. I left the OEM tank vent to the charcoal cannister open during my install. My tank occasionally burps back at me if I fill at a station that is less than level. I try to put my front wheels off the station pad to drop the front a bit when fueling. No more burps.
During the tank install, I cut a "door" on the floor of my trunk to service the pump and check for leaks without having to drop the tank.
#1064906 - 01/25/20 04:51 PM Re: Fuel tank and sending unit [Re: jmireles]
jmireles Offline
jmireles  Offline
El Paso, Tx
I'm going to check the vent hose to make sure it isn't pinched. I'll use a bore scope to get in that small space. I hope that's the cure because it takes about 15 minutes to fill the tank!
in '08. 3K
958/thumbs/th_0053.jpg
by montaguemonte
560/thumbs/carlo1.jpg
by burley
806/thumbs/82-84FBrd_tp.jpg
by greenmoonshine
681/thumbs/T5.jpg
500/thumbs/monte_carlo3.jpg
by juicylips85
