#1064338 - 12/02/19 04:31 PM Anti Roll Bars - Who Has One?
I’ve been putting off the purchase for a while and ready to take advantage of either the current sales or Christmas sales if I can’t make my mind up soon.
I’ve narrowed it down to the Spohn adjustable or the UMI 1” bar. I like the mounts on the BMR bar but I’ve seen one photo that appears to me the arms in the bar are too short for a near vertical alignment of the end link.
Anyone using any of these bars? Your experience with them would be appreciated.
I’ll drag race more than road race the car but wanted to have something that would pull double duty. Thanks in advance for your time.
#1064340 - 12/02/19 06:46 PM Re: Anti Roll Bars - Who Has One? [Re: BadSS]
Kevin I have the Spohn adj 7/8" Pro Touring bar installed in the 86. Spohn along with Marcus (SC&C) developed that bar.
https://www.spohn.net/shop/1978-198...e-Rear-Sway-Bar-1978-1987-GM-G-Body.html
It's installed on an 8 1/2" rear which makes install more difficult. On a 9" there should be less of a problem. One of the ears on the 8 1/2 needed to be removed, a 1/2' spacer at the rear mounts had to be added to drop the bar lower. These done so when the bar rotates from ride height to full compression the bar doesn't hit the rear. A talk with Marcus when I had those issues he admitted they test fit the bar on a 7 1/2 and 9" rear, never an 8 1/2''. My mods fixed the problem with interference.
When you install any of these link bars on the market as you change the rate the links will are not vertical in every position. What they want you to do is loosen the U-bolts on the housing and rotate the bar around the rear to put the link in a vertical position again. Being I drag race, full firm, street drive, full soft and autox the bar rate was changed often. Loosening the U-bolts was not something I wanted to do. So new frame mounts were made for the top of the link attachment with three location corresponding to the three holes in the bar. Also a gusset was added and now 5 bolts are used to hold that new bracket in place. Much more substantial, probably overkill, but i know it's not stressing the bracket or frame. To change the rate now all you do is remove the link from one side, move the link to the new holes on the other side and reinstall the link in the other side. No rotating the bar to get the links vertical.
Lance is using the UMI adj bar on a 9", maybe he'll jump in.
For drag racing some will use the big fat link bars. For a street car they are not advisable, way to much rate in the rear.
https://www.spohn.net/shop/1978-198...-Body-Pro-Series-Rear-Drag-Sway-Bar.html
https://www.bmrsuspension.com/?page=products&productid=31&superpro=0
#1064348 - 12/03/19 03:41 AM Re: Anti Roll Bars - Who Has One? [Re: BadSS]
Thanks for the information Bob! I was wondering about whether or not the manufacturers recommended rotating the brackets on the housing to line things up or not. I've seen some rotated and guess it would be fine if you didn't want to have it serve multiple purposes. I don't like the idea of loosening and rotating at all. Definitely like the idea of adding custom upper frame mounts for easy and "proper" adjustments - you know what they say about imitation!!! lol
So, if I'm going to do the custom upper bracket, the length of the bar's ends shouldn't matter. However, I'm leaning more toward the middle of the road 1" UMI bar ($367 with Jegs Cyber Monday Promo discount). I'm not planning on doing a lot of racing, but the ratio of drag racing to road course racing would still probably be 10 to 1.
Thanks again, Kevin
Edit - went ahead and ordered the UMI 1" hollow bar and a rear shock tower brace. Figured if I ended up doing rear coil overs that would provide a little extra support.
#1064349 - 12/03/19 04:47 AM Re: Anti Roll Bars - Who Has One? [Re: BadSS]
If you would want a couple pics of the link frame brackets I made I could send them to you. PM me an email address if you need pics.
Installed the UMI shock tower brace a few years ago. Always thought someday I would weld in another crossmember between the frame rails just ahead of the gas tank. The UMI brace took care of that need.
#1064488 - 12/17/19 01:47 AM Re: Anti Roll Bars - Who Has One? [Re: BadSS]
Duts87SS Offline
Duts87SS  Offline
Spanish Fort, AL USA
I'm running the adjustable Hellwig bar. It installed with no issues; bought it from Mark. Mark (Marcus) at SC&C would be the best person to talk to; he literally wrote a book on supsension.
Dustin
87 SS
#1064492 - 12/17/19 04:32 AM Re: Anti Roll Bars - Who Has One? [Re: BadSS]
Hi Dustin, long time.
Marcus and Steve Spohn originally co-produced the 7/8" adj rear Pro Tour bar over a decade ago when bolt on adj rear bars really didn't exist.
Marcus doesn't show that 7/8" Spohn bar available and now sells the Helwig 1". Interesting.
The Helwig is considerably cheaper than the Spohn, The Helwig may have higher rates, the links on my 10 year old Spohn are alum and stainless, excellent setup, may be the difference in pricing.
But the Helwig may be the best bang for a buck for an adj rear street sway bar.
#1064499 - 12/17/19 11:27 PM Re: Anti Roll Bars - Who Has One? [Re: mmc427ss]
Duts87SS Offline
Duts87SS  Offline
Very long time. Trying to find some motivation here.
Hope you have a Merry Christmas.
Dustin
87 SS
#1064506 - 12/18/19 03:48 AM Re: Anti Roll Bars - Who Has One? [Re: BadSS]
I dug up a pic of you standing in front of your car at the Cleveland Convention, you were just a kid back then. That and Nashville were two really good NMCOA conventions.
Happy holidays to you and yours.
#1064529 - 12/19/19 10:09 PM Re: Anti Roll Bars - Who Has One? [Re: BadSS]
Duts87SS Offline
Duts87SS  Offline
I've only done the Nashville convention. Still, over 17 years ago.
Dustin
87 SS
#1064533 - 12/20/19 04:16 AM Re: Anti Roll Bars - Who Has One? [Re: BadSS]
I sent you a pic via email.
Somehow my pics from Nashville got mixed with Cleveland, yep that was Nashville.
The wife and I made that a week vacation, Went to see Elvis in Memphis, then did the cruise to the Vette Museum and the plant with the other Montes on Fri. That 60 mile trip back to the convention with a 1/2 dozen Montes in tow didn't take very long.
500/thumbs/Unnamed.jpg
by tommy64red
500/thumbs/IMG_1296.jpg
by CornerCarver1980
by Sherdep
500/thumbs/p9290119p_copy.jpg
by Nycore
500/thumbs/MC14.JPG
by asghan23
